new thumpr cam questions
Old Jun 22, 2009 | 12:54 PM
Floorman279's Avatar
im thinking about putting one of the 510 lift thumpr cams in my 88 in a few months when the rebuild starts, and i was just making sure on a few things. since its after 87, the 88 blocks have the OE hydralic roller cam correct? what does OE stand im not to sure?
Old Jun 22, 2009 | 02:10 PM
Guest
Guest
Posts: n/a
Re: new thumpr cam questions
Original Equipment.
What do you plan on for an intake?
Old Jun 25, 2009 | 02:14 PM
possibly mini ram
Old Jun 25, 2009 | 03:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why are you set on a Thumpr?
Old Jun 26, 2009 | 10:54 AM
because its a good performing hydraulic roller that sounds good and itseems like a good cam to go with. why any suggestions? also thinking about an XFI hydraulic roller also
Old Jun 26, 2009 | 12:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You would be better off with an XFI grind. Thumpr cams sound cool and love to spin high, but achieved by sacrificing all the "requirements" that EFI likes. The smaller versions could be tuned aggressivly enough to make them run, but the larger versions I would say are best left for carb platforms.
Old Jun 26, 2009 | 12:58 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
x2
Old Jun 27, 2009 | 01:44 PM
anybody have any good heads that work well with the xfi's? don't xfi's have a rough idle also?
Old Jun 27, 2009 | 05:33 PM
Guest
Guest
Posts: n/a
I have a 350 with the 280XFI and AFR 190's that flow a little more than the new 195 Eliminators. And a TPI
Anyway, if you can hear this file this is what it sounds like. If you cant, let me know and I'll see if I can find a different format. I must be missing something today, only found this way to save it as a sound file.
http://home.earthlink.net/~ctf89/GPrev1.mpa from about 4 years ago
http://home.earthlink.net/~chris.foster/GPNewTrans.wmv Just recently, one header uncorked.
Old Jun 27, 2009 | 07:19 PM
Sooner's Avatar
Car: 1982 4cyl 4spd/ 1980 z28
the thumpr would be a nightmare to try to tune in an efi application. I run a the big ***** thumpr on my carbureted motor and im still fighting an off idle, and part throttle stumble.
I like the xfi cams alot, they sound great, perform great, and are very tuner freindly.
Old Jun 28, 2009 | 08:15 AM
oo yea that xfi sounds good. i thought that xfi's just had a deeper sound too them. thats pretty much the exact sound im looking to get. but what i noticed was in the jegs description for the xfi's it says "Additionally, the XFI camshafts take advantage of the high velocity EFI-style cylinder head intake ports, intake manifolds and combustion chamber designs." now am i just being stupid or are there heads out there mayde for efi systems that have these different intake ports and combustion chamber designs or what.
Old Jun 28, 2009 | 12:29 PM
Guest
Guest
Posts: n/a
I'd ignore the company propoganda when picking something out.
Old Jun 28, 2009 | 02:30 PM
yea that seemed a little fishy to me. thanks for your help
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
