clutch safety switch removal
Old Mar 16, 2019 | 04:57 PM
2mnytys's Avatar
I have searched. How do you remove the switch from the bracket. It is in such a tight area you are almost working blind.
I am having the the no start just click then maybe the car will fire up.
This has has been going on for a while once in a while. But yesterday I had to get towed home.
Need to check the voltage.
1990 Gta 5 speed.
Old Mar 17, 2019 | 10:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: clutch safety switch removal
On the back of the NSS there is a small metal clip that prevents it from sliding out of the bracket. It is a small hole in the middle of the two larger holes, I believe. You need to push that in then the NSS will, slide up or down, out of the bracket.
Old Mar 18, 2019 | 10:14 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If it clicks, it most likely is not that switch.
More like the starter solenoid or ign. switch on the column.
Old Mar 18, 2019 | 10:32 AM
2mnytys's Avatar
Thanks Don
After much reading the last few days that is also what was mention.
Key on. Fuel pump, door chime and other noises are heard. Vats light on then off. Just clicks.
I'll have to get towed to a shop for the stater/solenoid replacement, I have no way to get it up high enough to work on that.
Bob
Old Mar 18, 2019 | 10:42 AM
2mnytys's Avatar
Thanks Scooter
I 'll try that. It is in a real difficult spot.
Old Mar 18, 2019 | 12:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Originally Posted by 2mnytys
Thanks Scooter
Yeah, it sucks. The switch design is also not really great.
When I did my T56 conversion I changed the path on this circuit. Since my car was auto, I left the "stock" wiring for the auto through the solenoid but I wanted a clutch safety switch. I was eliminating the VATS since I was going to an LS ECM and I was installing an aftermarket alarm. I used the NSS as a path to ground instead of the high current path like the manual transmission circuit. The alarm system is now my ground for the starter solenoid, and I have the NSS as an interrupt for that path. If the NSS isn't pressed with the alarm deactivated the car won't crank, just like GM did with the VATS. I think it is pretty slick, and the switch will likely never wear out. If this is your problem, you may want to consider doing something similar.
Old Mar 23, 2019 | 12:30 PM
2mnytys's Avatar
Well checked the safety switch. It has been bypassed sometime in the past. Opps.
Checked the VATS it is worked and the resistance is within nominal reading
Guess it is time to get the starter and solenoid changed. Not something I can do.
But I will be checking grounds first. My best friend from Seattle is coming down for a visit and volunteered to help.
Old Mar 30, 2019 | 10:29 AM
2mnytys's Avatar
delete and move
Old Apr 1, 2019 | 02:46 PM
yeud619's Avatar
Car: 84 Camaro and a 82 camaro
Engine: Both are 5.7 litters
Transmission: Both are manual transmission
Axle/Gears: Both 3.73
To get to the clutch switch is simple slide it off you will see when you get under it. I bypassed mine and still will not make a noise?
Old Apr 1, 2019 | 02:47 PM
yeud619's Avatar
I am not getting back power to the s part of my starter.???
julyburnsred16
Nov 28, 2016 10:27 PM
Akshay
Mar 5, 2003 09:08 PM
Akshay
Mar 5, 2003 04:05 PM
ede
Jan 1, 2002 09:27 PM
UVA3rdGen
Jun 12, 2001 11:29 PM
