Got my 29C256 chips today from JDR
I cant wait to see how they work! I'll let everyone know how they work.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 5.7
Check out Truspeed
K... replying to my own topic here....
I burned my first flash prom tonite. It took a few tries as it wouldnt finish programming up to 7FFF for some reason. After about 3 tries it programmed it all. Put in the memcal and the car started right up with no SES light on
Changed the .bin file and simply reprogrammed it and it worked again! How simple! U dont even have to issue a separate erase command.. it automatically erases it while it programs! Very cool
Well, this would be my luck but I am having problems programming the flash proms. I get a programming error every time. I have tried probably a thousand times and just to make sure the programmer was working ok I burned a regular eprom and it did fine. I downloaded the new 3.6 fileprom.exe update, made sure everything is closed in windows except for fileprom and it still won't work! Any ideas?
David Tuschhoff
1991 RS Camaro M5
A SuperRammed, TPIS,
Ross, AFR, Scat, Crane,
CompCams induced 355!
My f-body page!
David Tuschhoff
1991 RS Camaro M5
My f-body page!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I don't know, we burned our first "flash prom" and it worked great the first time.
Don>>>
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Don>>>
'92 CAMARO RS
B4C Alt.
Mine did that too, then I remembered I had the programmer hooked up trough an exention cord, so I just plugged it in directly into the LPT1 port ont he computer. Now... it takes about 4-5 tires to program a chip fully. Sometimes it stops at 0200 or even at 7000. Sometimes I noticed it flashes on the second try. I dont know why this happens though :/ Really weird. Try to set your port type to Normail instead of EPP or ECP in your BIOS settings, and also try to do it from DOS instead of doing while being in a command prompt under Windows.
You did not mention this, so i thought i would throw this out @ you. have you tried more than one EEPROM? our burner @ work is tempermental with some lots & not with others, of the same flavor.
if so have you tried to program all 0's to see if it will take it?
just a few ideas.
BW
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
just a few ideas.
BW
Bob Wooten
Programmer is connected straight to the printer port with no extension. I have only tried one flash prom, will try another one tonight. I will also try it in only DOS to see what happens. Thanks for the tips guys! Hopefully I can get them to work.....as I am sick of erasing the eproms.
David Tuschhoff
1991 RS Camaro M5
My f-body page!
David Tuschhoff
1991 RS Camaro M5
My f-body page!
Tried programming in DOS only and it worked the very first time. Reprogrammed it about 10 times and it worked everytime. Whew!!! I also found that it's much faster to program. For anybody that is having problems with the Flash proms, try it in DOS only and it should work just fine.
David Tuschhoff
1991 RS Camaro M5
My f-body page!
David Tuschhoff
1991 RS Camaro M5
My f-body page!
Car: Death Mobile
Engine: 666 c.i.
I have found problems when using "Fileprom", but the DOS version "EPROM" always seems to work no matter what. I always recommend for people to use the DOS version "EPROM".
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've got the Windows version from Xtronics. Works great.
So far... I ordered my flash proms thursday, should be here monday.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
So far... I ordered my flash proms thursday, should be here monday.------------------
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
