lt1 throttle body question
Old Sep 21, 2011 | 07:14 PM
frankensteinGTA's Avatar
Car: 89 GTA
Engine: 94 LT1 with Painless Perf. cam kit
Transmission: 700r4 2100 stall conv. Vette servo
do any of you guys know why a lot of lt1 throttle bodies have a small hole drilled in them in the front, below the two main inlet ports? Was this some sort of GM fix for a particular problem. I plugged mine back up. Thanks.
Old Sep 21, 2011 | 07:38 PM
torque_is_good's Avatar
Re: lt1 throttle body question
do you mean where coolant would run and the theory was so it wouldn't ice up in cold climates.
then you get the people who bypass it thinking they pick up massive HP gains
Old Sep 21, 2011 | 07:52 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
That's the idle air supply. It works with passages in the LT1 manifold to distribute idle air evenly to each port. If you're not using an LT1 manifold, then plugging it is fine.
Last edited by 86LG4Bird; Sep 23, 2011 at 12:58 PM. Reason: corrected post. previously said IAC air supply
Old Sep 22, 2011 | 12:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Why?
Old Sep 22, 2011 | 08:08 AM
plz take a photo
it has to be the coolant passage. can you pass something through it like a pencil or piece of wire? If so, that's all it is, the coolant passage and it's not needed
Old Sep 22, 2011 | 05:46 PM
Car: 89 GTA
it looked like it wasnt supposed to be that way. Its only about a 1/8" diameter hole. like someone just drilled it out.
Old Sep 22, 2011 | 05:50 PM
Car: 89 GTA
this is just below and in the center of the two main air intake holes (ports) in the throttle body. Looking at it from the front. I think 86LG4bird had it right. It must be for the IAC motor.
Old Sep 22, 2011 | 05:57 PM
Car: 89 GTA
i'm using a painless pcm and the IAC motor. Probably should open the hole back up then. Just would like to know why it was drilled out in the first place. Doesnt look like something done at the factory.
Old Sep 22, 2011 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
