Datalogging w/ the 1228746
Old Mar 28, 2019 | 05:06 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Trying to prep for my ALDL cables arrival I've installed both TunerPro RT & WinALDL on a spare laptop. I'm only interested in datalogging w/ the 1228746 for diagnostic reasons. All problem specific situations will likely have an individual thread, but this is where I'll start this datalogging journey! Any information you're willing to share would be appreciated. Feel free to post links to other software one can use, tips & tricks, links to other useful threads, etc.
Old Mar 28, 2019 | 05:38 PM
Engine: 305 / 350
Re: Datalogging w/ the 1228746
Things I have are the AXKT.bin file, 61.adx file, and $61.xdf file. Loaded them up in TunerPro RT, I think all went well but i'm also not sure. I just have this long list on the left with Scalars, Flags, and Tables. Just a blank shaded grey work space off to the side. I guess it's Plug N Play ready.
Also did a test launch of WinALDL, and received a COM1 error, Clicked ok, it loaded a simple data table. I think it's ready for me to assign a COM port within usable range to my cable and get to logging.
What software title do you find with the best GUI that's reasonably user friendly too?
File Type: zip
Old Apr 2, 2019 | 04:53 PM
Engine: 305 / 350
Logging went off without issues in WinALDL. Can't get TunerPro RT to connect to the ECM. I keep clicking the cord icon but the statuses at the bottom never change.
Old Apr 2, 2019 | 05:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you tried to put the ecm in the 10k mode?
I can’t recall if this ecm needs to have it 10k to start dataflow.
You can try different com ports under tools/tunerpro preferences
no need to load a bin unless you plan on modifying it to be burned. Or want to look at its data but to datalog you only need the $61 adx.
Old Apr 3, 2019 | 03:42 PM
Engine: 305 / 350
SUCCESS: I've connected to the ECM in TunerPro RT. I had to change a setting related to the cable, I also activated the 10K mode so idk which made it work but it worked! The screenshot below is after the log at KeyOnEngineOff
I have a data-log file I'd like reviewed... but I can't upload a .xdl file
Old Apr 3, 2019 | 04:06 PM
Engine: Lb9
Transmission: M20
You have to have the log in a zip folder to attach to the post.
Old Apr 3, 2019 | 04:23 PM
Engine: 305 / 350
EDIT: I should have known that... I've seen it.
File Type: zip
Old Apr 3, 2019 | 05:54 PM
Engine: Lb9
Transmission: M20
MAP HIgh error 33 is being thrown if you look at the item list.
At least it was showing on the adx I got from gearhead efi.
Old Apr 3, 2019 | 06:28 PM
Engine: Lb9
Transmission: M20
Can you zip and post your adx ?
Old Apr 3, 2019 | 06:54 PM
Engine: 305 / 350
.adx sent to me w/ the ALDL Cable, dashboard modified by me.
Old Apr 3, 2019 | 07:07 PM
Engine: Lb9
Transmission: M20
You might want to throw in a new o2 it seems lazy.
It can’t hurt just as part of a tuneup.
what does your service manual say about code 33.
It shows in your adx too.
https://www.rockauto.com/en/catalog/...2)+sensor,5132
Old Apr 3, 2019 | 07:50 PM
Engine: 305 / 350
Code 33: MAP Signal Voltage High
Test # 1 > Check for voltage less than 1V at MAP Connector w/ Ignition On > Passed - Read .5V
Test # 2 > Probe connector Ground w/ test light to battery voltage > Passed - Test light lit
Per service manual it's a Plugged Or Leaking Sensor Vac Hose or Faulty MAP Sensor.
Old Apr 3, 2019 | 07:52 PM
Engine: Lb9
Transmission: M20
It’s odd your check engine light isn’t on but tunerpro says there’s a error.
Old Apr 3, 2019 | 07:58 PM
Engine: 305 / 350
When I drove it yesterday the CEL came on for a millisecond before she stalled out. The codes will only store after 20 sec or so under the conditions that led to the code iirc. Tried to force it to come back during my laps today but it didn't...
Old Apr 4, 2019 | 08:09 PM
Engine: 305 / 350
How do you get codes 33/34 at the same time? MAP voltage can't be both high and low...
Old Apr 4, 2019 | 10:31 PM
Engine: Lb9
Transmission: M20
Even though your status shows closed loop early at 200f the o2 was heated up and started to swing.
Are you getting both map codes stored in the ecm ?
I think you might have a vacuum leak the idle is high and the iac is commanded in trying to lower down the rpm. Does the rpm ever come down to 650 range ?
The high and low codes could be caused by the surging.
Old Apr 4, 2019 | 11:07 PM
Engine: 305 / 350
No, doesn't settle at 650 rpm's. I was able to get it to idle at 950ish by adjusting the idle screw while it was running at operating temp. The MAP & TPS voltage dropped some too and the surging smoothed out. This was like the last 2 min of the log. No codes are stored but I'm gong to disconnect the battery for a few and log again in the morning.
Old Apr 5, 2019 | 10:27 AM
Engine: Lb9
Transmission: M20
The iac counts need to be around 20 warm. I did notice the tps going from a hair over 1.0 to .81 at the end .
you might want to replace the tb base gasket or check for leaks there first.
Old Apr 5, 2019 | 07:56 PM
Engine: 305 / 350
New find, while running Battery Voltage dropped to 9V, what in gods name can take a battery from 12V+ down to 9V and back up within seconds? Even caught a Low Battery indicator in TunerPro, but nothing on the dash... No accessories were on and the battery is tested good.
Old Apr 5, 2019 | 09:10 PM
Engine: Lb9
Transmission: M20
Has the alternator been tested ?
This could be a regulator malfunction.
I think the voltage is not battery direct but fuel pump voltage on pin b2.
I mentioned this post #6
https://www.thirdgen.org/forums/dfi-...ed-please.html
Old Apr 5, 2019 | 10:54 PM
Engine: 305 / 350
Haven't had the alternator tested, this time I will swap it for a known good unit and log again. *IF "voltage is not battery direct but fuel pump voltage on pin b2" how would we know, is there a TunerPro glossary?
Old Apr 6, 2019 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The voltage in the data stream is from the ignition switch.
RBob.
Old Apr 6, 2019 | 08:47 AM
Engine: 305 / 350
Went to change out alternator and found the connector had been replaced. What's there is a 4-wire connector w/ 2 wires were cut. Should that work like a 2-wire or should I head to the jy to grab a 2-wire?
EDIT: Checked my other 92 and it has a 2-wire connector w/ wires coming from the center, I'm just going to swap the alternator and see how it goes.
Old Apr 6, 2019 | 10:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Two wires is correct. A large red wire on the S terminal that goes to the starter. Then a regular sized brown wire going to the F terminal. The terminal positions are molded into the body of the connector.
RBob.
Old Apr 6, 2019 | 10:48 AM
Engine: Lb9
Transmission: M20
RBob.
Thanks , was unaware of that
Old Apr 6, 2019 | 04:44 PM
Engine: 305 / 350
After the alternator change... I'm starting to think my likely aftermarket fuel injectors are dumping more fuel than the minimum idle set requires. What does the data say to you?
Old Apr 6, 2019 | 06:32 PM
Engine: Lb9
Transmission: M20
What’s your int and blm at idle closed loop ?
Old Apr 6, 2019 | 07:02 PM
Engine: 305 / 350
Varies, last glimpse blm was up to 150 and int was 151 at one point
*Note the drop in RPM's as I cycle through gears, it completely stalled once. Near the last few min it looked like MAP and TPS voltage was in line, I shifted in reverse boom code 33 map high in tunerpro, no CEL. Log ended.
File Type: zip
Old Apr 6, 2019 | 08:05 PM
Engine: 305 / 350
UPDATE: For the pure HELL of it I grabbed a spare ECM w/ stock AXKT PROM and tried it. I was shocked at the difference, the fuel coming from the injectors looked different, like an ultra fine mist cone spray and not the extremely visible cone spray that led me to believe the injectors were dumping fuel. I readjusted the idle screw in live op allowing the ECM to adjust accordingly got idle to 850-900 rpm's in park. While the log below was created in CL, It seems I achieved MAP voltage @ idle of 1-1.5V and TPS voltage @.94 defined as within spec in my gmsm. Most importantly, no surging & no stalling while cycling gears!
Not to kill my excitement, but we'll see if it runs the same come morning
Old Apr 6, 2019 | 10:26 PM
Engine: Lb9
Transmission: M20
I hope it was your ecm or chip, that would be great to solve this issue.
Old Apr 7, 2019 | 06:07 PM
Engine: 305 / 350
It didn't, It hurt so bad I connected the battery in my other 92RS and one crank, flawless ignition and idle... and it's her 1st start of the season. I sat listened to a few tunes and watched the log, I noticed some differences in MAP and TPS voltage. Anything in the previously shared logs compared to the one below stand out?
File Type: zip
Old Apr 12, 2019 | 07:07 PM
Engine: 305 / 350
Newest TunerPro log file.
Old May 18, 2019 | 09:03 AM
Engine: 305 / 350
How can I see timing curves and graphs in TunerProRT like you'd see on a traditional scanner like a Snap-On or is there another software for the laptop?
Old May 18, 2019 | 10:57 AM
Engine: Lb9
Transmission: M20
To see the timing curve view the bin. More than likely axkt.
btw 33 can be reprogrammed out of the prom but I don’t think it will help your running issue.
Old May 18, 2019 | 07:30 PM
Engine: 305 / 350
I'm not modifying anything my friend. Does the Gear Indicator in TunerProRT data show reverse or only drive & park/neutral?
Old May 18, 2019 | 08:49 PM
Engine: Lb9
Transmission: M20
I’m not sure you will have to check the item list.
I think it’s only capable of seeing park and neutral.
Old May 19, 2019 | 01:17 PM
Engine: 305 / 350
Is OLDPA3 Engine Knock?
Old Jun 6, 2019 | 02:05 PM
Engine: 305 / 350
Sorry about the title of this datalog I was a bit excited to complete a few laps without loosing fuel pressure! I don't know if the O2 voltage swing is normal, also not sure what a 121 BLM is lowest I've seen is 128, but normally around 140-150...
File Type: zip
Big Bob
Nov 3, 2000 10:47 AM
Mark305TBI
Oct 22, 2000 05:51 PM
UnderDogRS
Oct 15, 2000 01:16 PM
UnderDogRS
Sep 20, 2000 04:53 PM
