HELP!! 89 gta with 85 harness and 86 ECM
Old Apr 29, 2018 | 07:08 PM
91rsproject's Avatar
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
I have a 89 gta trans am. When i bought it the car had a carb and didnt have the TPI system. After months of digging i found a set but i was told it was off a 85 Camaro z. So the harness plugs in and hooks up, but i cannot get it to fire . i put some gass in the tb, and it fired up. I have narrowed down to the injectors not pulsing. I also had to bridge the fuel pump to get it to kick on.
I have searched the vats forums and i cannot figure out what the heck is going on. I have checked all kinds of parts of this. i have 12v on both injector wires. i have spark, i have 42 lbs of fuel pressure. there were some wires i could not figure out what they went to but the car starts and runs if i spray or put fuel in the tb.
Can anyone help me please.
Old Apr 29, 2018 | 07:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: HELP!! 89 gta with 85 harness and 86 ECM
http://f-body383.tripod.com/AAB/870-...pRepinning.htm
Not sure what was from the 85 the tpi harness or ecm, the ecm wouldn’t have vats.
If your use of the 1227165 ecm it would have vats. It’s not a plug and play in the 85 harness.
https://www.thirdgen.org/forums/elec...pass-vats.html
Old Apr 29, 2018 | 07:11 PM
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
So i have to repin it all?
Old Apr 29, 2018 | 07:16 PM
Engine: Lb9
Transmission: M20
Or get a different harness one for a 88 -89 would be the best since the alternator is on the drivers side. 88 has provision for the ninth injector so it can be left unplugged.
C100 might be different as well .
The 1227165 ecm was used in f body’s 86-89
Old Apr 29, 2018 | 08:25 PM
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
ok doing reserach looks like maybe the harness is maybe from a 86 as well. have the 259 ecm. so i shouldnt have to splice any wires.
Old Apr 29, 2018 | 08:31 PM
Engine: Lb9
Transmission: M20
259 is a superseded number for the 165. The memcal letters can tell if it’s for a 88-89 vats started in some 88s f body’s and 86 in the y platform.
If your fighting injector pulse you might have a bad icm. You can have spark but no injector pulse with a bad icm .
Old Apr 29, 2018 | 08:34 PM
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
what is the memcal lettters?? How do i tell if the vats system is not pulsing the system. is there a way to just bypass it without the key or resistor?? this does not have vats key.
Old Apr 29, 2018 | 08:38 PM
Engine: Lb9
Transmission: M20
You can post the letters on the memcal (computer chip) and I’ll see if I have that file to see if it has vats.
If the harness is from 85 you would have a plug like this next to the ecm for the maf burn off module.
Old Apr 29, 2018 | 08:49 PM
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
No i do not have this box. i will get the number tomorrow. I just want to figure out why and get this damn thing going.
Old Apr 29, 2018 | 08:52 PM
Car: 89 GTA
Engine: 5.7
Axle/Gears: Unknown
ok AUM 01228291, and 6243 1621 3684
Old Apr 29, 2018 | 08:55 PM
Engine: Lb9
Transmission: M20
Aum is from a 86 tpi 305 automatic. Your not battling a vats issue .
Old Apr 29, 2018 | 08:58 PM
Engine: Lb9
Transmission: M20
Have you checked that the check engine light comes on. The fuel pump and ecm power are tied together and fused bye a 20 amp fuse next to the battery.
Old Apr 29, 2018 | 09:11 PM
Engine: Lb9
Transmission: M20
Another thing to test is that the purple/white wire is hooked up. It’s ecm tach reference.
Another thing that can cut injector pulse is if more that 4 volts if feed back from the tps.
Blue is tps signal gray is 5v reference.
Or another possibility shorted injectors shutting down the injector driver.
michael
17
Jun 25, 2015 08:36 PM
Mirocz87
Mar 2, 2010 12:57 AM
stealth908
Feb 18, 2009 09:20 PM
