Removing Oil Panel without removing EVERYTHING?!
Old Nov 23, 2015 | 10:17 AM
propaintball96's Avatar
Hey guys,
I need to replace my rear main seal and oil pan. I have a t56 to clearance is super tight. I also have a UMI K member. I raised the engine I high as it can go from the tranny and I cant slip the pan out... I another 1 inch at least. Any ideas how I can get this mother fu**** out without tearing the tranny/clutch/flywheel out?!?!?
Thanks!
Old Nov 23, 2015 | 10:41 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Removing Oil Panel without removing EVERYTHING?!
Rotate the crank, see if you can get the counterweights and journals at the right position to get some extra clearance, usually the pan will come out.
Old Nov 23, 2015 | 12:52 PM
Already have the front counter weight in the up position out of the way...Still cant make it out Any more ideas?
Old Nov 23, 2015 | 12:56 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
When I did mine a month ago, after removing the motor mount through bolts and removing the distributor cap, what tom3 suggested above is when it finally came out.
Old Nov 23, 2015 | 12:59 PM
How high did you have to lift the engine? Also, what tranny do you have?
Old Nov 23, 2015 | 01:04 PM
antares57's Avatar
I have a 700R4 and IIRC the motor mount bolt hole were 4-5 inches apart. I also disconnected the transmission mount bolt, don't know if it had any effect.
Old Nov 23, 2015 | 01:08 PM
Yeah my motor mount bolt hole is about only 2-3 inches above the mount. The Tranny is bottoming out on the underbody.
Old Nov 23, 2015 | 02:07 PM
antares57's Avatar
I may have pushed the tolerances a bit. I really needed to replace my oil pan seal and had limited time to do it.
xnickx64
Dec 16, 2015 03:22 PM
ryo7
Apr 28, 2011 02:34 PM
built91Z28
Apr 23, 2010 06:27 PM
Praetorian27
Oct 19, 2006 08:30 PM
miacamaro305
Feb 26, 2005 03:10 PM
