LS1 Carb
Car: camaro rs (a tru sleeper)
Transmission: turbo 350
LS1 Carb
hello 2 all thirdgen im jus wondering if any one has taken a ls1 block and carbed it....i really dont wanna do the fuel injection i want to bypass da computers vats and all.....and if anyone has done it give me some ideas on how to go about this project
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You have to get the LS1 carb intake and computer to run all of the timing and spark control. I think Edelbrock makes it.
Transmission: 4L80E/4L80E
I've seen a couple of magazine articles on it. Interestingly neither made as much power with the carb as it did with FI.
Car: 1987 GTA
This is true, the tuning capabilities of the carb just can't keep up with FI tuning where you can tune each cylinder individually, plus you lose the fuel milage as well
so you guys are basically saying that im betta off goin efi fuel injection...because right now im runnin a 1992 camaro rs...305 high performance engine with a 650 holley carb and a th350 no computer and if im going to drop an ls1 with a 6 six speed tranny i hav 2 hook all da computer stuff back up?????
Car: 1987 GTA
Basically, yes.
If you want to have the most out of an LS1, it needs to stay FI with all the little computer gadgets intact.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ls1 carbed here. running great.
runs stronger than any fuel injection ls1 ive been up against.
sure the gas milage isnt there, but im about going fast.
i get 13 in the summer beating on it, 18mpg in the winter if i baby it.
8" race converter and a th350.
cant complain.
good luck.
cant complain.
good luck.
if u hav ne pics please post because im really trying to build a ls1 carb i dont like computers really trying to stay away frum dat
Car: 1987 GTA
You still have a computer even with the carb setup. It has to have one to run the ignition using all of the sensors on the motor.
I know of a guy running an LS1 FI setup, that's running 6.0's in the 1/8th setup with a single turbo on the car, all computer controlled. Quite a few guys around here running low 7's and getting 26+ MPG with a FI setup as well and a couple of them are actually daily drivers.
cant complain.
good luck.
cant complain.
good luck.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
both get the job done.
Car: 1987 GTA
It would look like this
Using this
which uses these to control the timing curves
The drawback to going with this setup vs a FI setup is using the LS1 computer you can tune the spark and fuel for each individual cylinder to get the most HP out of it which yields a better running car, and the best economy you can get. As I stated, I know of a bunch of guys running in the low 7's using a FI setup with just a cam swap and no work done on the heads.
And to be honest, stock for stock, cost vs HP gains it really isn't worth it.
Using this
Car: '91 Firebird
Engine: 305 TBI
Re: LS1 Carb
You don't need a special tranny. I think you might just need a crank spacer depending on what trans and what year motor. Or you could just get a converter built to fit LS1 to Gen1 type trans. I've got a 2004 6.0 hooked to a TH350(using crank spacer and regular TH350 converter).
dbrochard
Sep 19, 2015 08:13 PM
so do u hav a computer runnin ur ignition system and do ne guys hav ne pics
