Which sockish TBI intank fuel pump?
Old Apr 14, 2021 | 07:13 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im looking for a "stockish" intank TBI fuel pump. I don't need anything like a Walbro 255 or Areomotive 340.
I am currently running a carb and with a TPI pump and AFPR. I believe the pump has went bad and plan to replace it. The carb only needs 5 to 7 psi so a "stockish" TBI pump will work just fine. Reducing the pressure from 12-22 PSI with the TBI pump will be less taxing than the TPI pump at 45ish psi.
What brand/style pump has everyone had good luck with. Something that wont crap out in a few months or is loud.
AcDelco EP 386?
Delphi FE0115?
Other?
I know there are some counterfeit / branded pumps on the market. I have replace the pump before when I went TPI originally so I know its a fun job. Not looking to have to do it again because I didnt pick a good pump.
Old Apr 14, 2021 | 08:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Which sockish TBI intank fuel pump?
For your needs I'd stick to AC Delco.
Old Apr 14, 2021 | 08:36 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I was leaning towards the EP 386. I have read about people getting rebranded AC Delco pumps.
Any suggestions on a dependable supplier?
Rockauto?
Car ID?
Advance/Autozone?
Or just go with GM parts Direct?
Old Apr 14, 2021 | 08:43 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Any of those should suffice. People seem to get burned when they buy from Ebay.
Old Apr 14, 2021 | 08:48 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah you never know what you may get from Evilbay!
Thanks for the help.
Old Apr 14, 2021 | 11:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
AcDelco EP 386?
Delphi FE0115?
Other?
Limiting pressure of a TBI vs TPI pump is no more difficult with one pump of the other. As long as the flow is reasonable for the return line to handle the excess fuel it is not a problem. Restriction to flow is what builds pressure not the pump itself. I ran a 93 Astro 4.3 CPI pump which is the same one as a 96 Vortec truck on my G20 van for years. Still has the same Delphi pump as a matter of fact. It has fed a carb 305, a carb 350, a TBI 305 and a TBI 350 as well as a TPI 305 and a TPI 383 and now feeds a 450+ HP 8.1. That Delphi pump is the same one that GM shipped with the Ramjet 350 as well as the Ramjet 502 making 502 hp. At the 5-6 psi a carb requires it can support probably in excess of 700 hp. Volume goes up as pressure decreases.
Old Apr 15, 2021 | 07:08 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am running a return style FPR with the factory feed/return lines. I dont think the TPI pump was causing much of a spike, but the fuel pressure gauge is in the engine bay, so I can not verify while driving. My logic was since I may be replacing the pump, why not use the TBI version. Im sure the return line would not be a restriction for it.
If the factory feed/return lines would support a Walbro 255 (for example) while reducing the PSI down to 5-7, then I would go that route. If I ever switched to say Holley Sniper EFI, I would be set. It requires 60+ psi.
I am not planning on replacing the feed/return line.
If I'm wrong, as the meme says "change my mind". I'm open to suggestions.
Old Apr 17, 2021 | 09:40 PM
Sweatlock's Avatar
I don’t have personal experience with these but this is from a separate thread on pumps:Fuel pumps:
  • DELPHI FE0110 (good)
  • DENSO 9515014 (better)
  • DELPHI FS0177 / DENSO 9520094 are fuel tank strainers
Old Apr 29, 2021 | 06:13 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
ACdelco EP241 for a mild build
AC DELCO EP381 pumps for more punch.. both are direct bolt ins
Old Apr 30, 2021 | 06:54 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks,
I think I will go with the EP381. Should be more than enough for a Holley carb setup.
Old May 1, 2021 | 09:46 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Robert, not being a smarta**, but how would you define "mild" in this case? I know this isn't an exact science, but would, say, 300 be a reasonable threshold at which to make the jump from 241 to 381?
Old May 2, 2021 | 07:56 AM
I'd say yes
Evilokc
Sep 30, 2019 11:10 PM
Schurkey
Jul 2, 2018 10:36 AM
marcos beltran
Jun 27, 2010 02:12 PM
83Chevy_Camaro
Jun 29, 2006 11:43 AM
ausrs
Mar 4, 2001 08:36 PM
