Dome Light bulb socket
Old Dec 20, 2021 | 06:33 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
So after searching and having no luck finding the plastic part of the dome light bulb holder I designed one very similar to OEM in cad and 3d printed it, The first one was 1:1 to OEM and would crack (actually exactly where my OEM one did) after heat cycling it several times. So I modified it and tweaked it through several iterations and finally have one that doesn't crack after heat cycling it with a bulb that is way too hot for the housing. I'm using a plastic that is heat resistant so it also will not melt with the overly hot bulb so it should be fine with the proper bulb or a LED.
Unfortunately the cost of material, electricity, etc adds up so If I sell these they will be $45 shipped. I'm not looking to start a business so it's very little profit if any, the screws, filament, electricity, shipping pretty much adds up to that. (you can't do this with standard PLA/ABS you need thermally annealed plastic.)
Thoughts on if anyone would buy it at this price? The final version will be going into my car tomorrow when I get the right size screws in (the ones holding this example together are shorter than my design specification)
Unfortunately the terminals are discontinued by delphi (part number 8911417) or I would sell them pre assembled, you will have to re use your existing terminals which should be ok. I have a few 8911418 (which has the wire crimp in the opposite direction but will work) and there are many GM cars that use these so they are something you can get used pretty easily, but this plastic part is always heat baked and brittle.
Below is the one I've been testing thermally etc, no finish sanding etc (its not a visible part).
How I've been heat cycling it, the entire assembly gets hotter than I can touch.
OEM part on the left, my part on the right, trying to source white screws but I figure again its hidden so probably doesn't matter.
With the proper bulb (the one I'm heat cycling with is much hotter)
Old Dec 21, 2021 | 06:04 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Dome Light bulb socket
Awesome job.
I would buy one of these.
Old Dec 27, 2021 | 12:00 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Install instructions.
Remove fuse or disconnect battery before starting.
Remove headliner enough to easily access the dome light.
Very carefully remove the old housing from the terminal. I am assuming if you are doing this the old bulb holder housing is in pieces so I chose to break it off the terminals on my remaining part. You may want to pull the clips holding the wires to give you more room.
Insert the existing socket terminal into the housing. Do not cut your existing wires if your terminals don't need replaced.
They will be a tight fit so use something hard and flat to push them in. Apply force on the thick area only and not the "wings" that extend out to mount them.
As you press it in you should hear a click when the retainer springs out when it's fully seated capturing it in place.
Once the clips are in make sure the retaining clips are capturing the terminal against the plastic.
When attaching the top plate make sure the wire is captured in the channel, also note the plate has additional support for the terminals, and the plastic part has a notch where the wire crimp is to allow those supports room to reach the terminal.
The 6 m3 screws should not extend past the plate. Note only hand tight is required using a Allen wrench, do not use a driver as it will likely strip the threads in the plastic parts. The end screws take the load the middle ones prevent it from warping if too hot of a bulb is used.
Reinstall it using the original screws with the studs. Don't over tighten it though. Test and let bulb cool and remove it if your headliner needs space some are real tight to the bulb.
Install the headliner and housing.
Install bulb and test
Install lens
Old Dec 27, 2021 | 01:56 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Stress testing the bending and flexible. It should easily hold up to it's designed use.
Old Dec 27, 2021 | 05:05 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
As packaged,
Old Feb 16, 2022 | 07:24 AM
michaelb5's Avatar
@Aviator857 - how do I order one? My existing assembly just crumbled.
Old Feb 16, 2022 | 09:28 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
https://www.ebay.com/itm/11594551233...mis&media=COPY
Sometimes when it relists it updates so if it says sold out, look at seller other items and you should see a new listing.
Old Feb 17, 2022 | 01:03 PM
michaelb5's Avatar
Thank you @Aviator857 !
Old Feb 25, 2022 | 10:41 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
BTW if you need the terminals and can't find them in a junkyard this harness can be adapted to the thridgen and it includes the terminals. I haven't tried it but the terminals other than having the wire go in the opposite direction do fit (I found a couple of New old stock terminals). Just note you are adapting it its not a direct replacement for the wiring.
https://www.americanautowire.com/sho...t-harness-6890
Or if you can find it the dorman 74324 light comes with terminals that should fit it also.
Old Jan 5, 2024 | 05:00 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Updated ebay listing:
Old Jan 5, 2024 | 07:27 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Thank you for making this. At just under $40 (right now) that is a very fair price.
Old Mar 9, 2025 | 05:03 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Updated link
https://www.ebay.com/itm/116513282438
Old Mar 11, 2025 | 02:32 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
^^^^This.
Good deal on making an otherwise unobtainable part available.
GLWS
Old Jul 28, 2025 | 01:55 AM
Fernando.larios's Avatar
where can I order the dome light
Old Jul 28, 2025 | 07:14 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I need one now as well. Anyone have the studs as well that the housing attaches too? I think all mine is kinda hurt!
Old Jul 28, 2025 | 07:31 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
https://ebay.us/m/onP0f3
Old Jul 28, 2025 | 07:59 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Ordered.
Old Jul 28, 2025 | 08:58 AM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
I'd highly recommend going to an LED bulb. You can double (triple?) the light output and the whole assembly still stays cool.
Old Aug 13, 2025 | 10:25 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I used an LED bulb. Only recommendation is a little how-to sheet in the orders.
I installed it, then looked on the eBay ad and looked through the pictures to figure out what I did wrong.
Now that it is installed I LOVE it. Highly recommended, but you need a little patience as tolerances are tight (in a good way)
Old Dec 1, 2025 | 12:48 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
It may need a little filing here and there as with 3d printing it isn't as precise as CNC and it's done within tight tolerance so it holds those clips well. But when I do tests every few batches I can put it together without sanding or filing.
I just upgraded my printer and am working out the new cost. This printer can print at 370c so I am testing some higher temp solutions that may remove some post processing requirements but the filament is more expensive. I am still material testing.
Old Dec 2, 2025 | 10:53 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I have created a facebook page around them as I've sold enough it will make communication easier.
https://www.facebook.com/profile.php?id=61584755152082
IROC-MIKE
Exterior Parts for Sale
Nov 7, 2021 12:01 PM
82Firebird5.0
Oct 24, 2019 01:06 AM
84 1LE
Feb 7, 2015 12:29 AM
84 1LE
Jan 11, 2015 10:57 AM
spr250
Jul 16, 2007 12:52 PM
