Need help/info
Old Aug 29, 2002 | 07:05 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Need help/info
I have a '85 TA with a 305 TPI out of a '89. The electronics and computer is still the stock '85's It has no cold start injector. It is a pain in the @$$ to start. Is it possible to burn a PROM for a '85 with the fuel enrichment program in it? I have no idea how Prom burning works.
Matt
Old Sep 9, 2002 | 08:43 PM
Matto'85TA's Avatar
Can anybody help me? I'm completely new at this.
Old Sep 10, 2002 | 01:26 AM
Morley's Avatar
It'd be easier and cheaper (in the long run) to switch to the 165 ECM, then you'd be able to use much better programming (bin files).
Old Sep 10, 2002 | 07:44 PM
Matto'85TA's Avatar
Thanks for the help.
Does the 165 connect directly to the '85 harness with a mods?
Old Sep 10, 2002 | 10:28 PM
Morley's Avatar
Yes, it is a simple swap of about 10 pins and about 4-6 splices and adding 2 relays that do away with the expensive MAS module that is piggybacked on your ECM.
Look here for the low down. http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Ignore the part about getting the wiring for the relays from a "donar" car and about putting them in the engine compartment. Pepboys sells the plugs for the relays and the relays themselves. Instead of making a new hole in the firewall to put the relays in the engine bay I just mounted them to the bracket that the MAS module was on, then the wiring that comes with the relay plugs is all you'll need to wire them in.
Old Sep 11, 2002 | 07:23 PM
Matto'85TA's Avatar
About how long and how much will this take. I'm kinda low on funds right now. Also, how hard is this? I'm pretty good with electrical work, but messin around with the engine harness might be a little beyond me. Especially the "repinning", what is that?
Thanks for the help and info.
Matt
Old Sep 12, 2002 | 01:53 AM
Morley's Avatar
If you do the splices like on that web page (crimp on splices) I'd guess the whole thing would take 2 hours if you took your time and labeled all the wires that you are going to move around. I personally don't like crimp on splices and don't trust them. So I carefully cut the insulation in the "middle" of the wires about 1/2" long and solidered the wires, then wrapped in a good quality electrical tape.
Repinning is just that, there are several pins in the ECM connectors that have to be put in other locations. These pins are a snap to get out of the connectors, just remove the "combs" on either side of the connector and using a small jeweler's screwdriver or similar, you find the little lock tang that keeps the pin in place and depress it while GENTLY pulling on the wire.
Be sure to mark the pins with their remove from location and with their to be installed location (eg D4-A15). That way if you ever need to go back to the old ECM you'll have a good idea of what went where.
The cost? Figure on about $65 for a 165 ECM and memcal from either E bay or possibly someone on these boards selling one.
2 relays at about $14 each
2 relay connectors at around $24 each (expensive little buggers) but there is a cheaper way, you just have to be darn sure of the relay pinouts.
After that you'll be set to mod your engine and start burning proms.
Old Sep 12, 2002 | 07:15 PM
Matto'85TA's Avatar
Hey, thanks a lot for the info and help. This will have to be winter project. Is it all right to PM you if I need help?
Thanks again,
Matt
Old Sep 13, 2002 | 12:12 AM
Morley's Avatar
Thanks again,
Matt
Sure, there are also a lot of others here that have done this swap. I just did mine a couple of months ago, so it is all still fresh in my mind.
libolt
Jun 9, 2012 11:29 PM
crimsoncomedian
Mar 23, 2012 01:34 PM
J0hn_J0hn08
Carburetors
Jan 22, 2011 12:43 AM
Myfirst85
Jan 21, 2011 01:52 AM
F_N_JUNK
Jan 6, 2008 09:26 PM
