Tuning with the EBL
Old Feb 16, 2022 | 02:55 PM
  #4951
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Tuning with the EBL
Originally Posted by alan91z28
I have been having an issue over the last year with a "hesitation/stumble" in the ~3000 rpm +/- 300 say range when i am just on light throttle cruising speed.
I have had good luck with EBL in my other projects and generally in this project as well, but I haven't been able to get rid of this... Doesn't seem like i am in AE as this is pretty much a constant type throttle and while I have altered those tables it didn't seem to make a difference. Seems like when the problem develops it is when i am getting a leaner operation in closed loop in these areas compared to the area right before / right after
I noticed that this only happens when the engine is warmed up and today I forced it to stay in open loop and have no issues at all, although granted my VE table is a little rich all the way around
Engine is a ZZ5 with RAMJET 350 top end, shorty headers, GM TPI type distributor, etc, heated O2 narrowband, etc... My build thread is
https://www.thirdgen.org/forums/engi...t-coupe-2.html
Also interestingly I started out this project with a Holley HP EFI as I was thinking about using that platform for all my swaps, but Holley introduced an error in their software for these types of ignition setups and I got tired of waiting for them to fix it (which they still haven't) so last July 4 weekend I tore it all out and put the EBL P4 in and had it running better in 2 days than the Holley ever ran.
Other than this hesitation it runs great, and in open loop it runs completely super but there must be something i am over looking as no reason this mild engine combo can't run normal closed loop
The file attached is my bin (to force open loop all i did was raise the ECT enable to 140). The two datalogs are one in closed loop (PROM ID 00130) with some markers where i can feel the hesitation and then an open loop datalog (PROM ID 00131) today (no markers and nothing to mark in terms of any problems, but i did a lot of reference running in the 3000 rpm point)
Thanks for any advice
just out of curiosity, did you get this sorted out?
Old Feb 18, 2022 | 11:54 PM
  #4952
Yariv's Avatar
Hi,
Using TunerPro, How Do I disable lock-up besides 4th gear?
Thanks.
Old Feb 19, 2022 | 04:49 AM
  #4953
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Yariv
Hi,
Thanks.
There are a couple of ways to do it, but the easiest is likely the low gear MPH to lock/unlock values.
Set TCC - LoGr MPH OK to Lock to 255 MPH
Set TCC - LoGr MPH to Unlock to 254 MPH
Adjust the TCC - Forced Lock value high enough so that at red line in 3rd it won't get activated.
RBob.
Old Apr 19, 2022 | 10:40 AM
  #4954
Blown_WS6's Avatar
Car: 1991 Firebird Formula
So every time I do a VE learn, I'm doing it via my WBO2 and only the top right of the tables will adjust. I noticed when it will learn the cell highlight is green. Everywhere else the cell highlight turns orange and won't adjust. I have the WB selected for VE learns in the preferences screen on the general setup and the min CTS set to 125 deg F and the max CTS set to 220 deg F with a smoothing factor of 4. In the ADC channels I have the AEM WBO2 selected on Channel 0 where the WB button is pressed. I have the Closed Loop Enable set to 150 deg C so it stays in open loop the whole time but I notice that it is still going into closed loop and when any PE or AE is active it won't learn. I had the tune pretty dead on doing manual adjustments and data logging but then I bumped my AFRP up another 5psi because my Duty Cycle % on the injectors was getting over 90% at the top of WOT and I wanted to give myself more wiggle room since it needed a little more fuel on the 95 and 100 load columns.
What else do I need to change to get the VE learns to adjust properly on the rest of the table?
Old Jul 30, 2022 | 10:48 PM
  #4955
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Transmission: MK6 Manual
Axle/Gears: 3.45
Hello everyone, been a long time since I was here. I recently resurrected my old girl. Lots of work but in short I'm running the EBL flash setup on a TPI 355 with a 5 speed. The only stock parts left in the engine are the throttle body and the plenum that's ported a bit. I'm looking at my datalog and to me (not a tuner by any means) it looks pretty good. The DC is around 70 with TPS at 90. I assume that means the injectors are matched pretty well? or should I use more fuel? The BLM (short term?) stays at 128 for the most part which I thought was strange. I want to start dialing in the timing but I'm not sure I should yet. Any help is appreciated.
Old Aug 10, 2022 | 08:23 PM
  #4956
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
So ended up doing the whole bin all over again because I found that somehow ai had swapped bins to the pretty much stock 1006 file..I've now calculated the fuel tables BPCvs VAC, BPC vs Boost, Multiplied the AE Map PW table and TPS table by .856 as described in the Intro to tuning page part 2 for 50 psi fuel and 24lb injectors. She idles steady cold, and overall runs pretty good. Only issue is at around a constant 1500 rpm it has a slight stumble and the tach will actually bounce around a little bit in sync with the driveability issue. Also will surge a bit when coming off throttle. I've added IAc steps, bumped TCC lock to 100mph (it's a 5 speed) pushed closed loop to 100C and set EGR SA to 0.0 degrees (EGR is removed) and set the DFCO to 100C.Now on my 5th VE learn. Any help is appreciated Thanks
Old Aug 12, 2022 | 05:38 AM
  #4957
RBob's Avatar
Car: check
Engine: check
Transmission: check
Make sure that the TCC option flag is cleared. This way none of the TCC logic is run. The N/V ratio and reverse lockout is instead.
Set the hiway lean cruise CTS enable high to disable it.
RBob.
Old Aug 15, 2022 | 07:40 PM
  #4958
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
RBob.
Hi Rob, thanks for the reply. I had already unchecked the TCC and set the HWY to 100mph but I set the HWY min coolant to 100C as well. I just went for a drive after changing "fan on bump steps to 5 no change. Ill take her for a run tomorrow with the coolant temp bumped up tomorrow. I switched bins back to 1006 today just to see if it extinguished that issue and it did. Thinking I may have the fuel tables wrong. I calculated assuming the 1006 bin had 22lb injectors.
Old Aug 18, 2022 | 08:31 PM
  #4959
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Hi Rob, just ran it, didn't change at all. When she's warmed up coming to a stop with the clutch disengaged it surges pretty bad for a few then she corrects herself. The o2 wave is max rich then lean, seems like she's trying to correct fuel. I've read about smoothing out the low speed VE around this area. Should I give this a go or try something else? I don't know if it's helpful but here's the specs on the car: TPI 355, SLP runners, stock plenum matched, 22lb injectors AFR Eliminator heads 180cc with Scorpion 1/6 rockers, Comp cam 08-302-8, gross lift of 0.48 for both intake and exhaust. Duration is210 intake and 220 exhaust, lobe seperation of 112..and a stock throttle body.
Old Aug 18, 2022 | 08:39 PM
  #4960
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 18, 2022 | 08:46 PM
  #4961
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 18, 2022 | 09:16 PM
  #4962
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 18, 2022 | 09:18 PM
  #4963
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Looks like coming to a stop she leans out to much, O2 goes to 0V then spikes adding fuel to compensate and just gets into a loop. It does smooth out after a 4 or 5 surges.
Old Aug 19, 2022 | 06:13 AM
  #4964
RBob's Avatar
Car: check
Engine: check
Transmission: check
On a warm engine with no other loads, adjust the idle stop screw to get 20 - 25 IAC steps. The RPM is dipping too low and triggering the stall saver. This is what causes O2 to also spike up (rich).
It looks like the engine settles nicely to a 750 RPM idle speed.
May want to add to the VE table in the area where the RPM dropped like a rock. It would be better to post the graph area and the same area of the analysis screen shots.
RBob.
Old Aug 20, 2022 | 09:03 PM
  #4965
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
So I set the TB screw so that she was around 20-25 steps and set the lean cruise at 200c. Still has the surge comeing off throttle, no worse no better, and the "blip" in rpm also is still there, only seems to happen after being driven for at least 10 min. Here's a couple shots of the surge in the driveway.
Old Aug 20, 2022 | 09:04 PM
  #4966
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 20, 2022 | 09:05 PM
  #4967
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 20, 2022 | 09:10 PM
  #4968
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I honestly don't understand what you mean by give it more ve where the rpm dropped like a rock. You mean where the kpa and rpm meet on the graph? 48kpa and 587 rpm? Sorry, I don't deal with this stuff in the dealership.
Old Aug 20, 2022 | 09:56 PM
  #4969
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I also have the EGR blocked off, the air pump and canister removed.. maybe there are some flags I need to set/unset? I unchecked the EGR but wasn't sure what the egrNC was for so left it.
Old Aug 20, 2022 | 10:05 PM
  #4970
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I’m sure this will be elaborated on but look at you ve dip add fuel to see if fueling helps stabilize surge.
no / nc is just the solenoid state max egr vs coolant temp to disable operation.
Old Aug 21, 2022 | 09:28 PM
  #4971
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Been on this a better part of the day, Cold seems fine. Got her to settle around the 20-25 step mark with IAC and set the rpm to 750 rather than 825 in the bin. Started doing the same surging when hot, added 5 steps to fan on bump, no change. Messed with VE several times several road tests, no changes. I really don't know what else to do. Seems to run fine on the stock 1006 bin but I think I'm leaving a good amount of power on the table at that point. Here's the VE table after screwing with it, looks like a mess to me but what do I know.
Old Aug 21, 2022 | 09:29 PM
  #4972
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Old Aug 22, 2022 | 10:48 AM
  #4973
If it's forced to stay in open loop, does it still surge?
Old Aug 22, 2022 | 11:41 AM
  #4974
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Yes it does
Old Aug 22, 2022 | 11:43 AM
  #4975
Yes it does
maybe it's not a fueling error? Vacuum leak when hot? I'm speculating to give a broader perspective
Old Aug 22, 2022 | 11:51 AM
  #4976
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Yes I appreciate that. I don't rule out anything but when I flash in the 1006 bin that came with ebl, car runs perfect hot or cold. If there was a vac leak I would imagine it would be present all the time. The only real chages made from that bin to mine is the 24lb injector calculations, Anything else I've done is to try and correct this BS.
Old Aug 22, 2022 | 11:56 AM
  #4977
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I'm going to run this bin for a while, do some VE learns see what happens. I would think even though it fueled for 22lb injectors she will be adapting for more and more fuel.
Old Aug 22, 2022 | 12:48 PM
  #4978
wait, I'm confused between me probably misreading previous posts and this one. Which injectors are you using? 24 or 22 and then which ones? Delphi, holley, bosch 3s? Did you change the injector voltage offsets and the lb per hour?
Old Aug 22, 2022 | 07:11 PM
  #4979
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I’m pretty sure 24lb I think they are accel. I bought them back in 2009 when I had the “speed shop” build the motor.
Old Aug 22, 2022 | 07:14 PM
  #4980
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I think I’ve done everything. I followed the @intro to tuning “ there was the bpc vs boost and bpc vs vac . Then the other calculation based on the previous injector size. Forgive me I’m on the phone and am doing bedtime with my little one.
Old Aug 22, 2022 | 07:33 PM
  #4981
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
This is what I was talking about …The best way to compensate for a change in injector flow is to use the ratio of the old injector flow divided by the injector new flow rate. Using that ratio compensate the two AE PW tables (MAP & TPS). As an example, say that the 61 #/hr injectors are replaced with 80.5 #/hr injectors at 18 psi. The new flow rate is then 94.7 #/hr.Creating the ratio:
61 / 94.7 = 0.64
Go into your calibration editor and open the two AE PW tables. Multiply each entry by 0.64 (toolbox!). Save tables, save calibration (BIN). Done
Old Aug 23, 2022 | 08:12 PM
  #4982
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Hope I'm not out of line but, could you elaborate on this? What tables aam I looking for exactly and how do I calculate this?
Old Aug 23, 2022 | 08:29 PM
  #4983
not out of line at all. Injector voltage offsets. I'd have to dig or open the laptop and tuner pro for the exact table name. Injectors usually have different offsets. The manufacturer of the injector should supply it. Sorry if my example is difficult to read. Find the part number on those injectors. Maybe it's leading you down a bad trail from the 1006 bin.
Old Aug 24, 2022 | 08:06 PM
  #4984
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Damn you guys are good. I'm going to look into this and get back. Weather has sucked here so haven't been at the car. Thanks man.
Old Aug 27, 2022 | 01:48 PM
  #4985
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Will this wideband o2 sensor work with eblflash 2 ecm? https://www.innovatemotorsports.com/...-kit-8-ft.html
Old Aug 27, 2022 | 05:31 PM
  #4986
Larry's Avatar
Car: 86 Corvette
It should work. I used an innovate for years until it died. I recommend one with a gauge so you can monitor without your pc attached. I use this one
Amazon Amazon
because it has a shallow gauge the worked with limited space behind my dash.
Old Aug 28, 2022 | 02:38 PM
  #4987
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Well COVID finally caught up with me last week, so I had a little time to look at the car. I figured out those injector offsets. It's rated a little differently and at a slightly different voltage but ai plugged them in best I could and just moved the decimal. I also found one bolt had backed out of a runner, not sure if it was causing leak but either way the surge is probably 90% gone. I then pasted the origninal blank VE table back into the bin and ran some Ve learns. Seems she is really adding VE right around the spot where the coasting shudder or "blip" takes place. Looks like it's going lean on the diag screen, possible intermittent misfire. Just for good measure replaced cap and rotor as I've had a ton go bad in this car just from sitting in the garage in New England,.. (not this year though) While swapping caps noticed 1 wire doesn't "click" onto cap and has some light rust residue where all other connections look perfect. Road tested, exactly the same issue.Started checking wire proximity to the headers, some are pretty close, no signs of burning. Isolated wires as good as possible just for testing puposes, ran like a total bag of **** under load, backfiring horribly. Suspected I swapped wires but everything looks perfect, Seems to drive perfect when light throttle, even snapping out of gear. Think the wires got cooked, been on the car since 2005. when I was learning VE after setting the offsets car really seem to run perfectly, other than the little "blip" Wires should be here this week so hopefully this will close the case and we can move on to some timing adjustments. Thanks for that info,
Old Aug 28, 2022 | 05:26 PM
  #4988
KITT1983's Avatar
Originally Posted by Larry
It should work. I used an innovate for years until it died. I recommend one with a gauge so you can monitor without your pc attached. I use this one https://www.amazon.com/s?k=AEM+30-03...f=nb_sb_noss_1 because it has a shallow gauge the worked with limited space behind my dash.
thanks
Old Sep 2, 2022 | 08:51 PM
  #4989
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
so after that day, she still had that slight stumble on light throttle, cruising speeds. I decided to replace the cap and rotor, drove it and was way worse, barely drivable. ordered some new wires from Summit, got a set of 8, no coil wire?? Removed the old wires and sure enough, found one white and cracked burnt by a header. Replaced the ones I had and no change, couldn't believe it. Summit is sending the coil wire but i couldn't wait and went to the parts store and bought a set. installed the coil wire and sure enough, huge change, idles perfect no surge but still has the damn stumble at light throttle cruising speeds!! I also flashed in the stock 1006 bin and it's a little more mild but still has the stumble. At this point I'm thinking dizzy or spark module. The fuel pressure is set to 50, anyone ever have issues with the pressure too high? causing injectors to drip? I'm at my wit's end here. Any help is appreciated.
Old Sep 3, 2022 | 08:38 AM
  #4990
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it isn't already, disable the lean cruise highway mode by setting the CTS or MPH enable high. See if it is better.
RBob.
Old Sep 4, 2022 | 08:07 PM
  #4991
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I had already disabled the lean cruise in the beginning but I finally figured it out. It was a combination of everything. The wires were def an issue but when I moved them got way worse, summit didn't send the coil wire which was most of the problem, replaced it with a cheap one from the parts store, mostly gone. replaced the ignition module and everything is perfect, idle needle looks like it's painted on, no surging, smooth throttle, can drive at 1k in 5th gear with no problems. Did my first VE learn drive today and we'll do some more before I start messing with timing. Now it's time to dial her in!
Old Sep 4, 2022 | 09:58 PM
  #4992
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
I just drove on the 2nd VE learn and i have to say she drives just amazing. Shifting up and down the gears is just better than i can ever remember. Any insight on tuning as far as fuel and advance? she's set to 50 psi right now and the whole tune is of course set around that number. If I start dropping pressure to see if she likes it does that mean I have to re write all those tables just to see if its a step in the right direction? Also, are we talking about tiny gains for the race track or can I expect gains I'll feel in the seat? I'm not chasing quarter mile times but I want 100% of what she has to offer. That being said I dont want to spend the weekend gaining 3 hp to the rear wheels. Sorry for the noob questions.
Old Sep 6, 2022 | 09:05 PM
  #4993
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
So she idles a bit rough and runs pretty rich, shows 128/128 but starts maybe 9 AFR then slowly climbs until, bingo 14:7 and seems to clean up the smog instantly. I did check the open loop idle back on. Is this normal With the .480 lift cam and 1:6 rockers?
Old Sep 8, 2022 | 08:31 PM
  #4994
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
she seems to run great. Upon initial accel almost feels like a dead pedal until about 3k then starts to go. I'm going to start messing with fuel pressure. Any ideas or setttings I'm missing? Something under AE I can try? "IAC opening fuel"? what is that for?
Old Sep 8, 2022 | 09:59 PM
  #4995
is this wot ir heavy accel only? What's the afr in such state? Add fuel if it seems to need it. Any spatk knock in those areas? Add or subtract timing as it deems. Don't make huge changes, just make judgments based on what it's doing. You can always go back to what it was or change a little more till it feels right.
Old Sep 9, 2022 | 08:11 AM
  #4996
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
mostly notice when hard accel in a high gear, as rpm increases seems to pickup. The O2 seems to always be close to 1 V cruising, when i hit it she is almost always around 9 afr. After cruising a bit gets back to 14/7 and the BLM and INT GET TO 128 and stay as long as I don't stab it. Was going to drop some fuel pressure tonight, no signs of knocking anywhere.
Old Sep 9, 2022 | 08:56 PM
  #4997
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
So thanks again for answering me. I dropped the fuel pressure to 45 from 48ish. Def seems to like that. stays right around 14.7 and 128 when I can glance over at the laptop. I may try for 43-44 and then change the tables around the fuel pressure. Here's a dumb question, how do i play with timing? The dist is set to 6 as well as the ebl scalar. Do I just move it the old fashioned way little at a time? or with the SA table? Thanks again, I appreciate everything.
Old Sep 10, 2022 | 09:21 AM
  #4998
use the sa table. That way you can add spark where it wants it and keep it down where it doesn't need it. Like peak torque tends to like a little less timing.
Old Sep 10, 2022 | 11:48 AM
  #4999
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Just got back from a long cruise, I can't believe there is no knock counts at all. I'll try timing next and report. Thanks again.
Old Sep 10, 2022 | 09:57 PM
  #5000
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
So I applied -1 offset to the SA from 2000 to 3200(peak torque?) up to 80 kpa. Definitely seemed to like it but it could be in my head. Is this the way I should be going about it? Keep dropping a degree and see how she feels, focusing on this area? Then when I feel loss of power bump back up where I was last? Then pretty much do the same in the other direction going up the rpm range to around 5k? Don't think the tpi has much after that.
