Getting around Emissions
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
Hola Everyone, maybe I'm missing it in my searches or I'm just dumb, but how are you guys with LS swaps getting around emissions? I'd like to run long tubes, but thinking this wont be an option. Don't want to pay 12k for the LS3 E Rod kit. I live in Colorado where emissions is required and this is my Camaro that I built back in 1995. Currently it has a TPI 5.7 with a Tremec trans. Really wanting to LS it with a T56. Thanks everyone!
COTM Editor
Received 1,880 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Getting around Emissions
People don't get around emissions testing. They live in areas where there is no emissions testing.
The following 5 users liked this post by QwkTrip:
JAYDUBB (03-30-2020), no new tires (01-17-2020), NoEmissions84TA (01-11-2020), scooter (01-12-2020), T.L. (01-11-2020)
Received 1,705 Likes
Not sure how that would be A Good Idea. Sure... we all want to escape the rules that we don't like, just, make them apply to everybody else, not us... but here's what they're designed to avoid. If YOU "get around" them, by whatever means, EVERYBODY ELSE will, or at least SHOULD, have the same option. After all, that's one of the principles of our legal system; the laws apply EQUALLY to EVERYBODY, and EVERYBODY has a vote in enacting them. (or more accurately, in choosing those who enact them)
This photo was from the 17th floor of a building in LA a few days ago, right near LAX on the Inglewood side, looking toward downtown. It's ALOT better than it used to be at this time of the year, fortunately. Not hard to see what happens when pollutants are allowed to flow unchecked.
That said, long tubes probably aren't an option for you, if what that means is, you order it off of Amazon or something. They probably would be if there were any you could buy that (a) retained all emissions features of the engine that you're swapping in, as it came; and (b) supported the remainder of the exhaust system as it came. IOW, there's nothing INHERENT about "long tubes" as such, that limits you. Only, long tubes that you can buy. So, get out of your "I'm special and deserve to be exempt from the rules that apply to everybody else" attitude, and design yourself up a set that will pass.
Engine: TPI 350
I'm not trying to skirt around emissions, maybe my title wasnt the best use of words. Have YOU or anyone else designed a set?? Just looking for ideas to keep it emissions legal.
Engine: TPI 350
Engine: TPI 350
Here in Ca., we have the BAR, maybe you folks do too?
Pretty simple, comply with the rules or "hot smog" it, and have to deal with it whenever inspection comes up.
So you know I'm not talking out my ear here, I'm working on a LT1 swap for my kid's '89, it will be smog compliant. Not that I think it's needed for the environment, I just don't want her to have hassles down the road.
When I moved back here a few years ago from AZ I inquired when getting my cars emissions that I had a swap candidate and the office said to car and talk with the site (lead, or head tester, some title like that) about what I'd need to do, but mentioned he was a car guy and loves talking about that stuff. This was at the Broomfield station.
Engine: TPI 350
Engine: TPI 350
Engine: TPI 350
So I finally got around to talk to the Broomfield Emission Tech Center. The contact there is Justin and their number is 303 404 0265. Talking with him he told me that swapping in any LS would basically be impossible to pass Colorado emissions. He was saying that the E-Rod kit that GM sells would qualify as it is EPA certified for any 1995 or older vehicle. Colorado needs form DR-2365 to pass emissions, and the E-Rod kit will get us this. Doesnt matter that some of our cars (at the oldest) are 38 years old, even with collector car plates we'd still have to pass emissions every 5 years. Cats have to be in the same position that they were in originally, and no check engine light. Hope this helps others out there.
https://risingsun4x4club.org/xf/thre...ir-care.22746/
https://www.jkowners.com/forum/modif...-colorado.html
Engine: TPI 350
interesting. I found these link below, seems to show how to get the dr-2365 form. Basically have to have all the emissions equipment that came originally with the swap donor. But I think I sent you to the wrong place; we need to talk to the tech center to evaluate and get the dr-2365.
Yes we would have to have all of the emissions equipment in place from the donor vehicle. He also told me that the ECM from the donor would have to match which transmission you decide to run (i.e. Auto trans needs Auto ECM). Not sure that really matters for us, but I thought it was worth mentioning..
