speedometer help please
Old Jun 13, 2012 | 06:32 PM
F!SH's Avatar
Long story short, 85 IROC, with an 85MPH speedometer. i bought a 145 speedo a few years ago, just now getting around to putting it in, this is what I found. Any help would be GREATLY appreciated
edited for clarity:
the speedo is out of the cluster, but the needle isnt at 0MPH, it's sitting around 50MPH
Old Jun 13, 2012 | 08:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer help please
Info about cluster and speedo removal below:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jun 13, 2012 | 08:57 PM
F!SH's Avatar
the cluster is removed, the gauge is removed, but the needle is stuck where it is. thats what im trying to fix
Old Jun 13, 2012 | 09:07 PM
JamesC's Avatar
You might have mentioned that up front .
EDIT: Ah, the pic. I see.
The needle should respond when you twist the speedo cable input on the backside of the head. If not, the gauge may be defective.
JamesC
Old Jun 13, 2012 | 09:46 PM
F!SH's Avatar
te speedometer needle moves when i turn the input at the back, but it never bottoms out to 0MPH. I have NO clue. and yes, i plan on doing the odometer roll swap and trip fix as per your write up
Old Jun 14, 2012 | 09:48 AM
JamesC's Avatar
Another thought: If the needle was ever removed (for whatever the reason) and stuck back on arbitrarily at, say, 50 mph, your issue could be accounted for.
JamesC
Old Jun 14, 2012 | 11:55 PM
F!SH's Avatar
Unfortunately thats not the case. It was fine (reading properly) before I put it in a box (while still in the cluster with the faceplate attached) a couple years ago. I'm just now getting around to putting it in, and thats how it was. i have absolutely no idea how it happened or how to fix it.
Old Jun 15, 2012 | 12:20 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I checked out one I had laying around.
It looks like there is a small copper colored spring just behind the faceplate that returns the needle. That may be what is broken.
There is also a larger black disk below that, and that should be attached to the needle directly, while the input shaft indirectly influences the black disk.
Old Jun 15, 2012 | 12:33 AM
F!SH's Avatar
Thanks! I wasn't too sure about tearin it apart because ! didnt want to break it even more. I will tear my old 85MPH speedo apart and look into that, and see about scavenging my old speedo to make the new one work
Old Jun 15, 2012 | 12:48 AM
Scorpner's Avatar
Engine: V6, V8
FYI, I didn't take mine apart, I just looked at it from the side. The spring looks pretty delicate like what you'd see in an old wind up watch.
Old Jun 16, 2012 | 01:13 PM
F!SH's Avatar
I loosened the faceplate enough to look behind the needle. The delicate looking copper spring appears to be intact. I removed the backhalf of the actaul speedo that holds the gears and whatnot to swap mileage rolls. It returned to 0. I'm thoroughly baffled at this point
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
