Still getting crappy gas mileage...
Old Oct 30, 2004 | 12:30 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
OK, so right now my 305 TBI Firebird is pretty much stock. Won't stay like that for long though
Anyways, I have a new Edelbrock air filter on there...changed out the spark plugs and O2 sensor...yet I'm still getting awful gas mileage? I get maybe 18 or 19 on the highway, and maybe 14 driving it around a largely suburban area.
I know that an F-body with a V8 isn't going to give me stellar gas mileage, but I've heard that TBIs should be getting a little better than that..my friend with a highly modified 305 TBI (new cam and everything) gets 16mpg with a bad transmission...
Any suggestions of what else I should swap out?
Old Oct 30, 2004 | 01:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Maybe run some fuel system cleaner through it, that might help. Not sure what effect that would have on your new O2 sensor though.
Old Oct 30, 2004 | 05:52 PM
sellmanb's Avatar
Car: '86 Berlinetta
air filter, spark plugs and o2's and you got that good of gas mileage? I'm jealous! my carbed 305 got 14 after a full tune-up and was running smooth like-new.
You should do distributor cap, rotor, spark plug wires, oil/filter. Also, then complain about your gas mileage
Old Oct 30, 2004 | 06:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Ease off the loud pedal.
Old Oct 30, 2004 | 07:36 PM
sellmanb's Avatar
Car: '86 Berlinetta
loud pedal LMAO! Never heard it called that before.
Old Oct 30, 2004 | 08:29 PM
JungleMan's Avatar
Engine: L03 :(
Heh, well I have fuel injection, so I'm supposed to get better mileage than a carbed car...
I did spark plug wires (along with the spark plugs) and oil filter...my oil levels seem pretty good...didn't do distributor cap and rotor though...
But what's weird is that even after I did the spark plugs, wires, air filter, O2 sensor, etc...I didn't even see any increase at all in gas mileage? I figured with the air filter I'd pick up at least 1-2mpg.
Old Oct 30, 2004 | 08:44 PM
sellmanb's Avatar
Car: '86 Berlinetta
your coolant temperature sensor could be going bad, or you could have a leaky injector or two.
Or your lead foot gets in the way
Old Oct 31, 2004 | 01:46 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
maybe your friends car is geared for bettter milage. My friends Iroc with a 350TPI has 2.73 final drive and my firebird with a 2.8 has 3.42 final drive and I got only marginaly better than his because I have a smaller engine, so it needed more gearing to accelerate quicker where as his didnt cause it was faster from the fatory.
Old Oct 31, 2004 | 07:32 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Make sure your converter is not clogged, inspect your cap and rotor, stick a timing light on it. If you have many miles on the engine your timing chain has stretched, if nobody reset the timing EVER you could be running a few degrees retarded which will hurt your fuel economy.
Old Oct 31, 2004 | 12:17 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
My TBI car will avg. 22 MPG and get 28-31 on the hwy., but it's a 5-speed, make sure your timing is set correctly or even a few degrees advanced seems to make more power than the stock 0 setting.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
