Just got a th700, need some info...
Old Apr 2, 2006 | 11:27 PM
Bluechrome's Avatar
I just got a th700 from my local pick-n-pull and some guys told me the th700's that came behind the 2.8L's had weaker internals than those that came with the 305/350's. Are they right? And will I need an adapter plate to put it behind my 350? Thanks.
Old Apr 3, 2006 | 08:32 AM
chesterfield's Avatar
Car: Pontiac
isn't the 2.8L a 60 degree bell housing? yeah you'd need an adapter.
Old Apr 3, 2006 | 07:21 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i wouldn't use one that was behind a 2.8........get one that was originally behind a v-8. not just for ease of install, but for the heavier clutch packs. plus the input shaft is different.
Old Apr 3, 2006 | 09:48 PM
Bluechrome's Avatar
Thanks that's what I needed to know.
Old Apr 3, 2006 | 10:19 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
I don't think there even is an adapter... if there is, it's something brand new that just came out....
Old Apr 3, 2006 | 10:21 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
When I installed my Transgo Shift Kit, in the video, they said that the 700's behind the 2.8s were NOT meant for performance. I'm guessing you would gradually tear it apart with a 350.
Just pick one up from a V8 and have piece of mind.
Old Apr 3, 2006 | 10:41 PM
ljnowell's Avatar
No you wouldnt. You couldnt even hook it up. You could use a manual from a v6 car, with a different bellhousing. But you cannot change the bellhousing on the auto trans. Its a no go.
Old Apr 3, 2006 | 10:45 PM
Bluechrome's Avatar
The guys at my local junkyard are good guys and would let me grab another th700 from a v8 car to exchange with the 2.8L tranny so I didn't waste my money.
Old Apr 4, 2006 | 02:56 AM
Gotchya, it's just the way they made it sound, was like the two could interchange.
BANONE
Dec 9, 2002 08:00 PM
max_est
Nov 21, 2002 12:16 PM
macone
Jul 23, 2002 10:20 PM
91B2L
Jan 20, 2002 08:11 AM
FastBroker
Oct 18, 2000 08:10 AM
