92 RS sidepipes?
Old Aug 2, 2007 | 04:25 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
92 RS sidepipes?
I have a 1992 25th anne rs, motor swap to a 2 bolt main 350. Other few minor things here and there. Ive come to a point where its bout time for me to do my exhaust, i currently have some hooker shorties coming in. My current issue is that I want to put side pipes on my car. However the shops that ive gone to have all told me that i would have no ground clearance to do it. Some have suggested raising the rear end a little bit using bigger tires and higher stiff suspension. Any suggestions?
Old Aug 2, 2007 | 05:13 PM
Stephen's Avatar
Car: 87 GTA
Re: 92 RS sidepipes?
Side pipes are barely possible with FX, but you will reduce your ground clearance, quite a bit. Pulling the FX will certainly help.
Old Aug 3, 2007 | 08:41 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Do you mean sidepipes like in the pic above, or a side exit infront of the rear tire(turnout)?? There is a HUGE difference. If you say sidepipe to an exhaust guy he will think Corvette/AC Cobra. Which not only looks like crap on a 3rd gen streeter------it'll leave a hell of a scar on yer leg if you're not careful If you want a turnout then thats what you need to tell the muffler shop.
Old Aug 3, 2007 | 05:14 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
I was looking actually for any suggestions at all :/ As for the pic above, If i do those pipes ill prolly end up fiberglassing a kit around it or something
Old Aug 3, 2007 | 06:59 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
I went to a shop 2 days ago asking if they could do exactly that and they said I couldn't have the side exit on the driver's side due to the huge beam going down the middle of the car--which pisses me off because I already have a set of 4th gen Z28 tips that would look brilliant right infront of the rear tire. Is there an aftermarket beam that's shorter without losing any strength? I REALLY want the side exit...my only other option is putting them in the middle in the rear. Kind of like this:
But using the Z28 rectangle tips and sitting right under the rear bumper--see attached pic on where I want them as an alternate to side exits.. Which means I may have to cut a bit of the "trunk" area. I also want to drop my car 1" in the front and 2" in the rear...which means I might have to be REAL careful about going over dips and speed bumps/humps if I have any exhaust piping hanging.
Old Aug 3, 2007 | 07:35 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
"the beam" do you mean the touq-arm
Yes there are many aftermarket options, I don't know where you all live but in Tx the law is the exaust has to exit past the passanger cabin. In a car thats all the was out the back over the axel, in a truck its just past the cab. Just something to look into or keep in mind. Its because the fumes will make you pass out, and any way you look at it you will have clearance issues, if not with the tip, the pipe itself.
Old Aug 3, 2007 | 09:06 PM
VonKaiser's Avatar
What about if you get some smaller or "oval" shaped piping? I live in TX like you do, but I could careless about the law--cops up here around the Dallas area mainly care about speeding and ricers racing to give a damn about checking for exhaust placement.
Old Aug 3, 2007 | 10:01 PM
Stephen's Avatar
Car: 87 GTA
The cops may not care, but come inspection time, the inspector SHOULD fail you with exhaust that doesn't exit the rear. Probably won't though.
On that 4th gen with the center tips, the exhaust is still routed like our, it just has a different muffler & tips in the back. That could easily done to a 3rd gen.
Old Aug 7, 2007 | 10:10 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
that exhaust shop is not up to par.... my car has true duals that could easily be converted to side exit. the ground clearance is low but i dont clip anything yet, the hooker 2210 longtubes go to 2.5" pipes that goes under the x-member. Its not really all that complicated
Old Aug 7, 2007 | 11:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
pics of mine on the appearance board in the camaro section show my exhaust dumping in front of each rear tire
Old Aug 8, 2007 | 04:48 PM
VonKaiser's Avatar
I couldn't find that post. Do you have a link?
Old Aug 8, 2007 | 05:37 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Spintech sells boom tubes. Its not a mufflered exhaust piece but it will sure be loud and sound freakin good. I would get the y-pipe with those shorties and then buy a chambered muffler from classicchambered.com or stainless, along with a boom tube from Spintech. Depending on what sound your looking for.. This set up with give you close to that gmmg sound. I thought about this setup and really looked into it. I ended up going with shorties, QTP E-cutout, and a magnaflow cat back. I love the sound of my magnaflow. Look into what i suggested. It shouldnt be too pricy. Good Luck!
Old Aug 8, 2007 | 07:43 PM
xpndbl3's Avatar
Car: 1984 Z28
funny how it was only 8 or so links down on the page....
https://www.thirdgen.org/forums/cama...cs-really.html
Old Aug 15, 2007 | 07:57 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
hey xpndbl what sizr rims are those?? and whatd you go for tires? do they hook up nice assuming ill be running about the same hp
WASyL
Jun 13, 2009 02:42 PM
83 MidniteZ
Feb 19, 2009 08:53 PM
Cammed Kitten
Jul 8, 2004 04:22 AM
silver89Rs
Jun 6, 2002 11:27 AM
NjCamaroCruiser
Mar 24, 2002 10:34 PM
