carb modded for a S/C?
Old Jun 30, 2005 | 08:14 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
i have plans on supercharging my other car and its carbed but i have a 750 double pumper carb on it, is there anything i need to do to this carb to have it setup for a blow through style supercharger? im only going to be running about 4-6psi(closer to 4) so i dont think itll put alot of pressure on the floats and such.
Old Jul 1, 2005 | 09:14 AM
KS91Z28's Avatar
You'll need solid floats and you'll need to cut off the choke tower.
Old Jul 1, 2005 | 06:50 PM
Car: 85 Camaro Z-28
Engine: 6.6
nothing other than that? i dont really want to cut my choke tower off. eh but if i have to i will, is it for even distribution? or do i just have to take the choke out?
Old Jul 1, 2005 | 07:18 PM
blown3rdgen's Avatar
http://www.hangar18fabrication.com/blowthru.html
From andrew slater/ swt racing
This is for more serious power levels.
This is what I did on previous 6psi set up- Mill choke horn, nitrophyl floats, few jets up in primary, 8-10 in secondary, bigger squirters to eliminate tip in stumble. This will at least get you started, then get a wide band o2 or dyno time.
Also don't forget about fuel pump and regulator.
Matt
Old Jul 1, 2005 | 10:07 PM
KS91Z28's Avatar
You have to mill the choke tower off in order to fit a carb hat on it.
Like blown3rdgen said, you'll have to increase your jet size also (about ten jet sizes or so).
Old Jul 1, 2005 | 11:03 PM
Car: 85 Camaro Z-28
Engine: 6.6
i deffinately have hood clearance so is there any way to get a taller carb hat? i know K+N makes one but that looks like it would be kind of short. do either of you have the PT# for the floats for the carb?
Old Jul 2, 2005 | 07:42 PM
part # from 1st page of link I posted......116-3
Hats--www.superiorairflow.com
I recommend the EV hat with a 1" spacer (o-ring seal)
Matt
Old Jul 2, 2005 | 08:28 PM
Car: 85 Camaro Z-28
Engine: 6.6
alright so with the o-ringed hat i wont need to cut the choke tower correct?
Old Jul 3, 2005 | 10:59 AM
BigL350's Avatar
No matter what hat you use, you'll still have to remove the choke as well as epoxy the hole for it's linkage. My car starts fine without a choke.
Old Jul 3, 2005 | 12:46 PM
Car: 85 Camaro Z-28
Engine: 6.6
Alright how about would i go of doing that? a machine shop would probably do it for $20 or so im guessing.
Old Jul 3, 2005 | 02:46 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
hack saw... well thats what somone did to mine
Old Jul 4, 2005 | 08:25 AM
machine shop or dremel w/ cut off wheel and grinder to smooth
Old Jul 4, 2005 | 02:02 PM
Car: 85 Camaro Z-28
Engine: 6.6
Alrgiht, thanks for the info guys! i know paxton makes a blow through S/C setup and it has a huge carb box that sits on top, i doubt you have to cut the choke tower for that style but it would probably be expensive for that box.
Old Jul 4, 2005 | 06:50 PM
KS91Z28's Avatar
Not to mention having to take the box apart every time you want to make a small adjustment.
Old Jul 4, 2005 | 10:44 PM
Car: 85 Camaro Z-28
Engine: 6.6
the way you say it, i take it its hard to take the box off....
Old Jul 4, 2005 | 10:52 PM
KS91Z28's Avatar
It's not hard, it's just a pain in the @ss to have to undo all the screws just to do something as simple as adjust the idle.
Old Jul 4, 2005 | 10:53 PM
Car: 85 Camaro Z-28
Engine: 6.6
do they sell the boxes seperately? or would it not even be worth it...
Old Jul 5, 2005 | 12:46 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i think the box is around 600$ from vortec (samething)... i think
Old Jul 12, 2005 | 05:51 PM
Car: 85 Camaro Z-28
Engine: 6.6
maybe i can find one cheap on e-bay, a box because i do not want to cut my box, i called summit's tech line and they said i dont have to cut it off with a box and i shouldnt have to block off my powervalves ect. just boost reference them and use the new floats and maybe a few other small things. so i dont know who to trust on this. he said he has some books he is sending me on how to do it. so i have those on the way.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
