speedometer
Old Mar 19, 2014 | 02:01 PM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
speedometer
My speedo isn't working all the other gauges work fine, its the orig gauges from when it was a v6 car is a 91, the p/o did an engine swap 350 and 350 trans as well,so I'm trying to figure out what it could be could the cable not have been hooked up,is it broken idk I took off most of the dash to get to it just don't know where to go from here?
Old Mar 19, 2014 | 02:03 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Look where it attaches to transmission. Or maybe the cable snapped or speedo gears are worn out.
Old Mar 19, 2014 | 02:32 PM
Car: firebird 91
Re: speedometer
Here are Pictures of speedo
Attached Thumbnails speedometer-securedownload-123_kindlephoto-735966.jpeg   speedometer-securedownload-123_kindlephoto-694419.jpeg   speedometer-securedownload-50_kindlephoto-636233.jpeg
Old Mar 19, 2014 | 02:52 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
It likely has nothing to do with the speedometer itself. I'd be looking at the cable from the transmission. Under the car.
Old Mar 19, 2014 | 07:51 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: speedometer
There is no "cable" , it's a wire , cause it is an electronic speedometer . It's highly likely that when this different engine and transmission was put in that the TH350 didn't have the needed electrical speedometer drive (and had one for the old cable driven setup) . I wouldn't even want to attempt a guess as to what's actually there or not now , much beyond the notion that a 91 firebird most certainly does (or in his case , did) have an electric speedo .
Old Mar 19, 2014 | 09:48 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Right. My bad. The cable was phased out in 89. The 90-92s were electric. Sorry.
Old Mar 20, 2014 | 06:49 AM
Car: firebird 91
Re: speedometer
So what are my options can anyone tell me like is there anyway to get it to work or and of not anyone kno where I can find a digital gauge online or different options of what I can do?? Thanks
Old Mar 21, 2014 | 04:52 AM
Car: firebird 91
Re: speedometer
Old Mar 21, 2014 | 05:04 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Re: speedometer
http://www.autometer.com/cat_accesso...l.aspx?vid=234
or make sure you've got one of these on your transmission, its what Im using
http://www.autometer.com/cat_accesso...l.aspx?vid=114
Old Mar 25, 2014 | 05:36 AM
Car: firebird 91
Re: speedometer
Is there a cable /speedo setup for the turbo 350 trans I can get idc if I have to mount the speedo??
Old Mar 28, 2014 | 12:07 PM
Car: firebird 91
Re: speedometer
Anyone out there erictheviking are you saying I need both or one or the other with your links.....and is thete a cable speedo setup that'll match up?????
Old Mar 28, 2014 | 12:14 PM
Car: '92 RS Camaro
Transmission: TH400
Re: speedometer
I'm using the adapter on my th400. It basically spins the unit like it would a cable, this is converted to an electronic signal which goes to the speedo. No cable involved. The gps just gives a signal straight to the speedo, again no cable involved
Old Mar 28, 2014 | 12:16 PM
Car: '92 RS Camaro
Transmission: TH400
Re: speedometer
Mine screws on the outlet where the cable would have been originally
Old Mar 28, 2014 | 12:19 PM
Car: firebird 91
Re: speedometer
I know I'm asking if I have to buy both adap nd gps if so there's gotta b a cheaper alternative than a$200 speedo
Old Mar 28, 2014 | 12:20 PM
Car: '92 RS Camaro
Transmission: TH400
Re: speedometer
Buy one or the other
Old Mar 28, 2014 | 01:25 PM
Car: firebird 91
Re: speedometer
Do you kno where I can find one that site doesn't carry it?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
