Schematics for 2732A Eprom burner?
Old May 29, 2003 | 08:19 PM
dennis6's Avatar
Car: 1991 Camaro RS
Anyone know where I can get plans for a 2732A eprom burner? Money is tight and I don't want to blow 150 dollars on a burner. However I have an electronics degree and can build a burner cheaply. Thanks for any help.
Old May 29, 2003 | 08:36 PM
gunther's Avatar
I am not sure if these will work.
Take a look.
http://batronix.com/electronic/circu...layoutsb.shtml
http://www.qsl.net/iz7ath/web/home_eng.htm
http://electronics.alternatezone.com/eprom2.htm
Old May 29, 2003 | 09:02 PM
JohnL's Avatar
I built this one.
This will do your 32k proms, and there are circuit diagrams there.
You can get a kit from Dick Smith Electronics in Aus for about $90 US, but it takes some extra work to program proms over 256k, and it won't do EEPROM's.
Batronix is a better way to go, I think.
John
Old May 30, 2003 | 08:14 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks Gunther and JohnL. Not sure the batronix will program a 2732A, however the one you built looks like it will.
Old Jun 1, 2003 | 11:23 AM
Vader's Avatar
A PP-II should do 2732As. It's listed in the RPOM selection tables, anyway, and I know it will read some of the old ones I have.
Old Feb 23, 2010 | 11:30 AM
toneye's Avatar
Re: Schematics for 2732A Eprom burner?
dennis6 i have same car 91 rs 305 my ecm went bad we are getting new box then we will test eprom.if my eprom is bad do you know where i can get one.mechanic secretary tells me they are not available in calif for my car she has made calls to try to get eprom.Can you help
Old Feb 23, 2010 | 11:34 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Holy Necrothread.
The bin you need should be able to be found in one the bin libraries located at moates.net, tunerpro.net and a few others that people have started.
Then you can burn it to an new E/EPROM, install and go.
Old Feb 23, 2010 | 09:02 PM
jim_in_dorris's Avatar
If you looking for cheap, this is it.. I have no affiliation with these people, just looking to save money myself
http://cgi.ebay.com/PCB35-Willem-EPR...item3a580877c9
$750 L98
Feb 1, 2025 02:25 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
thunder57
Nov 7, 2015 02:28 PM
gta892000
Sep 16, 2015 12:37 AM
the_nikfive
Aug 11, 2015 02:46 AM
