Clutch Replacement
Old Aug 17, 2011 | 07:07 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Clutch Replacement
I want to start to Up grade. So what clutch is best for a tpi 305?
IS this one good
http://www.clutchstar.com/product/f1...8-conv-5-0l-v8
Old Aug 17, 2011 | 09:40 PM
Abubaca's Avatar
Re: Clutch Replacement
This will probably get moved over into the "transmission" forum, but I'll take a crack at it anyway. What mods are you planning? Unless you're really going BIG on your mods, just a normal stock replacement from a reputable aftermarket company is really all you need. I've always been a fan of Hays, and NOT a fan of Spec. Other than that, you'd have to do your research. Again, no need to go crazy on a clutch. ...and unless your racing for dollars, it's always better to go a little TOO light duty on a clutch, rather than TOO heavy duty. Weakest link is gonna break, and the trans and engine are both expensive to fix. Might as well be the easy to fix, cheaper, part in the middle! Also remember you can always call one of the companies as well, tell them your mods and see what they recommend.
Old Aug 18, 2011 | 06:57 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
+1 on the move lol however ive been running a luk clutch in my car for over 4 years, daily driver and i beat it up, like....mercilessly when i get the chance lol throwout bearing has finally started humming, oem style clutches are good for oem cars, simple as that, if you go for a spec clutch....thats a tad bit over kill lol look for like luk, zoom, autozone/ oriely clutches
Old Aug 18, 2011 | 07:12 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Go with a stock clutch. A performance clutch will tempt you to engage power at higher RPM's and the end result will be a damaged transmission. You have to baby a T5.
Old Aug 18, 2011 | 02:24 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
says who? I beat the tar out of mine, and I have a friend whos got a t5 behind his 350 and hes not nice either
Old Aug 18, 2011 | 02:44 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
So a mid or top end can take a beating and last? i am going to be increasing hp over time. So if i can put it in now, thats what i want to do.
BluFBdy im getting one for my parts store but its there top end. Luckily im getting for $269 instead of $5??.
*Im getting more answers here then in drive-train forum *
Old Aug 18, 2011 | 05:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
take my advice with a grain of salt, yes they CAN hold up but it will only last as long as you let it, Abucaca is 100% correct id rather have my weakest link be the clutch than the transmissions, t5's are not the worlds strongeest tranny, WC or not. In my experience ive seen them take some abuse, but that takes away from the overall life
Old Aug 18, 2011 | 06:10 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
okay thanks im going to go with mid grade and "try to take it easy on it."
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
