anybody using Fast EZ efi
Old Sep 25, 2011 | 03:55 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
I am looking for some input from someone who is using this system on there TPI motor.
Old Sep 25, 2011 | 07:49 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Re: anybody using Fast EZ efi
I am going to a totally different set up and not sure if the present GM computer will be a pain to calibrate. I like the idea of plug and play tuning it learns as you drive it sounds logical to me to get chip recalibrate once or twice will cost about the same. The answer to your question no I have not yet.
Old Sep 30, 2011 | 07:48 AM
rongreen's Avatar
I this truely a plug in and drive set up?
Old Sep 30, 2011 | 12:48 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
Have a look at 88fastgta as you scroll down the TPI threads. He has an extensive thread on installing the FAST TPI setup. Looks like good info you could use
Fivestar
Old Sep 30, 2011 | 12:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its a waste of cash really, cost as much as the Holley system but can't do 1/3 of the things it can.
Holley system is boost/NOS ready out of the box plus more.
FAST does look cooler with its side rails n underplate squirters but its way over priced once you find it it doesn't do very much. Almost bought one, glad I didn't.
Old Oct 1, 2011 | 08:49 AM
Steve Mack's Avatar
Car: 87 Iroc
Thats the whole point I want it simple .I don't plan on running boost or nitros.I read an article in super chevy .They took a good while to dial in the Fast 2.0 to get there engine to 600 horse.Then put EZ EFI on and made 600 horse in two pulls of the dyno.Thanks for the input though.
Old Oct 1, 2011 | 05:51 PM
rongreen's Avatar
how abouut the Comp Cam FAST EZ ECU not thinking 'bout a manifold and fuel rails. like the though of installing an ECU that programs itself like EZ EFI by CC. Do not understand prom burning and all....I am I in left field?
Old Oct 2, 2011 | 09:17 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I for one, love it. Haven't really been able to use it a whole lot due to the mysterious fuel pressure issue (NOT related to EZ-EFI) that many of us TPI guys have been having. The link documents my experience with it. You should probably disregard all the nay-sayers on this product and make up your own mind. I too wanted simple, not stock, not nitrous-capable. I had any number of guys tell me this is crap, is overpriced, underpowered, how GM had it right with chip, and how you should burn your own chips because this new-fangled technology can't do nearly what the 1989 tech could. Yadda yadda. Like listening to Charlie Brown's teacher. It will handle the future upgrades I have planned without the chip burning and headache. Again, I love it. It's simple to hook up and fairly simple to configure and tweak. Also try a search for a QUICKCHICKEN, he installed it as well. If you have any questions I'd be happy to try and help.
https://www.thirdgen.org/forums/dfi-...i-install.html
Eric
Old Oct 2, 2011 | 02:19 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks Eric for the info.I read your whole previous post and learned a lot.I hope you get your fuel pressure problem solved.I would like to see some real world dyno numbers when you do.Thanks,Steve.
Old Oct 3, 2011 | 07:06 AM
rongreen's Avatar
Thanks BOSS357 followed the QC forum learned a bunch. The FAST XFI II will fill the bill I like using my stock ignition. FAST EZ kit is cheaper but needs a custom distributer.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
