Slow cranking when hot
Old May 30, 2002 | 09:17 AM
dd85T/A's Avatar
Car: 85 T/A
When my car is hot it turns over real slow. The battery is new and also the cables. Is the starter/solenoid getting to hot? Should I install a heat shield? Replace the starter/solenoid? relocate the solenoid?The motor is a 350 TPI with a 5 speed.
Thanks for your help.
Old May 30, 2002 | 10:15 AM
BigRuss's Avatar
Re: Slow cranking when hot
Most likely heat soaking into the starter. Heat shield would help, but an aftermarket starter would help even more.
Old Jun 1, 2002 | 04:04 PM
LPE383's Avatar
Car: 84 Z28
Engine: 350 L98 from 89 vette
Transmission: World Class T5
Axle/Gears: 3.70 Precision Gears
I too have this problem! When my car is hot and i shut it off! There is NO restarting any time soon! As you could imagen this is a pain in the ****! Anyone suggest a good starter for a fair price???
Old Jun 4, 2002 | 08:19 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I and several friends have bought the starter listed here:
http://www.tommyjohnsonjr.com/bs/
It's the same as most of the other starters listed in Summit and Jegs, and even their severe duty starter is cheaper than the regular starters at other places. It sounds really cool when cranking the engine over.
Old Jun 5, 2002 | 01:45 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
when you have bad heat soak you can do two things in my book. one is get a remote solenoid and mount in a cool spot. or by a high torq starter. My father had the heat soak problem in his 68 vet and he installed a torq starter it starts every time now. He use to have to wait or dump cold water on starter to speed the process IMO the torq starter is the way to go
Old Jun 5, 2002 | 07:24 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
An ignition cut-out switch will help a lot; it kills the spark so there is less load on the starter when hot. I have one on mine, and flip it off when cranking until the engine gets 'up to speed', then flip the switch on and it fires right up. It can also be considered an 'anti-theft' device and might help lower your insurance premiums to boot.
One other thing that may cause hard starting, is having the timing advanced to far.
Pete
Old Jun 6, 2002 | 12:24 PM
LPE383's Avatar
Car: 84 Z28
Gregwestphal, What was the total price that you paid?? I seen them for 169.95 there. How much was packaging and handling?? What kind of cool noise does it make?? How do they rate these as far as how much tq they put out?? Do i need to email them about my particular application??? thanks for all the help!
Old Jun 6, 2002 | 02:43 PM
Engine: 385 HSR
I bought the standard model for $120, plus several dollars S&H. It has a nice medium/high-pitched whine, like a lot of the newer cars have, not a grunting noise like a regular older starter. Not sure about the torque or hp rating, but this model handles my 11.1 compression 355 with ease. It'd be easier to call them up to ask about applications and to order...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
