5.3 cam
Old Jun 22, 2011 | 08:37 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
5.3 cam
planning a 5.3 truck motor swap into a camaro
problem that i have is it needs a cam shaft
what would you guys recomend
Old Jun 22, 2011 | 10:15 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 5.3 cam
i put a few cams in a 5.3 that i had in a truck. 212-218-551-551-114---216-220-525-532-114---224-224-581-581-112--and finally 226-228-586-588-114+4 being the last.
the truth was i enjoyed the 216-220 the most.
Old Jun 23, 2011 | 07:08 AM
Guest
Guest
Posts: n/a
Re: 5.3 cam
Okay, now we need context. What else did you have with it? Headers? Ported heads? Torque Converter? Axle ratio? Rear tire size?
Except for lift, that's the same specs as one of the 2 cams I'm considering for my 5.3 into my '84 Camaro: http://www.summitracing.com/parts/TFS-30602001/
Which should work perfectly with these: http://sdparts.com/details/gm-perfor...parts/12499224
Old Jun 27, 2011 | 07:19 PM
Guest
Guest
Posts: n/a
Re: 5.3 cam
As he didn't get back to this, I sent a PM.
Here's what I got:
[/quote]
all i had done to the heads was a very slight cleanup at the ports on the intake. i had long tubes with carsound cats and a flo-pro muffler. axle ratio was 4.10. 2200 stall. with that cam i had a built 4l60e. i ran 13.98 in a 5150 pound silverado. cold air intake, electric fans, and a really good tune. it also had a really nice lope to it.[/quote]
That should about equal a 3.42:1 gear in a Camaro.
Old Jun 27, 2011 | 09:07 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 5.3 cam
wow i didnt see this one coming. it was a full bolt on 5.3 in a 5150 pound truck.
now how did we come up with a 3.42 in a camaro??
Old Jun 27, 2011 | 10:44 PM
Guest
Guest
Posts: n/a
Re: 5.3 cam
Fair enough. Since you didn't specify your tire size, I looked up the original tire sizes. 2WD was 245/70R17, which should be about 30.5". 4WD was 265/70R17, which should be about 31.6" Average, worn, is around 31"
Camaro tires are either 215/65R15, at 26", or 245/50R16, at 25.7", or 235/55R16, at 26.2", or 235/60R15, at 26.1" Average is about 26"
26" divided by 31" = 0.83871. That, times your 4.10, = 3.44
And since I'm using the 7.5 rather than the 9-bolt, the nearest gear is 3.42:1
Ain't math fun?
Old Jun 27, 2011 | 11:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: 5.3 cam
Maybe the HotCam for the LS engines?
Old Jun 28, 2011 | 04:41 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 5.3 cam
no it is not the hotcam for ls engines. it is a comp cam. i had 18 " wheels with nitto nt 404 285/50/18 street radial tires.
Old Jun 28, 2011 | 05:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Re: 5.3 cam
Huh? I was just adding a suggestion that the OP look into the HotCam from GM for the LS motors.
Old Jun 28, 2011 | 06:02 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 5.3 cam
must have read it wrong.
the 285/50/18 tires were 29.6 tall. with that math above it comes to a 3.67.
Old Jun 28, 2011 | 11:35 PM
Guest
Guest
Posts: n/a
Re: 5.3 cam
Cool, thanks. Close enough to 3.73:1 for my thinking. Basically, it just tells me that it was a fun combo with sporty gearing ( rather than economy gearing ).
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
