Looking to put braided lines for the tranny cooler, parts info needed.
Old Feb 26, 2003 | 02:49 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend and I are putting LT1's into our Trans Am's and were looking into using steel braided lines for the tranny cooler lines.
We'll be using aftermarket tranny coolers on both cars.
Any advice and parts to use for this project would be very appreciated.
Old Feb 26, 2003 | 04:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll need a pair of 5/16" I.F. to -6 AN adapters for the transmission fittings, and another pair if you're keeping the radiator in the circuit. Aeroquip has them but I don't remember the P/N. You'll probably need about 10 feet of -6 hose and 4 -6 AN ends if you're not using the rad and 6 -6 ends if you are. If your cooler has NPT fittings, you can get NPT hose ends from Earl's instead of using adapters.
Old Feb 26, 2003 | 05:18 PM
Zepher's Avatar
Cool, that's exactly what I was looking for.
Thanks a bunch.
Old Feb 28, 2003 | 08:42 AM
ede's Avatar
ede
you can get lines made with the correct flare fittings with out needing to use adapters. look in the yellow pages under hydrolic hose and have a set made. way cheaper then buying an parts and line from a speed shop and way cheaper for the same parts.
Old Feb 28, 2003 | 02:56 PM
Zepher's Avatar
Thanks, we'll look into that as well since we need to have P/S lines made too.
Old Feb 28, 2003 | 03:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I get my hose and fittings from an industrial supplier. Prices are typically anywhere from half to a third of what the speed shops charge.
Old Feb 28, 2003 | 03:10 PM
Zepher's Avatar
do you have a number or a website address?
Old Feb 28, 2003 | 06:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really, I just use the local guys down the street. Like Ede says, any hydraulic shop should be able to make you the hoses, or get the parts if you want to make them yourself.
Old Mar 1, 2003 | 06:59 AM
ede's Avatar
ede
i get mine at a NAPA store, but where i live there is so much industrial and off road equipment it isn't like most parts stores you see.
Old Mar 1, 2003 | 04:39 PM
Zepher's Avatar
Thanks for all the tips. Once we start to tear into the car, we'll measure the length required and have it made.
Another thing, he is using a B&M Tranny SuperCooler and it has screw in fittings for the inlet and outlet. Anyone have an idea on the thread size that's on it? It's the 11" wide unit.
Old Mar 1, 2003 | 04:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably 1/2 NPT
Old Mar 1, 2003 | 04:52 PM
Zepher's Avatar
Thanks.
Can't wait to start work on the cars. They should be nice street machine when they're done.
this is the first one getting the LT1,
And this is mine,
Old Mar 2, 2003 | 06:44 AM
ede's Avatar
ede
my permacool used 3/8 NPT, i used an adapter to go from NPT to AN
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1nastygta
Aug 8, 2015 07:38 PM
