Do I have a speedometer hole?!
Old May 21, 2005 | 04:06 PM
Can_of_yum_yum's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Axle/Gears: Moser 12 bolt/3.73
Hey, does my tranny come with a hole for the speedometer cable to go into? I bought the car with the tranny allready in it. The guy said all I need to do is get an adapter so the speedometer will be acurate. I know the combination should be 7-tooth drive gear and 21-tooth driven gear, but I don't know where to put the stupid cable. I cannot find a hole in the tail shaft. Please help.
It is a T-10, 7d (does that mean 7-tooth drive gear?), and the #3813490 and then it says R-2.
thanks
Old May 21, 2005 | 06:55 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Of course you do, you better!
If your speedometer is working (regardless of precision), the mechanical cable is attached to the trann and working. Just find it. It's a cable that's screwed onto the tailhousing of the tranny. On the T-5 and 700R4 it's on the driver side. That's your "hole".
When you unscrew the cable, remove the bolt and pull the gear housing out. You'll see both gears now.
Oh, btw ..... catch the fluid in a pan!!!!!!!
Here's a post with some pictures and info on how to do the gears: https://www.thirdgen.org/techbb2/sho...postid=2329537
Hope this helps.
Lou
Old May 21, 2005 | 08:20 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Hope this helps.
Lou
He never hooked it up. There is just a cable hanging next to the tranny. I have looked and felt all around the tailshaft and towards the front and I cannot find a hole to put the cable into or even a hole with a bolt in it big enough for the cable. If you want I can maby get some pics up. I hope I dont sound too stupid.
Old May 21, 2005 | 08:57 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
There isn't going to be an actual hole. It should be a threaded thing coming out of a hole. About as big around as a quarter maybe. The cable should have a threaded sleeve. You use that to screw into the transmission.
Old May 21, 2005 | 11:08 PM
BigBadLou's Avatar
Engine: TPI
Yeah, if you can get some pics, that would help. I have never seen a T10 before so I can't tell where the speedometer cable hookup is but it gotta be on the tailshaft somewhere.
Do a search and maybe you'll come up with something. I'd search for ya but I'm on dial-up @ 26k (can you believe it?) and it would take me ages, sorry.
Lou
Old May 23, 2005 | 07:50 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
K, here are some pics. Is it possible that in 1962 (when my tranny was made) they made some of these without a speedometer?
Old May 23, 2005 | 07:55 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Old May 23, 2005 | 07:57 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
pass. side
Old May 23, 2005 | 08:00 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
That cord really close to the camera on the bottom of the pic is the speedo cable.
Old May 23, 2005 | 08:03 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
close up on drivers side
Old May 23, 2005 | 08:04 PM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Where does my speedometer cable go?
Old May 23, 2005 | 10:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It goes right here.
Take that nut off, remove that stud and large washer. It's a backyard/hillack plug for the hole.
The little threaded hole next to it is where the bolt for the retainer goes.
Attached Thumbnails Do I have a speedometer hole?!-4-spd-speedo-gear
Old May 24, 2005 | 08:35 AM
BigBadLou's Avatar
Engine: TPI
Good job, RB83L69! I missed it on the first pass. Then I looked closer and saw the same thing, the bolt hole is a dead giveaway.
Though, I believe the tranny tailhousing will need to come out to remove the bolt from the inside. Or maybe they have some special washer inside that will fit through, I don't know but I'd be prepared to pull the tailhousing anyway.
Lou
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
drumstixer
Sep 29, 2015 03:02 PM
Bigold4x4
Sep 28, 2015 05:21 PM
