Tuning with the EBL
Old May 28, 2023 | 05:57 AM
  #5051
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tuning with the EBL
Need to increase the VE% where it is lean. Should also verify that the fuel pressure is holding.
With little headroom left in the VE table, increase the BPC - BPC vs VAC table by 15%, and reduce the VE tables by the same 15%. Continue on.
RBob.
Old May 28, 2023 | 10:11 AM
  #5052
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
The BPC - BPC vs VAC was set at 158. So I add 15% and should change it all to 182?
Do I then subtract 15% from both High and Low VE tables?
Old May 28, 2023 | 02:38 PM
  #5053
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I increased the BPC - BPC vs VAC by 15%. Wow that got the fuel into it up top. Wot pulls up to 5500 rpm were showing mid/high 12s afr. I didn't touch any of the ve tables yet. It's idling Rich around 13 but also not dipping or surging.
I was going to do some more logging and SA changes but my passenger collector bolts fell out creating a big exhaust leak.
Old May 28, 2023 | 05:27 PM
  #5054
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, ...
RBob.
Old Jun 2, 2023 | 09:21 AM
  #5055
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
The SA - Main Table values indicate a timing value. Are those values the final total timing? Or does those values get added to the base 10 degrees to form the final total timing?
ie; the SA - Main table shows 21 degrees at 3600 rpm. Is 10 degrees initial added for a combined 31 degrees at 3600 rpm?
For my tune I am running the vortec spark tables with the AFR 195 enforcer heads. I think along the way I read that the vortec timing was a good one to run. But now I am not sure. At WOT I am only going to get 30 degrees of total timing. Seems low.
Old Jun 2, 2023 | 10:27 AM
  #5056
RBob's Avatar
Car: check
Engine: check
Transmission: check
The SA - Initial SA value gets subtracted out within the ECM. With the physical position of the distributor adding it back in.
Another tip, the SA value shown via the WUD is the at-crank timing. Can use a timing light to check this if need be.
RBob.
Old Jun 3, 2023 | 06:17 PM
  #5057
Rainmaster's Avatar
Car: 1987 GTA
Engine: LB9
Axle/Gears: 10 bolt 3.23
Alright I've done some more BLM VE learns and got my low speed table to be pretty smooth aside from a bowl around the low rpm / high map area. Not really sure what I can do to get coverage there on my learns since I have a 700R4 and cannot force high loads at those rpms easily.
I am also now having an issue where turning the A/C on while the engine is idling causes it to stall every time. Seems to happen both in closed loop and open loop. I have also had the engine stall after I turned off the A/C after it had already been running and I went to park the car.
It is just an 87 LB9 with an intake and exhaust. I am not sure why it is struggling so much at idle. I am attaching a short datalog that shows the stall in both open and closed loop and the bin I am using.
File Type: zip
Old Jun 4, 2023 | 11:43 AM
  #5058
RBob's Avatar
Car: check
Engine: check
Transmission: check
According to the WB the engine is idling too lean.
RBob.
Old Jun 4, 2023 | 07:15 PM
  #5059
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
A question about the VE learns with a WB.
With the closed loop cts threshold changed to 150c and the ccp vacuum line plugged I, I've been doing ve learns.
I noticed in open loop the cAFR varries depending on driving. I'm talking about easy stoplight driving no wot or heavy throttle.
If the cAFR is changing, how does the ve learn properly work?
The tune seems to get the ve close, but then back in closed loop operations, the blms are varying from 128 at idle down to 120 or lower.
I'm also having the same problem as a poster a few above. I have the data sheet for my wideband, entered the data as per, but the WB gauge readout and the WUD display are off by half to 1 full point. And it's not linier, say at 13:1 it's showing 13.1-13.3, but at 14.7 its showing 15.5.
Old Jun 5, 2023 | 06:17 AM
  #5060
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the WB data being seen by the ECM is bad, then the VE Learns will be bad. Garbage-in, garbage-out.
RBob.
Old Jun 5, 2023 | 08:27 AM
  #5061
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
This is what I have programmed into WUD.
This is the AEM WB data. I have the gauge wired in as follows: BLK to car ground. RED to switched 12v. White signal analog + to EBL FLASH II. 3 wires, that is how it was hooked up to the stock ECM. Perhaps I do not have it wired correctly?
Old Jun 5, 2023 | 11:49 AM
  #5062
RBob's Avatar
Car: check
Engine: check
Transmission: check
Connect the brown analog wire to the EBL ECM GND terminal (left two most are GND, on the EBL Flash-II).
Be sure that you selected the user device that you created. Along with the correct ADC channel (WUD preferences).
See if it is better. If not then measure the voltage output from the WB controller and see if it matches the gauge AFR.
RBob.
Old Jun 5, 2023 | 02:05 PM
  #5063
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I had it wired as stated in the instructions as the least desired option. I connected the brown analog wire to the EBL ECM GND terminal. The WUD display and the WB gauge now appear to display the same information.
Old Jun 5, 2023 | 02:35 PM
  #5064
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I would also like to understand how the VE learns in open loop.
While in open loop doing VE learns the cAFR moves around due to the Open Loop - AFR vs RPM & VAC. Goes anywhere from 12.8-15.3 according to that table.
Back in Closed Loop if the target for street cruising is 14.7, isn't the ECM going to have to make lots of changes to the BLMs trying to get the AFR close to 14.7?
Maybe this is correct, but its leaving me too lean now. Here is a log of cruising around with a couple WOT at the end.
File Type: zip
Old Jun 5, 2023 | 03:05 PM
  #5065
RBob's Avatar
Car: check
Engine: check
Transmission: check
Easy, in open loop via a WB learn, the WUD compares the cAFR to the WB reported AFR and adjusts from there.
In closed loop the WUD just uses the BLM value.
When doing VE Learns, easy on the go-pedal. Hold it steady at various RPM & load areas. But hold the pedal steady.
RBob.
Old Jun 5, 2023 | 03:10 PM
  #5066
Larry's Avatar
Car: 86 Corvette
I used these settings to get the gauge and EBL to report the same.
Old Jun 5, 2023 | 03:32 PM
  #5067
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I am very new when it comes to tuning and understanding how things work. Is what I think correct? The VE learns gets the VE tables close so that cAFR and actual AFR pretty much match. Then once back in closed loop the BLMs move around to add or subtract fuel to get the AFR to match the cAFR depending on what is happening, ie, idle, varying cruise etc?
So how come after VE learning and back in closed loop I steady cruise at 15.4-16.2? (not in highway mode) Shouldn't the ECM be adding fuel to bring that to 14.7? Am I missing something in the procedure?
Old Jun 6, 2023 | 05:24 AM
  #5068
RBob's Avatar
Car: check
Engine: check
Transmission: check
Lots of good reading can be found here:
https://www.thirdgen.org/forums/diy-...uide-book.html
A smattering of fueling threads from that thread:
https://www.thirdgen.org/forums/diy-...-contants.html
https://www.thirdgen.org/forums/diy-...ng-points.html
https://www.thirdgen.org/forums/diy-...d-voltage.html
RBob.
Old Jun 6, 2023 | 08:04 AM
  #5069
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
That is some good information. My answer came from a old post of yours in the R/L threshold voltage thread.
Today's focus, now that I understand fueling a bit better is to settle on a spark advance table. I've been using the table that somes in the bin for 5.7 TPI auto.
The part throttle SA looks fine to me, but that SA at 90-95 kpa (where WOT is happening) is jagged, uneven, and reduces as RPMs go up.
I've been trying to look at other SA tables to get an idea of what they should look like. I've seen examples that are nice and smooth and increase until a total of about 34-36 then plateau until redline.
The '113 SA table does that, but is still jagged in places. Ive also seen people mention using the LT1 or LT4 tables.
My combo is 383", AFR 195 enforcer heads, Edelbrock pro Flo xt 4 intake, comp 08-502-8 cam, 700r4 3.23 gears.
Old Jun 6, 2023 | 12:24 PM
  #5070
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
So I'm wanting to do a TPI swap on my 92 K1500. It doesn't have an IAT sensor stock and I'd like to add one. How would I go about doing this?
Old Jun 6, 2023 | 03:38 PM
  #5071
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
are you deleting the egr ? That would free up a wire for mat.
Old Jun 6, 2023 | 03:49 PM
  #5072
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I've moved on to the SA tables now.
I was using the timing table that came with the 5.7L TPI Auto bin but wanted something with more linear advance. Instead of reworking that one I used the Building Spark Advance Table excel spreadsheet. I put in that I wanted 34 degrees maximum advance and Limit to Maximum Advance above this kPa: 90. I used 90 kPa there because I am focused on max WOT performance, and 90-94 kPa is where it holds at WOT.
Car runs great with the new table. No knocks at all, which is both good and worrying. When I built the engine I used a new knock sensor. The WUD shows knock counts at engine shutdown, so I guess it is functioning?
Anyways I went from this:
To this:
Old Jun 14, 2023 | 06:18 PM
  #5073
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Originally Posted by gibbles
I'm having an issue with hot restarts.
Pretty much if I shut off the car when it's something around 220F and come back 20 or 30min later, the car acts like it's flooding.
Cold starts are fine...
Starting the car while watching with a wideband O2, it shows a pretty rich fuel mixture and it runs a little rough for a bit, sometimes stalling.
Sometimes I need to crank for a while, flooring the pedal in hopes of clearing the flood.
I'm using most of the values from the 3001 bin..
Details that might matter, CFI injection, renegade intake that's been ported slightly, edlebrock heads (70cc), aremotive fpr with the vacuum reference connected to the intake, and 80lb injectors.
long tube Headers, dual 3in exhaust, 84 vette.
One thing I have not done, was to check the cts at key on...
Increase the cranking AFR at the engine temperature where this occurs. Can also reduce the choke AFR in the same temperature area. Choke is really after-start fuel that is added for a short period of time.
RBob.
Originally Posted by Dominic Sorresso
RBob,
Could u clarify what u direction u mean by increasing AFR or reducing AFR.
Does INCREASE mean Richer, reduce mean LEANER? Just to be clear.
The cranking AFR is actual commanded AFR. So increasing it is leaner.
The choke AFR is a value that is subtracted from the commanded AFR. So reducing it makes the final commanded AFR leaner (less is subtracted out).
RBob.
I'm having about the same hot start issues as above. I have a miniram style mpi intake system though and the ebl flash 2.
After shutting off the car when the engine is 200 degrees and going into a store and coming back out 10 minutes later, the car cranks and starts pretty fast, no extended cranking, but then the RPMs fall and it stalls. No surging or anything just starts then stalls. It will do this until I start the engine then hold the RPMs around 2000 for 5 seconds or so, then it will idle on it's own.
Does the above quoted information pertain to my issue? Is there something else I should look at?
Old Jun 15, 2023 | 06:14 AM
  #5074
RBob's Avatar
Car: check
Engine: check
Transmission: check
Where is the IAT/MAT located? Is it heat soaking...
RBob.
Old Jun 15, 2023 | 08:00 AM
  #5075
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
It is screwed into the intake plenum. I'll check a log to see, but I think I recall seeing the temp matching the coolant temp after sitting.
*I just drove around up to temp. Shut it off for 20 minutes. Came out. Coolant was 196 and MAT was 173 buy it fired up with no issues. Lol.
Old Jun 15, 2023 | 04:38 PM
  #5076
RBob's Avatar
Car: check
Engine: check
Transmission: check
The EBL system is expecting an IAT, not a MAT sensor. Grab a birdcage style IAT sensor (grommet or threaded, doesn't matter), and mount/locate it where it best reports the incoming engine air temperature. Where isn't always in the air induction system.
RBob.
Old Jun 15, 2023 | 05:38 PM
  #5077
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
Other than the visual difference between a IAT and MAT, what is functionally different? As for placement, I've seen that V6 cars have a provision for the sensor right in the air filter intake duct. Would that be a better spot?
As for the birdcage IAT sensor, I've seen threaded, but not grommet. Any part numbers?
Old Jun 15, 2023 | 05:57 PM
  #5078
RBob's Avatar
Car: check
Engine: check
Transmission: check
Uh, one reports the intake manifold temperature. The other reports the incoming air temperature.
And here is something that will throw a huge curve ball into this. Many times I've mounted an IAT where it isn't even in the incoming air stream. But behind the grill, off to the side/front under the hood. As I posted, it needs to report the best incoming air temperature. I have lots of posts on this.
No, it is over the radiator and will heat soak at key off.
A '92 TBI Camaro/Firebird uses a grommet mounted sensor. Same as the '93 - '94 LT1 and others, and use a smaller different one. Many '94+ trucks also used one. I rarely buy new, rather hit the JYs and just pull sensors. Can't go wrong with GM stuff. And it is easy to test.
RBob.
Old Jun 15, 2023 | 06:57 PM
  #5079
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
If I change to a IAT and relocate it out of the intake manifold, will changes to the VE tables be needed?
Old Jun 20, 2023 | 01:50 PM
  #5080
drive it's Avatar
OK, what happened?! I programmed bank 0, with verify and set active. Now it's stuck in program mode with fans on. It was working fine-is it something stupid I did? How can I clear it? I've tried about everything from disconnect the battery to read program other banks etc.
Update- every time before when programming a bank-fans on until after program done then back to normal. This time it "stuck". Went back to try again-programmed bank 0 and same. Then went to bank select, changed banks and it cleared. Able to go back to bank 0 no problem. The engine isn't back together yet so I can't run it but all monitors on the WUD look good now as opposed to reading at zero before.
So what happened? I was going to try to "update" the ebl again but that failed, then the above worked.
RBob-I emailed you along with posting here. Thanks for any insight.
Further update-been trying everything going kind of crazy. It appears that when I read the most recent bin from bank 0 and then changed C.I. injector data etc. then reprogrammed it into bank 0 it got corrupted-don't know how. I tried a bin from the laptop from an earlier edit instead of trying to read the bins from the ebl and it all works as supposed to. It did sit for 10 years with no power to it before I got back to the car so I'm not sure if that had anything to do with it.
Old Jun 21, 2023 | 09:10 AM
  #5081
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check and make sure that the EBL P4 board is fully seated into the MEMCAL socket. It can at times take some force to do so.
If it is, the ECM then likely died. Common for the '7730 units.
RBob.
Old Jun 21, 2023 | 02:53 PM
  #5082
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I got the sensor and mounted it in the driver's fender space. Reads about 100 degrees less than coolant temp. Still getting heat soaked though. Will have to move it again.
Old Jun 26, 2023 | 09:57 AM
  #5083
DrPockets's Avatar
Car: 1988 Chevy G20 Van
Engine: 355
Transmission: TH400
Finally had some time this weekend to install Flash II in my van and did 4 or 5 VE learns and I have to say, this is a truly incredible setup, RBob. Really really impressed.
Running better than it ever has.
I feel like I've been catapulted into the 21st century. Bravo.
Old Jul 15, 2023 | 01:17 PM
  #5084
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Doing a VE learn from a datalog... I have never done it that way before.
When doing a VE learn from a datalog, do I still disable closed loop and plug CCP, etc?
Old Aug 4, 2023 | 08:27 AM
  #5085
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Why not just tune your VE off of what the narrowband/wideband is telling you?
- Rob
Old Aug 4, 2023 | 08:36 AM
  #5086
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
- Rob
I just wanted to try something a different way I never ended up doing it from a data log.
Old Aug 4, 2023 | 08:42 AM
  #5087
The VE Learns are meant to get you in the right direction, but once you see your BLM is averaging stoich in a particular cell, you would then go into your editor and build your VE table around that one or two cells. Your stoichiometric value should never change once the cell you're working with is Learned, and if it does because of density, it is a very slight change that the ECM will of course correct for. When I tune for members, I only need an idle datalog for that reason... .
- Rob
Old Aug 4, 2023 | 08:59 AM
  #5088
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
- Rob
I've done some ve learns in OL but the problem I'm having is once the table is made and smoothed out, back in closed loop the BLM sits at 108 and INT in the low 120s indicating too rich. But if take more out of the VE table to lean it out it runs like crap, bucking, stumbling. So not sure where to go now.
Old Aug 4, 2023 | 10:14 AM
  #5089
ULTM8Z's Avatar
Are there O2 voltage rich/lean threshold tables?
in 8D on the 7730, i adjusted the target O2 voltages slightly rich allowing for a slightly richer VE table. The engine feels much more responsive during part throttle operation.
Old Aug 4, 2023 | 12:41 PM
  #5090
I would touch those areas depending on camshaft specs, especially if a member advanced the cam using the crank gear. A properly built engine with increased velocity from say a miniram would also benefit from tweaking that area, as AE would only be able to keep up with it so much before it bogs down, so the O2 thresholds are definitely a happy medium......
- Rob
Old Aug 5, 2023 | 09:56 AM
  #5091
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I am still researching the O2 rich/lean, and mean R/L tables. I came across a video of someone tuning on a crossfire and at the point I selected he talks about dialing in those voltage tables using the WB readings so that the BLMs and INT don't have to fight to keep stoich.
I'm not sure exactly how to do that though. Do I do get the readings in open loop, closed loop? On a datalog the O2 mv reading is all over the place.
Old Aug 5, 2023 | 10:46 AM
  #5092
ULTM8Z's Avatar
On mine, I did it in closed loop, but with the help of the WB.
Basically I started increasing the O2 voltages until the WB showed AFR's that the engine liked. At light throttle, I left it at stoich. But moderate throttle (below WOT and w/o engaging Power Enrich), it seems to like about 13.5:1. It also provides a more linear/seamless feel between non-PE and PE.
When I got the AFRs to where I wanted them, the BLM's of course were much lower than 128. So then I adjusted the VE table to bring things back to ~128.
Old Aug 7, 2023 | 10:37 AM
  #5093
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
When changing fueling tables in the EBL, does the ECM memory need reset each time? I come from Ford eec-iv tuning and when changes are made the KAM (keep alive memory) needs cleared so the long term fuel trims are cleared so the new tune changes are apparent instantly.
Does flashing a new bin override and reset the memory? That might be covered the the EBL write up buty quick look came up empty.
Old Aug 7, 2023 | 01:12 PM
  #5094
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the BLM key-on init values. The supplied BINs have them at 128.
BLM - Max/Min BLM at Key-on (init)
RBob.
Old Aug 7, 2023 | 01:23 PM
  #5095
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
All the bins I have modified off the 3005 have had the BLM - Max/Min BLM at Key-on (init) set to 128/128
Old Aug 7, 2023 | 02:39 PM
  #5096
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, so the long term fuel term, the BLM, gets reset back to 128, neutral at every key-on., You are good to go...
RBob.
Old Aug 8, 2023 | 04:55 PM
  #5097
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I did another VE learn and the BLM/INT are leveling about 126/130. Not perfect but closer. I'm not gonna chase that too much. I'll do another VE learn though.
But now at certain cruise speeds/RPMs it feels a bit rough, surges at that speed/rpm, (35mph/1400rpm). If I richen it up with the VE table in the cells it needs, won't the BLM/INT start moving around to try and lean it out? Is that fine to do and leave like that or is there some other way to do what I want?
Old Aug 8, 2023 | 06:35 PM
  #5098
RBob's Avatar
Car: check
Engine: check
Transmission: check
Make sure that the MPH threshold for lean cruise (highway mode) is higher then 35 MPH. Should be in the 50 - 55 MPH range. We had some BINs get set at 35 MPH, which doesn't work.
SA also plays a role, if the lean cruise is set OK, there may be too much SA.
Yes, the fuel trims will lean it out. They go by the O2 window table values.
RBob.
Old Aug 13, 2023 | 09:45 PM
  #5099
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I did a longer more comprehensive VE learn. It seems to drive pretty well. Cruising around at a steady speed the BLM/INT are now almost on 128/128. There are a few spots that the VE learn leaned out, but the engine wants more fuel in those cells. If I add the fuel then the blm/int are going to start fluctuating.
I want to know if I need to adjust the O2 voltage tables? One thing I see when driving is at times the WB is showing lean or rich and the O2 NB reading is always around 800-900 mv.
Would anyone look at this log and tell me if things are on the right track to where they need to be or if there is a obvious problem that needs addressing?
File Type: rar
Old Aug 13, 2023 | 10:30 PM
  #5100
ULTM8Z's Avatar
If the engine wants more fuel and you don't want the ECM to trim it back out with lower BLM's, then you have to increase the O2 voltage swing points. I have my swing point into the ~750mV range at high map in order to get WB reported AFR's the engine is happy with at non-PE heavy throttle conditions, and yet still have the BLM's hovering around 128.
