can someone help me 700r4 questions
Old Oct 6, 2013 | 02:46 PM
itsdeenoo's Avatar
Car: anything with wheels
Engine: 327
Transmission: t5
Axle/Gears: ford 8.8 4.11
hello i have a 1984 camaro with a 700r4 tranny the tranny will not shift out of first so i pulled it out and want to get another 700r4 out of a diffrent camaro can i use any 700 r4 out of another camaro and it all match up or what will i have to do to make it work someone let me know please thanks
Old Oct 6, 2013 | 03:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: can someone help me 700r4 questions
What year did the trans come out of?
Ensure torqueconverter is installed correctly.
When you get the shift cable in ensure it engages in all gears & selector lines up with gears selection.
Correctly adjust TV cable.
www.tvmadeez.com
Connect cooling lines.
Maybe change fluid & filter. Verify fluid level.
Make sure all connections are correct.
Old Oct 6, 2013 | 03:14 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
my trans is from a 84 but im asking what years can i get a 700r4 from that will work in my car
Old Oct 6, 2013 | 08:01 PM
Car: '87 Camaro
DOH!!
Sorry I missread " want "... thought it said " went "...to get....
I'll leave it to others who know what year they went from cable driven speedometer to vss electrical,
Sorry I dont know the year!!
Old Oct 6, 2013 | 11:50 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Up to a 92 should work fine
Old Oct 7, 2013 | 03:53 PM
cumminsN14's Avatar
Car: 86 Z28/86 IROC
Engine: 305 LG4/ LT1
Transmission: 700R4/4L60E
I think 90 they went to a VSS, i say 89 and older so it works with mechanical speedo, i would swap speedo gears from your old trans without knowing what car it came from, i put a 700r from my wifes car with a 145mph speedo in mine which has a 85mph speedo and at 40mph its really doing about 65.
Old Oct 7, 2013 | 05:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The VSS and mech speedo drive units interchange so simply R/R to suit whatever the car requires
Old Oct 8, 2013 | 04:14 AM
Switch8383's Avatar
Vetteoz what do you mean R/R? Because I need to swap from a vss to a mechanical speedo cable the 700R4 that I'm putting in is a vss and my car is a 89.
Old Oct 8, 2013 | 07:11 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/tech...formation.html
R/R. Shorthand for remove and refit
As noted the two interchange
This cable drive unit
fits here in place of the VSS shown
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
