Tpi ram air plenum?
Old Apr 30, 2014 | 11:06 PM
Jackrabbit501's Avatar
Car: 1986 Camaro
Engine: 355 tpi
Tpi ram air plenum?
Im looking into a tpi upgrade, really like the tpi but want it to breathe some more. Its not a crazy build so i couldnt justify buying the holley stealth ram, but i found a plenum on ebay that looks fairly good for my use, considering it says you dont need aftermarket fuel rail, probobly not harness either?
Heres the link to the part, i would like to know if anyone has used these or if the gains are worth the money, if any?
http://www.ebay.com/itm/Chevy-SBC-350-TPI-EFI-1957-1986-Ram-Air-Upper-And-Lower-Intake-Manifold-System-/181329849982?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a3819ee7e&vxp=mtr
Old Apr 30, 2014 | 11:22 PM
Parrydise7's Avatar
Re: Tpi ram air plenum?
Since you are in California did you notice there is no provision for an egr?
Old May 1, 2014 | 12:09 AM
Car: 1986 Camaro
Engine: 355 tpi
I sure did. I havnt had to mess with emissions in quite some time, I already have no egr on my stock intake, or smog pump, with addition to longtubes. Although if the time comes I still have all the parts to pass emissions. I just want a better intake for my ik180s.
Old May 1, 2014 | 12:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Just a Chinese ripoff of the the HSR
https://www.thirdgen.org/forums/alte...e-285-hsr.html
Where does it state that ?
Old May 1, 2014 | 01:28 AM
Car: 1986 Camaro
Engine: 355 tpi
I realize the cheaper version is not going to be as good as the more expensive hsr, but if they share the same structures would it be an improvement onto the stock tpi?
In the product description is says
Aftermarket fuel rail required: No
Old May 1, 2014 | 01:44 AM
92g92's Avatar
Car: 1992 Camaro Z28
It's a Chinese HSR. There is a thread on here discussing them, might want to look for it. I wouldn't trust the "no aftermarket fuel rail required" part. I would treat it as an HSR if I were you, which does require aftermarket fuel rails. Who knows, maybe there is a Chinese knock off of those too.
Old May 1, 2014 | 02:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 92g92
It's a Chinese HSR.
As per the link I posted for him to read above
Sure do
Read
https://www.thirdgen.org/forums/alte...tive-fuel.html
Old May 1, 2014 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It's a HSR
Everything in the HSR link below applies
https://www.thirdgen.org/forums/alte...gal-whats.html
Don't believe everything you read online
A known fact TPI rails won't fit a HSR ; only have to look at the stock TPI FPR to see there is no room for it on a HSR
Old May 1, 2014 | 12:33 PM
Car: 1986 Camaro
Engine: 355 tpi
I figured it would, although the seller claimed to not need an aftermarket fuel rail. I wasnt very successful with my searches to find the knockoff, thanks for the help!
Old May 1, 2014 | 05:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Post # 4 above
Old May 6, 2014 | 06:16 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Even though the thieves in China say it uses stock rails, because they copied the strath ram it's obvious that the stock tpi rails won't fit.
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
bryan623
Aug 10, 2015 11:33 AM
