Cam Breakin
Old 05-18-2005, 09:12 PM
89blackm's Avatar
Cam Breakin
Hey.....in the next few days my cam is going to be broken in. Will i need my exhaust on for backpressure or would it be fine just to do it with open headers????(Exhaust is true 3"duals going into 2 dynomax bullets dumped right before the axle)Id like to get a few opinions on this......thanks mike
Old 05-19-2005, 12:22 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You don't need backpressure... open exhaust manifolds or headers is fine.
Old 05-19-2005, 07:02 AM
ede
ede's Avatar
backpressure = monkey spank
Old 05-19-2005, 07:36 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: Cam Breakin
I tried to break in my cam with open headers.
The neighbor got pissed off and created problems I didn't need.
Old 05-19-2005, 06:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I tried breaking in my cam with open headers. It was loud as *** * and i had foot long flames shooting out of them. Its not cool, i would totally advise against it.
Old 05-19-2005, 06:39 PM
Air_Adam's Avatar
Originally posted by ME Leigh
I tired breaking in my cam with open headers. It was loud as **** and i had foot long flames shooting out of them. Its not cool i would totally advise against it.
True... but its not going to hurt the cam to break it in with open headers... just annoying as hell.
Old 05-19-2005, 07:01 PM
sellmanb's Avatar
Car: '86 Berlinetta
Use your manifolds. The heat from the cam breakin kills off the ceramic coating on the headers, which causes it to flake off, and then you lose out on the 200 for coating.
Old 05-19-2005, 09:26 PM
IHI
IHI's Avatar
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Not only that but it's nice when everything is as quite as can be so you can keep an ear out for any tell tale "bad noises"
Open headers sound cool, no doubt. But breaking in an engine sucks to do this way. Even with your bullets it wont be much better than open, but should still be a little quiter and easier for everybody around you to take.
Old 05-20-2005, 10:13 AM
89blackm's Avatar
Ok so it sounds like its not big deal then.Im not worried about the noise issue as they are annoyed with the car from last summer I was just worried about burning valves up or doing damage to the engine due to not having as much back pressure
Old 05-20-2005, 02:00 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You do not want back pressure. Back pressure is a restriction that reduces power. You do not want back pressure. The back pressure myth started back in the dark ages of engines, when people didn't know **** and the old timers that didn't know **** are still passing it on today. Damn old people!
Old 05-20-2005, 02:34 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
I've never heard of this, I guess you mean that keeping the engine at 1500 RPM or so for 20-30 min. will overheat the headers? Do you have any proof of this or did it just happen to you? I have ceramic coated headers but didn't need a break in cause it's a roller, one more good reason to run a roller I guess.
Old 05-20-2005, 09:13 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by AsphaltAssalter
I've never heard of this, ...Do you have any proof of this or did it just happen to you?
Most companies void their warranty explicitly for this. The problem is that most people do not have their timing and mixture dead on when breaking in new components.
89blkm... is the cam a roller by chance?
Old 05-20-2005, 09:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What Lucifer said.
If the mixture and/or ignition timing isn't dead on (and how can it be?) while breaking in the cam, a lean condition can cause the headers to glow red hot, literally.
I don't care how "good" ceramic coating is, it can't stand that much heat for very long.
Old 05-21-2005, 08:07 AM
89blackm's Avatar
No its not.......its comp cams xe-274 if u wanna check it out
Prodigious
Theoretical and Street Racing
35
04-13-2021 02:37 PM
Jorlain
10-08-2015 01:57 AM
customblackbird
10-01-2015 04:30 PM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: Cam Breakin
