Runner dent removal
Old May 20, 2010 | 09:32 AM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Runner dent removal
I am still grinding away at the ends of the runners so the 1.5 ball will fit but I see a problem on one side there are factory dents that will block the ball from going in or out that end. So how does this work? Ive read on here about people doing this wrong and getting egged out dents. Just hammer in till I get that far then reverse out so I don't damage it or is there a way to go all the way through? If it is not going all the way through should I only port one side to safe myself some time? Thanks
Old May 20, 2010 | 09:59 AM
Twin_Turbo's Avatar
Re: Runner dent removal
forget the ball, fill the tube w/ water and put it in the freezer
Old May 20, 2010 | 10:20 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
yeah well i was wanting it to flow a little better too
Old May 21, 2010 | 07:43 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I don't even know if the 1.5 ball will fit. Ive ground out the "lips" around the ends and it just doesn't look like it will fit.
Old May 21, 2010 | 05:22 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
use miller light.. not only is it less filling and tastes great but, when it freezes it is less likely to expand as much as water which can pop the tube. The beer has enough water content to quench the thirst of a dented tube.. Use duck tape to seal the ends.. This is not a joke
Old May 21, 2010 | 06:37 PM
Twin_Turbo's Avatar
miller light doesn't taste good, no american beer tastes good
flame suit on
Old May 21, 2010 | 07:52 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
flame suit on
Any and all beer doesnt taste good to me!! ewwww!!!!!!!!!
I'm going to try the water thing on mine. Or I may just go buy a can of beer and see what happens.
Old May 22, 2010 | 12:05 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
I'm not sure which part you're serious about.
Old May 22, 2010 | 08:12 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Ok.. I didn't ask what is another way to remove the dents. Ive known about that technique and I keep seeing where other people ask a similar question and you guys throw out the freeze idea using beer or whatever. We are asking what we are asking for a reason. Don't mean to sound like a d!ck but jeez. Anyways I got it all figured out now but thanks for responding to my post.
Old May 22, 2010 | 11:26 AM
centralcoaster's Avatar
Car: 1985 Corvette
Engine: TPI
Transmission: 6 speed
Axle/Gears: D44/3.45
Have you tried either method? The ball bearing method works great, less filling! It will remove even the smallest dents and imperfections.
Old May 22, 2010 | 11:29 AM
Car: 1985 Corvette
Engine: TPI
Port the flanges a little bit past that, into the runner a bit. You can't expand the flange, or the runner right at the flange, it has no give.
Old May 22, 2010 | 12:03 PM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Will do when I get more sanding bands. It is also a good thing I'm trying this out on spare set before I do the runners I'm going to use but still don't want to mess up either set. Thanks for the info, I pretty much stopped porting once the lip was gone and smooth with the rest of the inside.
Old May 24, 2010 | 11:49 AM
Shinobi'sZ's Avatar
Did you buy the kit off of Ebay...seach TPI Dent
Old May 25, 2010 | 08:57 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
I've personally used the water/freezer to remove dents and I can attest that it works perfectly. I filled them with water, laid them in the freezer so the openings were facing upwards and left them in over night. When i work up in the morning, no more dents! Took another 1 hour of slow defrosting to get the ice out tho!
Old Apr 21, 2013 | 08:59 PM
1fast89z's Avatar
Car: 1989 Camaro
has anyone had anyluck with the water trick yet? ive got mine in the freezer now hoping for a good outcome in the morning. the ballbearing method seems like it may be a little rough
Old Apr 21, 2013 | 11:08 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
do you have before pics? id post pics of both before and after. tell us how it came out.
Old Apr 22, 2013 | 09:09 AM
1fast89z's Avatar
Car: 1989 Camaro
I can try and get some pics up sometime today. The water has seemed to remove the large dents but it looks like i might have to buy the steel ball kit to get them to look good. Anyone have any other ideas?
Old Apr 22, 2013 | 02:51 PM
tonys91rs's Avatar
Car: 91 Camaro RS
interesting. i may do the same. do a search on ebay for a 1-1/2 inch steel monkey fist ball. i found one for 7.00 with free shipping. probably get a few 1-1/4 steel ***** for around the same price. alot cheaper than 40- 60 dollar kits ive seen.
Old Jan 17, 2022 | 08:00 AM
Eightyninef's Avatar
How do they get dented anyway ??
Some hack trying to change injectors ???
Old Jan 19, 2022 | 11:51 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
I removed the small dents from mine with two ball bearing sizes. They were not that bad so it wasn’t too hard. Like Eightyninef mentioned, I like to know how these things get dented as well.
87350IROC
Jul 7, 2009 10:04 AM
evoluzione1
Feb 13, 2007 08:41 PM
Chris Williams
Aug 31, 2004 08:01 PM
john5.7 87Iroc
Mar 7, 2002 07:23 PM
grafx
Mar 5, 2002 11:24 AM
