high Oil Pressure
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
high Oil Pressure
Well The car has been sitting all winter and it doesn't look like I am gonna put her on the road this year because funds are low, gas prices are high, and i might as well get some cosmetic work done. I Did all the tune up work your supposed to do and when i started her up she ran like a dream.. until i glanced at the oil pressure guage, It was pegged. I varied the RPM's and even drove it around the neighborhood with no plates to see if i could get it to drop below 60 with no luck. It did vary somewhat but never below 60. What could be wrong?? I don't have the slightest idea, but maybe I'm just freakin out. Thanks for the help guys...
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
It could be a number of things, but the first thing I'd check would be the sending unit, it's located on the "china wall" on the back of the block. I'd also take one of the oil plugs out of the front of the block and put a mechanical oil gauge there, you can see your exact pressure, and it dosen't dampen any oil fluction like the eletric gauge dose, so you can see how good your bearings and the rest of the oil system is. (the more "jumping" it dose the more worn the engine is)
over 60psi may not be a problem. if you're worried about it you can check with a mechanical gauge and see what you really have. did you let the engine get up to operating temp? that may make the oil pressure drop.
Like ede said, first verify the problem by using a mechanical gauge. It only takes two things to create pressure, FLOW and RESTRICTION, so if the pressure is in fact HIGH, you would want to check the restrictions in the lube system..
Car: 1987 IROC-Z
Engine: Carbed 355
well checked it out with the mechanical gauge and all seemed fine so i replaced the sender (pain in the ***) and all is fine now. Thanks for your help guys.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah its not too big of a problem unless it reads zero ...lol....but too much can be something seriously wrong but glad it was only the sender bet that was a relief...
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Try putting a quart to tranny fluid in next time you change the oil. That will clean all the sludge and crap out of the oil passages and such.
ive heard of people doing that before but that always scares me im afraid of it damaging something ...
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
ive done it before. Didnt use a full quart, though. Seems to have done something...that may just be my mind playing silly games, though.
hesitant, yes. Thats why i only did like a 1/2 qt or so.
ambainb
Apr 25, 2016 09:21 PM
