Time to play! WHAT THE HELL IS THAT? Game
Old Jun 30, 2006 | 03:37 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
My car has always had starting problems these days it's turning on fine but very rarely does it it turn off after I crank it.. sometimes the idle is way low, anyway I recently discovered this wire that appears to be borken and ripped off something I dont know what it is!? or where it goes to, but I do know where it's coming from, it looks like its coming out of the STARTER harness but I can't seem to pin point where it connects too maybe you all could help me. Right now I just took some pictures and if you are all in the mood to play the game please be my guest and have fun while helping me! I would greatly appreciate any help in finding out where this wires connects too or if it is essential to my starting system or electrical system. Thanks everyone, here they are:
pleeease Help!
Old Jun 30, 2006 | 03:59 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
ill check on my RS and see ,mines flat black just like yours lol
Old Jun 30, 2006 | 06:19 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
cool thanks!
Old Jun 30, 2006 | 07:10 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Could be your knock sensor boot ..
Did you look to see if there was one on there??
appears to me that sucker snapped, but .. it could
also be the coolant fan switch sensor boot, they look
similar in design ..
Old Jun 30, 2006 | 07:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If that is a green wire with a white stripe (which it is), then that is your radiator cooling fan switch connector (which goes to the passenger side cylinder head between the 6 and 8 cylinders)...
Old Jun 30, 2006 | 07:45 PM
TPI's Avatar
Yea that is what I meant to say, Not coolant temp
The sensor on the head between 6 & 8, it has the same boot
style as the knock sensor down below .. Ill fix my mistake
Old Jun 30, 2006 | 08:08 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
so with this disconnected what will happend? what are the results of this boot being disconnected?
thirdgen88's Avatar
Car: 1995 Corvette
Your cooling fan will not engage automatically... It still might come on with the A/C, but not without..
Old Jun 30, 2006 | 08:13 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
as you can tell the AC has been removed, and the electric fas has been micky moused. Some jerk off who had it before me screwed it up and now the fan turns on as soon as I turn the key..... and stays on until the keys from the ignition are off
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mhatfield 14
Oct 24, 2015 07:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
