frustrated over an oil dipstick tube
Old Apr 1, 2012 | 04:03 PM
PETERK's Avatar
Car: 2001 F150 SCREW; 92 Camaro RS
Engine: garage built 355
Axle/Gears: possi from Z28
I did a 350 swap to carb. The block that I got is a driverside dipstick. I read on some board that there is an internal dipstick "guide" bought it from Chevy went to put new upper tube some Mr gasket chrome thing for blocks up to 77 don't fit. So my question is does anyone know how to install internal dipstick guide and what actually fits this thing in regards to dipstick tubes. Any help appriciated thanx
Old Apr 1, 2012 | 04:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: frustrated over an oil dipstick tube
I bought the chrome Mr Gasket dipstick when I did my motor build in the late 90s. The chrome was so thick that it didn't fit. I had to file the crap out of it and it still isn't in all the way.
Old Apr 1, 2012 | 05:47 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
The internal one can be gently tapped down into the block until it stops.
Old Apr 1, 2012 | 11:59 PM
PETERK's Avatar
This one goes in from the top of the block first and the external one goes into it right? Or does it go in from the bottom which means I need to take the oil pan off?
Old Apr 2, 2012 | 06:58 AM
Edwardgp's Avatar
Engine: 454-350
The internal guide you tap gently down from the top unless there is all ready one in there. If there is on in there then just install the external one. The internal one is down in there quite a ways I don't know if you can see it.
Old Apr 2, 2012 | 08:22 AM
PETERK's Avatar
So there is a ridge to stop the internal one from going into the pan?
Old Apr 2, 2012 | 08:49 AM
PETERK's Avatar
And how important is it that its there?
Old Apr 2, 2012 | 06:24 PM
Edwardgp's Avatar
Engine: 454-350
Yes there is a ridge to stop it from going to far. What it helps with is giving you a nice clean line on your dip stick. Makes it a lot easier to read. Sorry took so long to get back to you just got off work.
Old Apr 2, 2012 | 06:55 PM
PETERK's Avatar
Thanks for all your help its now installed and my frustration is gone on this part of the project.
Old Apr 2, 2012 | 07:01 PM
Edwardgp's Avatar
Engine: 454-350
Great I am glad I was able to help you out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
gta892000
Aug 11, 2019 11:16 AM
BDR
Nov 7, 2015 03:05 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
