New 3.4 Crate Cam lobe wiped out
Old Jun 6, 2005 | 09:37 AM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
After a few run in miles a cam lobe wore out, 80-90% worn,
anyone else have a problem like this with this engine the 3.4L 60* V6 crate engine
Thx
Paul
Old Jun 6, 2005 | 10:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
dont think anyone else here used the crate as a 3.4 swap. It was usually the s10 peps that used the crate engine as a base. May want to join some of them and ask.
How well did that cam work on an mpfi setup?
Old Jun 6, 2005 | 10:24 AM
KED85's Avatar
I would make sure you speak to a GM REGIONAL REPRESENTATIVE about this issue.
No one, here, having installed used 3.4 report that problem. AND I never recall reading about the cam wearing out on a 60* engine. New GM cars with V8 of the 70's, it was an issue.
That stinks.
I am so sorry to hear about this.
PERHAPS you may be able to get another new GM crate engine.
Really reach high for this issue to be solved.
The cam was also made by CRANE CAMS in FLA. I'd also speak to them about this. 904-258-6174
Hope this will lead you to a settlement of this issue.
Old Jun 6, 2005 | 08:18 PM
TVRPAUL's Avatar
Hi Dale, KED85
Put the Holley 390 4 brl. on the engine. it only had about 70 miles on the engine when this happened with the cam.
Big let down, The engine was going in a car that is less the half the weight of a Camaro.
I told my guy to let GM know that I want a new engine.
Paul
Old Jun 6, 2005 | 10:25 PM
KED85's Avatar
My understanding is that these crate engines do carry a warranty.
Next engine make it better!
YET after all those pics, so hard to see how!
FOR FUN
1965 Griffith 200 #58 of 300 289/271 BHP, 1800 lb, restoration comleted 1988, 0-60 3.8 secs, vintage race prepared, 1st place show winner Midwest Musclecar Nationals $30,000.
Oh forgot to say this
Road & Track Marketplace, September 1988 issue.
Old Jun 8, 2005 | 11:15 PM
TVRPAUL's Avatar
Well the Chevy dealer is having my shop take the car back, and let them do the work. The service manager is going for new engind. It only had about 70 miles on it. I q
Old Jun 9, 2005 | 12:10 AM
KED85's Avatar
Best thoughts!
Old Jun 9, 2005 | 08:14 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No, my GMPP 3.4 (S10) dident have any problems with internal engine parts. One thing you need to watch out for on the warrenty issue is your 4bbl. They may say it was over fueling, had to much gas in the oil and lost lubrication.
Change the oil run it for 10 minutes then pull it and ship it back.
Old Jun 16, 2005 | 11:02 PM
TVRPAUL's Avatar
GM wiill replace the cam and all lifters. and will let the shop that has the car do it, not the dealer.
How does that sound to all
Paul
Old Jun 17, 2005 | 05:47 AM
Dale's Avatar
Engine: 350 S-TPI
not to bad. I would see if their is a way to flush the oil out to make sure no debris is in the system.
Old Jun 17, 2005 | 09:07 AM
TVRPAUL's Avatar
I am going to talk to the shop about doing just that.
Paul
Old Jun 17, 2005 | 09:58 AM
KED85's Avatar
I would have the engine completly torn down, cleaned and then rebuilt/reassembled.
Send out heads for "rebuilding and have 3-way cut finish" put on the valves.
Get GM to pay for the labor costs, GM supplies parts.
This way of total rebuild (or complete tear down, take your pick of terms), the oil passeges WILL be flushed out. One cannot truly flush out oil passages with block in car. And there are oil passages in the crank shaft, too.
ALSO get new oil pump in deal. Include new pump pick up screen, too. Metal could have gone into that, also.
Lucky, new engine and quick problem. This resolve of he problem the engine will last a very long time!
Old Jun 17, 2005 | 03:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's great, TvrPaul!! Glad to hear they're taking care of you. Keep us posted!!
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
