car vibrates at 80 and above when cold
Old Nov 4, 2000 | 09:55 PM
chrisfrerick's Avatar
my car just began to vibrate at speeds at 80 and above when the car is cold. i shift it in netral and nothing changes. when the car warms up it is fine. any ideas?
Old Nov 5, 2000 | 02:20 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i wouldnt recommend going that fast when the engine is cold...that is unless you dont like your engine.
Rick
90 Camaro RS 305 TBI
400 on the way!!
Old Nov 5, 2000 | 01:35 PM
Vader's Avatar
Chris,
First, I'll add my vote to BB's. Why would you run that fast when the car is cold? not only does the engine oil have to be warmed to lubricate effectively, but the transmission and rear axle oils don't do very well until they have had a chance to warm up and get moving. Oil pressures in the transmission are exceptionally high with cold oil. Pistons are loose in their bores until they are at operating temperature, and oil that is supposed to splash/spurt up to piston pins and oil control rings isn't doing that until the engine is warmed. Lifters are not getting adequate flow, yada, yada...
Second, if you have nylon belted tires, the cold tires will have a "memorized" flat spot from where they were parked the night before. The tires don't get fully round until the tire carcass is warmed and pliable enough to flex a bit.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 5, 2000 | 05:06 PM
thats some excellant advice that i never really thought about. i live about a mile from the highway and i will sometimes travel at 80 if its not busy.
Old Nov 5, 2000 | 09:30 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm having the same problem at about 45+ MPH.
Could it possibly be a U-joint? I know I have one that's bad, and I think that's part of what's wrong with mine (It vibrates before 80 MPH though)
I also think my tires develop a bit of a flat spot after sitting, because it's sometimes worse after sitting a few days, and worse on blacktop. They're Firestone SH30's (I just hope the tread doesn't separate!)
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Old Nov 6, 2000 | 04:10 PM
JimBow's Avatar
My car also vibrates. If the vibration is in your seat it's either rear wheel balance of drive train. If it's in the steering wheel it's either front wheel balance or alingment. To test alingment let go of the wheel and lightly push the breaks it will pull either direction.
My problem is the drive shaft . I have a dent in mine. It really throws a lot of vibration at high speeds. I plan on putting on a 1LE drive shaft when I get the money. Good Luck Jim
[This message has been edited by JimBow (edited November 06, 2000).]
Old Nov 7, 2000 | 10:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JimBow,
I regularly sell used thirdgen alum shafts on this site. Unfortunely, I only have one one at the moment, and it's missing a balance weight, which means it would require balancing. In every other respect, it's quite nice. Should you or anyone else be interested, please e-mail me. $75 shipped, money order, certified check or PayPal.
JamesC
JamesC
Old Nov 7, 2000 | 11:35 AM
JimBow's Avatar
Thanks james, I priced new ones at Next Gen .com and they wanted 349.00 for a GM 1le shaft . I'll send you a E mail. Thanks
Terrell351
Jun 13, 2021 01:13 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
