87 2.8 VS 95 3.4
Old May 8, 2001 | 02:51 PM
gemmefire's Avatar
87 2.8 VS 95 3.4
my freind what to run our cars. (race) we both have 5 speeds he has a chip i have ram air and a cam... waht are the chances of me winning the race. who has the HP adgantage?????
Old May 8, 2001 | 04:02 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
hed take u
2.8 135/170
3.4 170/200
the cam and ram air may have added 15 hp..but ur still 20 hp shy
[This message has been edited by Graeme'sFirebird (edited May 08, 2001).]
Old May 8, 2001 | 04:14 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Dude, Belchertown Ma??? You're not even 1/2 hour from me!! Wanna go cruising sometime???
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic
2.8, A4, T-tops, 90k miles
'97 Z28 w/30th Anniversary package
LT1 (obviously), 6 speed, t-tops
White with orange stripes, killer system, 41k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old May 8, 2001 | 07:02 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
hey, if you guys ever come up to cape ann, tell me. there is NO ONE around here to talk car stuff with!
Old May 8, 2001 | 10:35 PM
AntiVTEC's Avatar
Your 2.8 should be able to hang or even beat that 3.4. Gotta remember the 4th gens got a little weight disadvantage to the 3rds. Also, the 3rd gen V6's are geared better than the 4ths. Unless he's got 3.42's out back and is a good driver, U've got a good match. Good luck!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Eibach and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"I'm out to seek those pesky VTEC boys!" (don't get me wrong, I'm asian myself! hehe)
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old May 9, 2001 | 08:50 AM
KED85's Avatar
Cheat.
Steal his car.
Swap your engines.
Give the car "back" to him.
Then see his expression when you really beat him.
He won't be able to tell the difference between the 2.8 & the 3.4 block, under there!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 9, 2001 | 07:28 PM
94Camaro's Avatar
Car: 1994 Chevy Camaro
Engine: "3400" 207ci V6
Transmission: Tremec 5 Speed (T5)
Ked85 - Yea, he'll be able to feel the difference. Ask Graeme, he always tells me that the motor in my 94 3.4L feels strong.
Graeme - hate to point this out, but you are wrong on the 3.4L stats.
its 160hp/200tq for a 1993-1995 3.4L V6 F-body.
AntiVTEC - some 2.8L cars might be able to beat 3.4L cars. but its not all because of the gearing. 3.42's dont give much advantage over 3.23 gears. a little but not much, quick acceleration will lose you in the top end (3.42's dont get as good when you go higher than 70(could be wrong on this figure) or so) and so on and so forth. GM put 3.23's in the 4th gens for good highway crusing speeds.
ok now to answer the question:
gemmefire - you have a 2.8L or a 3.1L? you didnt specify. what kind of cam do you have? (lift numbers - stock 3.4 = .472in/.475ex) depending on all these factors, things could go for or against you.
all in all, its more likely that you will win because he has only that one modification, while yours is more substantial. are you sure he doesnt have any other mods? just curious..
-R
Old May 9, 2001 | 08:20 PM
Jason E's Avatar
I've driven a '95 3.4, and it felt like I was driving my RS with a nicer dashboard and a console
The 3.4 is faster in theory, but the 2.8 may be faster in actuality
Old May 9, 2001 | 10:19 PM
AntiVTEC's Avatar
The gears in the 87 T-5 are different from the 4th gen T-5. 3rd gen T-5's can keep the motor in a better range than the 4th's can. Not so sure about 3.42's not having much advantage over 3.23's. My bro has 3.42's in his 4th genner and that bad boy will get up harder then any 4th genner with 3.23's that i've ever drove. Plus, his car is stock. The number might not be too much different but when it comes to keeping the motor in the sweet spot, it just makes the difference. Just ask some of the 4th genners with 3.23's how their car feels when they're on the gas and they shift from 1st to 2nd. Seems like they kinda die for a moment. Aight then... payce!
Old May 9, 2001 | 10:46 PM
KED85's Avatar
I've got 3:42's in my Firebird.
That thing flies!
Sweet Spot?
Try G-SPOT!
100mph, going from 70, in a blink. Freeway crusing, barely breathing.
Tach?
Not hooked up, yet, but soon.
70ph is about 2200rpm
Chat Soon,
KED85
Karl
Old May 10, 2001 | 12:03 AM
AntiVTEC's Avatar
What do u need a tach for? If u got a manual gear box, shift: 30,50,75,110,oblivian! haha. LATE!
Old May 11, 2001 | 12:02 AM
KED85's Avatar
I have an automatic.
I tend to 1-2 upshift at 50MPH....
Opps, that's the Corvette automatic shift.
I like seeing what's going on with gauges.
Besides, something to watch in traffic. All the pretty girls have the windows tinted. But, those few in convertibles....YES! Some days, you just gotta love SoCal.
Chat Soon,
KED85
Karl
Old May 11, 2001 | 03:22 PM
ooooo i stand corrected
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
86maro_252
Oct 10, 2015 06:52 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
spartanreaper
Sep 25, 2015 07:22 PM
