Gunk inside TPI... how do i clean it out?
Old Aug 18, 2002 | 09:11 PM
Fred91GTA's Avatar
Car: 1991 GTA
Yeah, I took off my intake a few days ago to do some porting and polishing to it. There's a lot of carbon buildup in there though and it's gummy like it's been mixed with grease. How do I clean that crap out? I could just put it back on like that but I have to clean out the inside of my plenum and runners anyway because of the aluminum dust particles built up in there after the porting and polishing. TIA for any help.
Fred
Old Aug 18, 2002 | 11:00 PM
Gruvin84SS's Avatar
i used carb cleaner to spray mine down. I have seen a pic of runners that were filled with cleaner and let sit for a day or so. B-12 chemtool worked well. The gumout carb cleaner did not work as well. HTHs
Old Aug 19, 2002 | 12:52 AM
Morley's Avatar
Try Valvoline's Synpower Throttle body and carb cleaner, works great.
Old Aug 19, 2002 | 10:54 AM
tpi_roc's Avatar
castrol superclean
Old Aug 19, 2002 | 11:45 AM
fastvetteTPI84's Avatar
Tolit Bowl cleaner ....the cheaper the better also it works great on carbs and TB's but be carefull water it down 70/30 i learned this trick form and old *******
Old Aug 20, 2002 | 11:10 AM
89Irocz23's Avatar
water injection
make sure engine is at normal temp though first
Old Aug 21, 2002 | 06:56 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I thought you weren't supposed to use Superclean on aluminum??
Old Aug 21, 2002 | 06:59 PM
5SIZ's Avatar
Car: 1987 IROC-Z
you can use super clean on the plenum, it will work good, but dont let it sit ont here for to long because it will pit/ etch the aluminum.
Old Aug 21, 2002 | 09:19 PM
Fred91GTA's Avatar
Car: 1991 GTA
Thanks a lot guys! I decided to go with B-12 Chemtool because that's all that my local Autozone had... It worked beautifully. 15 minutes and one set of runners were done. Now off to the plenum and the other runners. Can I let that stuff sit for awhile to let it soak or do I have to be quick about it when using it like the Castrol Superclean someone on here mentioned? Thanks again!
Fred
Old Aug 22, 2002 | 10:32 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
*cough* dishwasher *cough*
K
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
mud runner
Nov 2, 2015 07:30 PM
89fast5oh
Sep 8, 2015 09:55 AM
