LY6 carnage
Old Jan 30, 2025 | 12:44 PM
  #351
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: LY6 carnage
I have been trying order DSE front control arms since black friday first company that had the best price was tick performance. So after about two weeks of not hearing anything I called to find out the order was on hold because they didn't want to honor the price and wanted me to pay extra so refund was issued. Next company to give me the run around was speedzone based in Florida. They had the next best price but after a few more weeks of back and forth emails of them saying they cant get into touch wirh anyone at DSE about the order I figured it was time to call dse for myself. They picked up the phone almost right away and checked on my order and say the arms are built and coated just waiting the bushings to get machined so they said a week tops. I emailed back speedzone and told them the good news only to have email me back the next day saying they are no long a DSE dealer and sent me a refund.
Since this years mission is front suspension im going to be doing most of the QA1 stuff and seeing if it holds up and hopefully offers a serious improvement on the autox and a road course as well this year if we can make that happen. Still need to order k-member and spring sliders asap..
Old Feb 1, 2025 | 08:51 AM
  #352
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Speedway sale saved me $180 and a week after I called in the order we got parts!
Old Feb 1, 2025 | 03:52 PM
  #353
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: LY6 carnage
I've got to order front end components also you think the QA1 parts will be as good quality as DSE? Keep us posted
Old Feb 2, 2025 | 10:15 AM
  #354
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
DSE parts are proven nobody can really question that. I got the QA1 struts and CC plates and now snowballed into their K-member and a-arms with the 850lb frame slider kit. What sold me was I heard or read that their was a slight geometry change with the frame sliders over the factory coil spring which to me means a chance at improved ride qualify and handling. So far all the parts I have received look great.
Old Feb 12, 2025 | 03:51 PM
  #355
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Just a quick little fit n finish check!! Very excited to get this in the car and see how it feels.
Old Feb 12, 2025 | 05:03 PM
  #356
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: LY6 carnage
Looks expensive lol. When I did my moly kmember and UMI lower front arms can’t say a huge improvement. A lot of room with the kmember tho. Def shave some weight tho.
Old Feb 12, 2025 | 11:49 PM
  #357
92BLKL98's Avatar
Re: LY6 carnage
They sure look good though. That may be the way I go. Do you think it is better than a coil over set up?
Old Feb 13, 2025 | 08:26 AM
  #358
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
For how I use my car this should be better than front coil overs. Adjusting ride height doesn't look as simple as the weight jacks but other than that its pretty impressive stuff.
And this k-member is lightweight 21.4 pounds that bare no mounts or bushings installed just straight out of the box.
Old Feb 13, 2025 | 09:31 AM
  #359
Car: 87 TA clone
Re: LY6 carnage
I bought Spohn coil overs and literally mocked them up on the car and sold them before even running them. I don't like the way the coil overs place the stress on the upper strut area. These cars front and rear suspension is designed to run the load/weight of the car in certain areas. Same reason I didn't go with coil overs in the rear as well. Weight jacks are better in my eyes. I haven't really had to touch the ride height either but I also don't race where constant adjustments are needed. Front weight jacks is a simple 1/2 extension on a 1/2 rachet and bobs your uncle.
Old Mar 26, 2025 | 11:25 AM
  #360
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
In the middle of buying my grandparents house so progress has been slow. I did get to weigh the koni strut vs the QA1 and the koni was 13lb vs QA1 7lb found that to be interesting.
Old Mar 26, 2025 | 01:07 PM
  #361
92BLKL98's Avatar
Re: LY6 carnage
Do you think this will give room for a low mount AC compressor. Living in the south AC is a nice thing to have.
Old Mar 26, 2025 | 09:05 PM
  #362
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
The best I can do is get you some pics after the install and hope its enough for you to go off of.
Old Apr 10, 2025 | 04:18 PM
  #363
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
K-member went on without any issues but engine mounts didn’t offer near enough adjustment to keep my motor in the same place best guess the qa1 stuff wants to set the engine back another 1” farther then my hooker mounts. I wasn’t in the mood to mess with all the headaches off moving the engine so I cut the engine plates off the posts at the weld and mounted and fit everything in the car and tacked the mounts back together and removed them to finish weld.
Old Apr 10, 2025 | 04:20 PM
  #364
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Missing a small part from qa1 for the springs sliders so waiting on that to come yet but it’s getting closer to being back together again.
Old Apr 11, 2025 | 09:01 PM
  #365
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LY6 carnage
This checks out as the hooker mounts intentionally move the motor forward an inch. Starting to come together...
Old Jan 30, 2026 | 10:39 AM
  #366
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Back for a winter update since this past summer was lost to mostly remodeling the house. Main winter mods will be ati dampener with a 9.45 lower pulley for more boost. I needed a trunnion upgrade so going to try the btr rocker arms as well. Other then that the exhaust is getting completely redone cause I think the dual 2.5 is a huge restriction at this time but it’s still in the planning stage at this point but it will be getting dual 3” valvetronic mufflers to tame the noise.
Old Jan 30, 2026 | 11:02 AM
  #367
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
BTR rockers are on next will be the dampener
Old Jan 30, 2026 | 11:05 AM
  #368
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Definitely nice finally having the garage done it needed a floor so got a cement mixer and 10,000 pounds later I have a floor.
Old Jan 30, 2026 | 11:21 AM
  #369
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LY6 carnage
Curious to what your plan is to mount those mufflers. I need something different for my dual 3" and I've though about something along these lines. I've never heard of this company before but these mufflers aren't too terribly large.
Old Jan 30, 2026 | 11:47 AM
  #370
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
I got a few ideas but most likely I will be doing something similar to my kit car build years ago. Which would involve cutting a few inches out of the bottom of the trunk if need be so they tuck up under the car.
Old Feb 3, 2026 | 12:24 PM
  #371
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
New lower installed just waiting on a new idler pulley and belt.
Old Feb 3, 2026 | 12:25 PM
  #372
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Just doing some test fitting for now but that driver side fits like a glove but not so much on the passenger side.
Old Feb 3, 2026 | 09:48 PM
  #373
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LY6 carnage
Very interesting. Patiently waiting for pics of final configuration.
Old Feb 5, 2026 | 01:42 PM
  #374
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Originally the plan was y-pipe into a 4” single then split it back to dual 3” at the axle but I found a deal yesterday on the speed engineering 4th gen kit. So that’s on the way and I’m heading to NY for the next few days. When I get back I plan to cut the bottom of the trunk out and go from there. Now does it need cut out probably not completely but it would need notched or even notch the passenger side spare tire wheel well area.
Old Feb 5, 2026 | 01:44 PM
  #375
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Basic rough idea of what I’m going for but with a different filter design and angle.
Old Feb 6, 2026 | 07:17 PM
  #376
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LY6 carnage
You'll for sure need a filter 2X or more the size of that one. I gained 13rwhp by swapping from a similar filter size to a massive K&N.
Old Feb 9, 2026 | 09:01 AM
  #377
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
13whp gain is huge thats awesome. Just me getting it outside of the engine area should hopefully get me a few extra hp. Goal is 750-800 whp but might be asking to much from the small cam.
Old Feb 25, 2026 | 10:37 AM
  #378
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Progress so far has been slow going but getting closer. I need to put in an order for some pipe bends to connect up to the headers. Center mounted exhaust is a serious option at this point.
Old May 10, 2026 | 11:16 AM
  #379
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Finally got to start this up with the new exhaust full installed. Still need to wire up the box to remotely open the valves but with the valves closed I’m extremely happy with the db level at idle so far.
Old May 10, 2026 | 01:36 PM
  #380
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Open and closed part 2.
Old May 21, 2026 | 06:09 PM
  #381
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Road test is complete and the results are very surprising and hard to believe. With the valves open the car is quieter than the old exhaust setup by alot and super quite closed to the point of it sounding like a stock car with a dynomax super turbo muffler.
Old May 21, 2026 | 07:42 PM
  #382
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Loving it!
I'd really like to see more of what you did with the Rear Cargo Compartment/ T-Top Compartment that you cut out for Exhaust clearance.
Old May 23, 2026 | 05:01 PM
  #383
NoEmissions84TA's Avatar
Re: LY6 carnage
Loving it!
Me too.
Old May 31, 2026 | 09:30 PM
  #384
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
I haven’t done to much else yet with the trunk cause of future plans. About have my air intake sorted out so that’s good news but have bad news also. I was out today for a test drive and smoked the clutch on a wot 3-4 gear hit. It held third perfect at the 60mph hit blew the tires off left a lot of rubber on the road but soon as I hit fourth gear the clutch gave up the ghost.
Old May 31, 2026 | 09:32 PM
  #385
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: LY6 carnage
Remind us what clutch you had? Thats hard to do on an initial run.
Old Jun 2, 2026 | 11:54 AM
  #386
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Clutch is a monster twin disk if I remember it was rated for 800w. Which is probably about what it’s making now just was hoping it could make it to the dyno and last for this year.
1GU809
Jan 18, 2013 11:25 AM
Mr. Notorious
Dec 6, 2010 12:58 PM
AlkyIROC
18
Jun 7, 2006 09:49 PM
TraviZ
Dec 29, 2005 12:14 AM
Maverick H1L
May 28, 2004 08:23 PM
