Speedometer off 5mph, or is it?
Old Apr 26, 2010 | 02:52 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Today I was dataloging my car and was about to enter a school zone. I looked at my dash and brought it down to 20. I glanced at my laptop and it said 25. After the school zone I took it up to 40 on the dash and yet again 5mph over. I took to the highway, 70 on the dash- 74 on the laptop. It was a bit harder to tell at 80, but it seemed to be closer to 2-3mph off. which is correct?
Old Apr 26, 2010 | 03:39 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Speedometer off 5mph, or is it?
If your at idle and doing 0 MPH, does the laptop say 5?
Old Apr 26, 2010 | 03:42 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
no, its says 0.
Old Apr 26, 2010 | 04:34 PM
built91Z28's Avatar
What about when your speedometer says 5, does the laptop then say 10? If so, have a friend walk next to your car while the speedometer says 5. 5 MPH is a fast walk while 10 is a decent run speed.
Old Apr 26, 2010 | 05:58 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I haven't tried it at 5, but will try it.
Old Apr 28, 2010 | 12:10 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
What I would do is find a nice suburb neighborhood because somewhere they usually have a speed limit sign that tells you how fast you're actually going. I dont know any places in SA but brodie lane in austin has one about every 2 miles. I dont know if you guys with the vss have a smoother reading than the mechanical speedos but when im driving at a slow speed like 5 or 10 my needle bounces and becomes worthless so the experiment above wouldnt work for me, maybe you high tech guys have better luck.
Old Apr 28, 2010 | 07:02 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
you could also get a buddy with a car (one that you would expect the speedo to function accurately in) to drive beside/behind/in front of you. Then compare readings.
Old Apr 28, 2010 | 08:32 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Drive down the interstate and hold a constant 60MPH. Measure the time it takes to travel 1 mile (use the mile markers, not the speedometer).
It should take you 1 minute to travel 1 mile at 60MPH.
You can drive at any constant speed and using the mile markers, calculate your speed.
Or find someone with a GPS that measures road speed.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
