Seized Throttle Body
Old Mar 20, 2006 | 10:56 PM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
Hey guys, a little update on the restoration of my 85 SC. I've found the accelerator cable and got it all attached, but the throttle body has seized up. What do you guys think? Shoot some of that rust eating stuff on it and force it open or do you think I should replace it?
Old Mar 21, 2006 | 05:43 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If you have the money and sources, I'd replace it.
Old Mar 21, 2006 | 11:43 AM
daves12secV6's Avatar
if u want to try to free it up, get urself a can of pb blaster stuff works great foir freeing up rusted parts
Old Mar 21, 2006 | 03:02 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I'd just replace it because you don't know what kind of condition the passages are in, if the rust is bad enough to seize up the plate in the bore(VERY small contact area between the two) imagine what the air passages look like.
Old Mar 21, 2006 | 04:19 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
In any case, the first step is to take it off and take it apart to see where you stand. You might have lucked out. If all looks as it should, a good soaking in pb blaster and some elbow grease should free it up nicely. If you find any internal problems, the junkyard is only a drive away
Old Mar 22, 2006 | 02:53 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
good to hear from ya again. id do what they suggested and also cleanup all that corrosion and such from all the engine parts. doing that will allow you to see if there are any other problems and clearup any binding problems there may be. another smaller plus is that you would feel better about the car cause it would look less like a POS (atleast thats how i would feel. )
Old Mar 22, 2006 | 03:23 AM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
Yep, I'm gonna go over the engine bay with some wire brushes, rags, and cleaning stuff as soon as I clean up my garage and get the car towed back to my place. Kinda hard to do much work on the car out in 30 degree weather with 10+mph wind blasing at you..
Old Mar 22, 2006 | 08:16 AM
xplane's Avatar
Engine: 2.8 MFI
hey that sounds about the same here but the winds are a heck of a lot more than a measly 10mph. good luck.
Old Mar 22, 2006 | 01:24 PM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
Oops did I say 10 mph? I meant constant 10mph winds while gusting up to 30
Old Mar 22, 2006 | 02:59 PM
xplane's Avatar
Engine: 2.8 MFI
well do the temps in your area go from 80* one day and the next its snowing? kansas has some F'ed up weather.
Old Mar 22, 2006 | 03:34 PM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
Hmm well it can. New York has been getting crappy weather lately. Temps as if it was still winter altho its spring. Oh and it rains. Alot.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
