Can someone tell me the weight of a t5 from a 91 firebird. I searched with no results
Old Apr 21, 2002 | 12:30 PM
Hulk0202's Avatar
I can find it any where. Thanks
Old Apr 21, 2002 | 12:34 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, I'm not sure but the 4spd from my '85 Stang probably weight around 75-100lbs maybe.
Old Apr 21, 2002 | 12:42 PM
poncho9789's Avatar
Should be about 85 pounds when full. they are easy to bench press into a car I can put it to you that way.
Old Apr 21, 2002 | 02:41 PM
Hulk0202's Avatar
Thats exactly what I wanted to know. I'll be doing it by myself. Thanks
Old Apr 21, 2002 | 05:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
if your working on the ground
I found a secret
Put the trans behind your head with your body at a 90 degree angle to the car.
Then raise up the tail housing and pull it on to your chest. With the main part of the trans on your right, roll over on to your right side and when you roll back pull the trans on to your chest.
You wont use all your strength b4 you get the trans to the point you can press it up to the car.
Old Apr 21, 2002 | 08:16 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
lol vee vant to pump you up!!:sillylol:
i got a better chance at getting pregnant than putting a tranny on my chest
Old Apr 21, 2002 | 08:23 PM
burnoutrpm's Avatar
i heard somewhere that a t-5 is about 100lbs. lighter than the 700r-4 slushbox.
Old Apr 21, 2002 | 11:13 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Yes, the T-5 tranny alone weighs about 80 lbs...
Not too hrad to bench press up into place. Why didn't I ever think of installing it like that ? I could never lift it up over my head Anyway, it is lighter than a 700R4 any day. Especially when you pull the tranny off and it comes down with the extra weight of the completely filled torque converter. However, I wouldn't call it 100 lbs heavier.
Old Apr 22, 2002 | 11:21 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
If you are gonna benchpress it into place, you better be able to do it quick, cause your arms fall asleep quick when you are under the car and your arms are in the air. Its not pretty to have something on your chest that you can't take off (I can tell you from experience).
Old Apr 22, 2002 | 12:19 PM
MikeS's Avatar
Um, yeah, it is not all that heavy. I mean, even I can carry one around and manipulate it to some degree under the car. Use a floor jack to support the weight of the tranny though. That will leave all of your strength to use for aligning it with the engine. Either way, be careful doing it completely alone. It sucks when you drop things on you and there's nobody there to yell at.
Old Apr 22, 2002 | 06:46 PM
Hulk0202's Avatar
If I couldnt lift an 80 pound tranny into my car, I woudnt be able to call myself a man.
Old Apr 23, 2002 | 06:20 AM
Blackened's Avatar
Riiiiiiiiiiiiiiiight... if you need to do THAT to call yourself a man then ... maaan (pun intended).. you got other issues! LOL
Old Apr 23, 2002 | 02:28 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
ive done it by myself numerous times.. the bench press technique is where its at and having a jack nearby to help hold it is also nice.. pretty much neccessary actually
and i believe the official weight difference between two exact same thirdgens one with an auto and one with a manual is like 104 pounds. I sure as hell believe it, the 700r4 weighs enough to barely be able to move around by yourself (like sliding and dragging on the floor)
you could play rugby with a t5
Old Apr 23, 2002 | 03:52 PM
Chronos_Titan's Avatar
The manuals are easy to bench into place. The 700R4 is a real pain to move around when it is full of fluid. Without any fluid it is a lot easier and the case is light as h_ll.
Old Apr 23, 2002 | 06:30 PM
Blackened's Avatar
LMAO !!!
Old Apr 24, 2002 | 10:49 AM
84TransAm's Avatar
Remember to watch your fingers when you pull out the tranny. I accidentally let if fall on my right index finger once on the way out, and once on the way in. This happened last April [hey a year ago!] and when I bend the finger it still snaps, took forever to get back to the straight position too.
Old Apr 24, 2002 | 12:23 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I weighed one empty the other day, it came out to approximately ~75lbs. Who would install one of these full??
Old Apr 24, 2002 | 02:21 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
no one with a brain
Old Apr 24, 2002 | 03:57 PM
Blackened's Avatar
Even 75 pounds is not super easy to maneuver under the car unless you got some serious muscles on you. I remember when I had to put the valve body out of my old 700R4 back in the tranny. After a few minutes of messing with it my hands started getting really tired. That valve body is made of cast iron and it can be pretty heavy when you're trying to hold it like a platter and put bolts in it at the same time. LOL
NORTz89
May 20, 2020 03:51 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
iroc22
19
Apr 23, 2003 12:19 AM
88redxtsy
Sep 10, 2002 03:28 PM
