Turbo Install
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Purge can/ turbo...install
Ok got to drive the car on a 50mile round trip. Ran fine, just a little richer then i'd like at crusing. It was hovering at 14.5 AFR average. Before I touch that does the warmer weather make the car run leaner or richer?? Its like 60* out today. And I though that the warmer it is the richer the car is since the air isnt so dense.
Anyways, I added a log of a WOT pull only for 0-85Mph or so. It shifts much better now that the fuel cut of is set right...opps, on my part. But I turned the WG duty cycle down and dont like it, takes to long to spool up. Im just starting to relize that im going to get a little boost spike if I want it to spool up fast but in general the car is running smooth, starts well when hot/or cold. And the Tcc locks up good when crusing and isnt locked when 40%tps and higher at certaint mph.
Let me know if that log looks ok, as I think it does?? 0-80Mph in 11 seconds?? Not bad right with a crappy start and a slow spool up...And WOW does the intake temp go up fast under boost on a warm day after crusing, absolutly no knock though
Row 19-97 is the 0-80mph area in 11.36 seconds.... Keep in mind the low boost level, and the slow spool up. I think thats respectiful considering. I drove about 1 1/2 hours on this tune so its was supper conservitive since I cant just pull over and fix it..LOL And had a 200lbs passenger.. Some one had to watch the laptop.
but in about 2-3 weeks i should be a site sponsor here, once i get that ill hook u up with a deal on a set of real turbo headers for that thing
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
/hijack
Car: 1991 Camaro RS
Let me know asap dave, as I really wants some.
Heres another log for your entertainment If ya wana take a peak, I just put the good info on there. WOT only. Row 25-133 is the WOT 0-100Mph, still with the slow spool up becasue of the WG duty cycle.
one of my planned products for u v6 guys is going to be a direct port nitrous system
Car: 1991 Camaro RS
Cool, dave. Thanks again.
On the latest WOT run to 100mph i got these numbers. After the latest run I think im ready for the track in a few weeks to really get into tuning WOT. But it seems to be good enough for now, and driving arround town
Heres some math from that last 0-100Mph log i attatched in the other post...Anyone know how accurate tunerpro is at the timing in its logs??? Anyways I posted those numbers on that drag racing forum, so theyll probly laugh at me for modding the V6 like I did and only be as fast as a stock z-28..
0-80Mph 10.62 Sec.
0-90Mph 12.49 Sec.
0-95Mph 14.25 Sec.
0-100Mph 15.71 Sec.
All I did was launch a little better considering the un-preped road and it said I cut 0.74 second off the 0-80Mph time from the log before. Thats why I wanted to know if anyone knows how accutate the timing is on tunerpro. Im not too concerned about how close it is to real time....Im just concerned that if it says im a seconds faster in this MPH to this MPH, if its actually somewhat accutate.
You guys think that those times are ok for what ive done?? Ive driving it so much that I cant even tell its that fast anymore...
SOB!!!!!!!!!!!!!!! I just now saw that my vac line from the silenoid controler was ate up from the dam* pully just enough that it wasnt air tight anymore. Explains why I kept messing with the command boost, and WG duty cycle and saw minimal results. Oh well thats what those 50-60 mile cruses are for...to fine the flaws in the system i guess!
0-80Mph 10.62 Sec.
0-90Mph 12.49 Sec.
0-95Mph 14.25 Sec.
0-100Mph 15.71 Sec.
Engine: LZ9????
Transmission: 2004R
Car: 1991 Camaro RS
Im really interested in those turbo headers also. Aren't you running $59 on that truck?? Else then the little benifits of crusing in closed loop, its fine if I just always run my car in open loop for now isnt it? I wouldnt see why it wouldnt be since im still new at the $59 and theres ALOT of stuff in there
for closed loop..
And I finally the tune is good enough to drive on the hi-way for a bit and even take it down the track... @34blazer....70* today man!! In ohio!! Anazing isnt it??
@dave(project89)..What were you Intake Temps when you ran the 1/4 mile. Im seeing like a 81* temp at the begining of the run and it goes up to 127* at the end of the run. Then once off boost it goes down fast.
Is that normal for a intercooler like the one I have?????
This was on a 14.9@98MPH logg on the Gtech with 20 MPH head winds...LOL Windy as He*l out but its warm. Also 6.3 0-60Mph and 189RWHP as of g-tech. That g-tech is probly so far off but oh well it keeps me happy..... so 189*20% drivetrain loss=227hp. So even if im getting 210-240Hp im happy for now....Still@ 10psi of boost.
It was about 65 degrees out ambient temp when i did that..... Im starting to think of how to mod up something that will let the air flow into the IC better, that airdam sorta suxs...
Car: 1991 Camaro RS
Dont laught BUT..
Doubt anyone will believe me since I have no video of it, BUT, i did manage to stay side my side a 5gen V6 camaro today from 40mph up to 80mph. I didnt want a speeding ticket so i stoped the race... but still dont those new LLT 3.6L V6's have like 250-300Hp??
But anyways the car is a blast to drive as it was 70* today and I could just roll the windows down and cruse. Thanks everyone for the help thus far!!!! This car is just so fun to drive when on the hi-way. Its a sleeper till that turbo spools up. Fun Fun Stuff!!
The car ran a litter richer but only could you tell on the excel log. Average 11.8 under boost. (Crusing was 15.2 AFR average without boost) So I racked up 150 miles in the last two days with it being a pretty reliable car in town, crusing, and getting on it. So thats all I can drive it for a bit as the 93 is killing me at the pump when I get gas. Might get 30Mpg on the hi-way, but only like 3Mpg when on boost!! When its 4bucks a gallon...It gets exspensive!!
But to the bottom line...THANK YOU ALL FOR YOUR HELP THUS FAR!!! YOU KNOW WHO YOU ALL ARE!!!
nice, just for ***** and giggles pull the airfilter and then try another wot run again.
i bet that air filter is slowing u down.
my air temps would get into the 150-160* range so ur still fine
3mpg under boost is horrible u have to be way rish or somthing do u have decel fuel cut enabled?
what muffler do u have on the car as well ?might be time to put a cutout in the ex system u should be faster then what u are now @ 10 psi
Car: 1991 Camaro RS
Im just guessing the MPG at WOT, i have no idea what it is, but im sure its bad
I have just a magnaflow muffler on it, no cat. I want to get a cut out before I first hit the track forsure!!
Engine: LZ9????
Transmission: 2004R
i think the high in vegas today was 60ish. of course when i leave ohio the weather breaks lol. must be a black cloud following me around. im not using $59 in the blazer yet. im running $42 but i cant wait to swap to a 7730 because $42 sucks compared to $8D S_AUJP. im unpacking all my household goods right now, lots of spare parts lol. hopefully back on the project soon.
good to see yours is coming along nicely
Transmission: 5-speed/T-5
Your IC is grossly inefficient, if you're getting intake temps that high, without heat soaking the IC from sitting still, or your turbo way out of its efficiency range.
When it's 80* or so out, I will see intake temps around 100 to 110* while cruising, then hit the throttle and within about half a second my intake temps drop to a degree or two above ambient. It's even better when ambient temps are 70* or lower.
Moving my air filter out of the engine bay did help, but not a great deal, maybe about 10* lower while cruising, next to no difference when in boost. I had to move my filter back into the engine bay, due to a newer radiator that I installed, that interfered with the intake tubing I had.
Car: 1991 Camaro RS
TO4E t3/t4....
I do NOT like the way that I have that IC mounted right now, I think that if i rotate the fins of the IC twards the ground alot more airflow would be getting to it. I never did like the way the camaros breathed in air from below the car...
See in this pic how the IC in vertical..you think if I go through the trouble of making it horrizintal that it would help..... This pic is before i really mounted it but do you see what i mean by laying it horizintally??
What do you think?? Would this help?? Changing the position?
I think you should start by adding an air dam under the rad support, like is supposed to be there.
You may have to go as far as adding ducting eventually, but try the air dam first, it will make more difference than you think.
Car: 1991 Camaro RS
The airdam is there, this is just a picture from when I first mounted it and the turbo set up wasnt complete yet.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you may need to move the air dam forward to blow more air through the IC instead of up into the bottom of it. you may want to go so far as to build a deflector on the top side of the IC. This way, you blow air up from the air dam (mounted to the front bottom edge of the IC) up, hit the deflector and go through the IC. Just blowing air up in front of it may not be enough if its not directed through it. ...just my thoughts
Car: 1991 Camaro RS
Does this sounds like crap??? Its with the exhaust open, about 4Ft from the turbo itself. You can actually sorta hear the turbo wining a little. Thats a first from it wineing by just reving it up??
http://www.youtube.com/watch?v=4TI_i...ature=youtu.be
Heres it with the exhaust like that driving down the road and back.... I had the windows up so the exhaust is louder, but when boost is being made it not as loud??
http://www.youtube.com/watch?v=4TI_iobC4z8
What do you think?? Will it help stricktly at the racetrack????
i told u the cutout would make a world of difference, the muffler u have is restricting the hell out of that thing.also with a turbo car the bigger the downpipe the better, there is no such thing as to big when it comes to the downpipe though u willk get to a point with minimal returns
and yes with a turbo car with an open downpipe the faster u go the quieter it gets.
i also bet u when u cut the pipe ur afrs changed
heres another test for u put the pipe back on then disconect it at the miffler and see if it runs the same as witht he pipe disconected in the front. if it does u know the muffler is the issue and replace it with a cheap 30$ bullet mufler
Car: 1991 Camaro RS
Yea huge difference in spool up time and power in general. I might just have to pick up a cherry bomb style muffer, to help me when im just driving an playing arround. But ill see if the muffler is the problem first, im sure it is, after where i had the exhaust open its just straight back 2 1/2 pipe all the way.
Oh yea AFRs did change, exspecialy at idle, but they were a little higher overall(about .2-.4)
if u buy a cherry bomb paint it black or something, a big red tube muffler under the back of the car will get u pulled over lol
summit ells cheap bullet mufflers that will quiet the car down a bit better then a cherry bomb and are still straight threw muflers
like one of these
http://www.ebay.com/itm/Dynomax-Race...cc36be&vxp=mtr
Car: 1991 Camaro RS
Ahh ok, I know what im looking for then. I dont know if ill get that by the first race but I plan to have the car running open like that at the track. Is it ok to have the cut out about 3-4 ft from the turbo??? After the 90* off the turbo, then the straight pipe down, then the last 90* to aim back to the back of the car... after that mess, I had the exhaust open(its about 3-4 ft in total off the turbo and about 2Ft from the o2 sensor)
yeah that will be fine
i almost forgot go datalog a 0-100mph run witht he pipe disconected so i can see the difference in the data log
Car: 1991 Camaro RS
Ill get on it on tommrow and make a run. Will that effect my tune alot? I think I have dialed in well. Im running a little more timing now and it seems to pull more at high rpms with no knock. Roughly 19* of timing at Higher Rpms, 10psi of boost.
the afrs may change a lil bit now that the ex isnt choked
Car: 1991 Camaro RS
they can go up or down a lil bit shouldnt be much though
Engine: LZ9????
Transmission: 2004R
I am so freaking jealous right now
and effe the noise police too, i got a ticket in strongsville for my exhaust and its not even all that loud lol.
Car: 1991 Camaro RS
On that blazer? Well thankfully I live in the country or id have tickets too. So they still do that emmisions crap out there?? I lived in akron about 8 years ago and they still had that stuff then....
Engine: LZ9????
Transmission: 2004R
out here they do the full visual inspection for smog gear and then idle, free rev at 2200 rpms. last time i had my fleet smogged was in crackron, forgot the exit but its right off I-77/76. by the time i got the blazer on the road it was exempt so i took the stock exhaust off. now the mustang is exempt(25+ years old). since im mil and stationed out of state im exempt anyway.old jaloppys FTW!
Car: 1991 Camaro RS
no and thank gawd because im bleeding from the ears when i get out of that thing lol. i got the ticket in the mustang, 130 bucks
old jaloppys FTW!
Thats freaking awsome man! Senior Member
Engine: LZ9????
Transmission: 2004R
/reminiscing
I found that with in my Jimmy (turbo Hybrid 3.2L 660), that it was actually quieter without a muffler, than with one. So I ran a 2.5" exhaust. I did have a catalytic converter in it though, from Magnaflow.
Car: 1991 Camaro RS
Hey dave, could you toss up a timing table that your were useing on that turbo set up you had. If you still have one?? I just wana see what you had for a timing curve.
Also you guys when on tuner pro my (spark advance to ref. pause is about 13 degrees???) Is that suppose to be my base timing, because on my timing light I set the base to 10 degrees and the ref. angle on the $59 is 9.84 degrees?? So what exactly is the spark advance to ref. pulse?? What im thinking is that is what the ecm is adding to the base timing, but i want to make sure Im thinking right... Thanks!
get urself an 89 2.8 maf bin and take a look at that. i basically ran a stock 2.8 table +4*
Car: 1991 Camaro RS
i was somewere around 26* @ 7,000 rpms @ 9 psi timing peaked in the upper rpms but dont forget i also spun my motor just a tad over 2,000 rpms more then u do
ill dig threw my old tune files later, i dont know how well u can copy over a maf spark table since its not refernced by map presure.
the only way i see u could convert the table would be to convert the table to pounds per min of air then plot it on the compressor map for the gt3076 turbo and figure out how many pounds of air per minute = whats boost presure
unless i can dig up one of my old ignition maps then u can just copy that over since ms uses speed density
Car: 1991 Camaro RS
Ok @ my 10Psi I have all 17* and 18* degrees in my cells with a one 19* degree cell in the middle(3k area)
Man you didnt have knock with that much timing?? Mabey thats why I feel less power up on the top Rpms?? And in the next cells over 6-8 PSI ive got starting at 17 degrees up to 20 degrees but the curve is in the middle Rpms. Man Im thinking I need to work on these SA tables more.
I really didnt want to copy them, but get a basis of what the timing curve looks like..does it peak at the highest running RPM's of peak at the middle ones(3-5K)?
Car: 1991 Camaro RS
Im not sure how well you can see this but heres my map of the SA.
they peaked around 5,000 and cariied all the way out
basically i put all of my timing in by about 5k and just carried the table out
no knock that i ever knew about but i didnt have a knock sensor i just used my ears and checked my plugs from time to time
Car: 1991 Camaro RS
I check my plugs alot when Im really beating on it, to get a reality check. Plugs dont lie!What kind of intaketemps were you seeing...did you have the volvo intercooler. Man, my timing is way lower then that...like ALOT. about 8-10*s lower.
mine got hot cause of the crappy volvo intercooler intake temps would get well into 140's i dont worry about it to much since i know of cars with blowers that see well into the 200's
Car: 1991 Camaro RS
Wow man 200* intake temps. Ive seen the highest of 132 so far@11psi, and that was after a long as* cruse then doing a standing 1/4 mile(2 times)opps. And really I need to get that airdam to work better. Dumb thing is sorta bent back from all the abuse over the years. I know thats not helping!
Well the weather looks like its gonna be nice on my day off so Ill get to play again on the timing, im going to add some timing and make that curve higher, then add fuel as needed..well see what happens I guess.
Car: 1991 Camaro RS
Well dave, I bumped the timing up and its maxing at 22* @10Psi 5krpms and out. Car didnt show any knock, and arfs are fine, but it was also cool out this morning. I was definitly cheating myself on timing. I looked at my stock spark map and it was 23 degrees at 100kpa 5600Rpms, so I sorta modded those numbers.
One problem I AM having is when it shifts into 2nd gear it spins "a" tire.
Every time when at WOT, so the boost goes down one psi or so for that split second the tires spin. I know that wont be a issue at the track but jeez the road was dry as a bone and still it spins at 30Mph??
I left like a 15ft burnout that i could see in the rear view mirror, the first time I went WOT. Its hard to tune WOT on the road when every time its shifts from 1st to second, it lights a tire up.
does it pull better with more timing?
the reason i told u the danger zone was around 21/22* was i didnt want u to jump right up that high until u got a feel for the tunning
do u still have the muffler unhooked?
weres the new 0-100 video and datalog?
Car: 1991 Camaro RS
Yea dave it pulls better forsure! I got it at the 22* area at 10psi and untill it gets up arround 70 degrees outside, im going to leave the timing there for now.
Car: 1991 Camaro RS
Layed like a 15 ft mark on the road at 35mph... the muffler is hooked up. I only had about 1 hour today to play with the car......EDIT!:Heres the attatchemnts if you look at the mph at the 30ish MPH you can see that it doesnt move or i actually slowed down, a slight KR in there at a few spots that need attention.
