Carb cleaner used on Throttle body
Old Jun 17, 2011 | 10:24 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
ok not thinking i got a can of carb cleaner instead of throttle body cleaner it says not recomended for fuel injection but will reallt hurt the motor.. really what im asking can i use it on my throttle body and not have it cause problems
Old Jun 18, 2011 | 01:20 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Carb cleaner used on Throttle body
carb cleaner will work perfectly fine to clean out the sludge from the throttle body.
Old Jun 18, 2011 | 11:28 AM
regular6d's Avatar
Car: 84 Z28, 05 Mazda 6
Axle/Gears: 3.42 Open
Carb cleaner is a bit harsher than throttle body cleaner but you should be ok. Just don't use Brake cleaner that'll ruin your day.
Old Jun 18, 2011 | 11:56 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
and try to avoid contact directly with any plastic parts. but you'll be fine
Old Jul 5, 2011 | 09:07 AM
hotrod9168's Avatar
Car: 1991 1-LE
Engine: 305ci HO TPI
Axle/Gears: 3.42:1
Doesn't the TB have a coating on it to help with it keeping clean and with icing?
Old Jul 5, 2011 | 09:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Some throttle bodies do. Don't think anything used on our cars did, though.
Carburetor cleaner isn't always free of chemicals that will contaminate or damage sensors, unless labelled "sensor safe".
Old Jul 5, 2011 | 11:52 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
i used it and it didt hurt anything didt make much of a noticeable difference
Old Jul 5, 2011 | 07:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
And I wouldn't use it on the MAF - get a can of MAF cleaner for that.
Old Jul 5, 2011 | 07:54 PM
DENN_SHAH's Avatar
on the older systems i believe ford is the only one to use a coating on the throttle plates, at least i don't recall ever seeing a warning label on any other cars, not until you get into the throttle by wire systems anyway.
a coated ford TB will coke up just as bad and just as fast as one that isn't coated.
the absolute best throttle body cleaner i have ever seen is made by BG.
occasionally i've used MAF cleaner, but its never really impressed me. most of the time i just used starting fluid with a straw and its worked fine.
i've never used BG maf cleaner. i know most of the rest of BG's products work great, so their maf cleaner could very well work better than starting fluid.
Terrell351
Jun 13, 2021 01:13 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
