thread loc/ loc tite
Old Mar 21, 2007 | 11:50 AM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
what all should be threadlocked on a motr?
i think its red stuff for tranny ... (all i know is my brother used non, and broke a tranny in half.)
... and blue for things like accsesory and intake????
what about inside the engine?
This should be a reminder to all the new wrenchers out there.... use loc tite
Old Mar 21, 2007 | 12:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: thread loc/ loc tite
Intake bolts go into the water passages, so they need a thread sealer. Ditto for head bolts. Internal engine bolts need lubrication to get accurate torque readings. None of the bolts anywhere on the car "need" a locker.
Your brother's broken transmission was in no way a result of using any thread locker.
Old Mar 21, 2007 | 12:12 PM
Car: 91 formula ws6
i thought it holds the bolt tight from vibration?
I never use it on anything. Don't even own ANY of it.
i thought
OK.... and ... ???
Old Mar 21, 2007 | 12:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A properly torqued bolt doesn't loosen from vibration.
Old Mar 21, 2007 | 12:53 PM
Car: 91 formula ws6
k so is teflon tape better then?
Old Mar 21, 2007 | 01:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Teflon tape is for sealing tapered pipe threads.
Old Mar 21, 2007 | 01:33 PM
Best thing I've ever found for that is a WRENCH. Closely followed by a ratchet & socket.
Old Mar 21, 2007 | 05:05 PM
Vader's Avatar
Threadlock is recommended on torque converter bolts, and is required on some transmission bolts, like T56 shift housing to main housing bolts, 4L60E adapter bell bolts, and probably others I don't know about. You can usually spot those requiring threadlocker by the residue on the threads of the bolts as they are removed.
Old Mar 22, 2007 | 03:23 AM
ede's Avatar
ede
about all i use it for is oil pump bolt, converter bolts, and flyweel/flex plate bolts.
Old Mar 22, 2007 | 06:58 AM
Vader's Avatar
What the Metal Monkey was suggesting for head and intake bolts is a liquid thread sealant, not tape. Try something like this:
Old Apr 7, 2007 | 11:12 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
My torque converter bolts flew out, right into the starter. All three bolts had loctite on them originally, however it looks like maybe the one flying out didn't have quite enough.
So for some things, yes, use a tiny bit of loctite.
As for me, I'm just going to use a tiny tiny bit.
I'm waiting for the day when someone will use high temp loctite on valve covers and rocker arms
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Linson
Sep 21, 2015 01:08 PM
e3pres
Sep 9, 2015 01:51 PM
