Swapping a 10 bolt for a 9 bolt
Old 01-02-2006, 09:12 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
I've been planning on swapping my 10 bolt for a 4th gen rear, but recently have decided I want to run wheels that don't look like they're for a FWD.
Today, I came across a 1LE 9 bolt with 12" brakes and aluminim calipers and 3.45 gears. On the face of it, this looks like a perfect swap for me; my 10 bolt has 3.42 gears and that's the ratio I want to stay with.
Does anyone know if this will be a DIRECT swap? I just got an aluminum 4th gen driveshaft, had it balanced and new h/d u-joints put in. Will it be a direct swap?
Also, I'm assuming the 1LE rear brakes would be near the top of the list of rear brake choices. Am I correct? I plan on swapping to C5 front brakes at a later date.
And finally, will the 12" 1LE rotors clear my stock 16" WS6 wheels? I plan on running them for awhile, at least.
Old 01-02-2006, 11:40 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Yes, everything will be a direct swap, except for one thing: Unless you currently have PBR disc brakes, you will probably need to change e-brake cables.. Your wheels will fit.
Old 01-02-2006, 11:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
yep should be direct bolt in... the only thing i could think of is like above mentioned, the E brake cables. also maybe some brake line issues if your not already running disk rears and i think the PBR disk rears.
Old 01-02-2006, 11:49 PM
Axle/Gears: 3.73:1
When I swapped from a '91 drum brake axle to an '89 9-bolt, the brake line on the 9-bolt attached right onto the brake line on the body. Worst case scenario is he would have to figure out how to adapt his hardline to the new axle's lines.
Old 01-03-2006, 02:44 AM
Engine: L03 305 TBI
Thanks for responding. Can you tell me how to resolve those brake line and e-brake cable issues?
Old 01-03-2006, 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i think you could go to an auto parts store and order a ebrake cable for the same year as the 9 bolt your swappin in.
Old 01-03-2006, 01:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following should provide some info:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old 01-04-2006, 07:26 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Along these lines when you change the fluid in the 9 bolt you're swapping in what are you going to use?I did a search as to whether or not to use the limited slip additive with a 9 bolt posi.I'm confused somewhat,well more than usual,as to what fluid would be best when I service the 9 bolt posi on my '83.The factory aluminum tag that says use only limited slip fluid is still attached which makes it more confusing from the info i've read.
Old 01-04-2006, 08:08 PM
JamesC's Avatar
Nothing special about a nine bolt that I know of. I use Mobil 1 with GM additive in my 10-bolt with limited slip.
JamesC
1984HO
03-19-2021 11:59 AM
ZMWojnar
Brakes
05-12-2019 10:43 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
theurge
08-21-2015 12:46 PM
Quick Reply: Swapping a 10 bolt for a 9 bolt
