strong smell of gas
Old Dec 31, 2003 | 09:13 AM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
strong smell of gas
I have noticed for quite some time when i got my car that there is always a strong smell of gas coming from the gas tank. I mean you can just walk past the back and smell gas. I thought well it is a gas tank so just blew it off. Now i cam kinda of concerned that it is still there. I don't see any leaks but wondering why the hell it smells like this?
Old Dec 31, 2003 | 10:09 AM
deb92rs's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Here's a simple test. The gas tank is under pressure (14 psi if I remember correctly), so drive it around for a while. Then unscrew the gas cap. There should be a hiss as the pressure is released. If not, I'd say there is a problem. I know there was a recall from Chevy regarding the 1992 Camaro fuel tank, it could also include the 1990.
It could be several things. The filler neck could be cracked, a faulty gasket, or a problem with the tank itself are a few possibilities. You should never smell gas and if you do, get it fixed ASAP. Its the fumes that ignite. Hope this helps.
Old Dec 31, 2003 | 10:30 AM
ede's Avatar
ede
could be a problem with the charcole canister too, it's supose to be a vent of sorts for the fuel system. sometimes they get saturated with fuel and quit working. give it a shake and you can hear the fuel in it if it's bad.
Old Dec 31, 2003 | 01:22 PM
Engine: 305 tbi
Transmission: t-5
Where might i find the charcole canister and how easy would it be to replace and how much? and should i look for anything else?
Old Dec 31, 2003 | 04:27 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Charcoal canister is under the hood... so I don't think that is your problem.
Unless I'm totally off in space land here... it is that canister under the hood that looks like an old fashioned coffee pot.
Old Dec 31, 2003 | 05:48 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I had this problem when I first bought my car. I got under there and the rubber hose coming off the tank had slipped off the tube. Apparently they didn't clamp this at the factory, its just slipped on.
Old Dec 31, 2003 | 06:41 PM
ssean92's Avatar
Car: sold
i had the same problem with my 92 rs, i called on the recall thing and they said that there wasnt any open claims, but from what a friend had told me is that the recalls drop off after 10yrs. so just by luck i got a parts car and was looking around under the car by the gas tank and noticed that there was a little (spinning top) looking thing attached to a line that was coming from the tank. Im not sure what u would call this filter but I took the one from the parts car and put it on my car and my gas smell has gone away, it also seems to have better pressure when i open the tank it fill it up. Can someone help and saying what the proper name is of the filter (spinning top looking thing). i just figured that i would let u know what i did to get rid of my strong gas smell. ssean92
Old Jan 1, 2004 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Someone correct me if I'm wrong, but I don't believe that recalls go away regardless of time, owner or miles.
JamesC
Old Mar 25, 2004 | 11:59 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
ssean, The Filter you are referring to is called a vent valve.
Old Mar 26, 2004 | 06:47 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
JamesC
According to the NHTSA, dealers no longer have to replace any parts in a recall free of charge after ten years.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
