What kind of automotive-type stuff can I fab up w/ a 48" metal lathe?
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I guess the thread title just about covers it - my next-door neighbor showed up yesterday asking if I had room to store part or all of his 48" metal lathe for a year (long story). Said I could use it if I could get some good from it.
So, given this opportunity, I'm trying to make the most of it. So far, the only automotive-related stuff I can think of is bezel-type stuff, like around gauges, etc., but I know there's gotta be more that I can do.
Thoughts, comments, suggestions?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm not sure what the 48" refers to, depth of travel perhaps? But what's the maximum diameter you can throw in it?
A guy I worked with before, threw his wheels onto a lathe at work, to remove some curb rash.
I got a guy to make me a nifty shifter **** - piston like.
uhh, not much else coming to mind right now though. I'd rather have a mill, much more use for that.
Shoot, so much for making custom rims...
Car: 1982 Trans-Am
steering wheel?
turning brake discs
Making some slick custom center caps for your wheels
yea, not much really..?
turning brake discs
Car: 91 Red Sled
Wheel spacers or adaptors out of aluminum. Turn brake rotors depending on your tooling and autofeed options. Bore a throttle body, single with a 3 or 4 jaw chuck, complex throttle bodies can be bored with a 4 jaw chuck.
As crazy as this sounds, you can make your own racing muffler by making the end pieces. I did this for a race car but I wouldn't expect it to be done on a road car. Just giving you ideas.
YEa the list is endless, shifter ***** and a new shifter handle would be a good start for a beginner. Also aluminum would be the easiest to work with.
it sounds like a precision lathe with the 10" max. Too bad it wasnt a bigger one so you could polish the lip of your rims and stuff. That gets scary when you have a 18inch rim on a lathe spinning 500rpm...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i know this sounds lame, but 90% of what i would use it for is custom bushings and spacers.
for example, i needed a spacer thats 1/16" longer then what i had for my tubular front LCAs.... that was a total PITA to have someone else do.
with a lathe, i could have done it in a evening.
RSFreak
May 14, 2001 01:49 AM
