what makes more power> HSR or mini ram
Car: 1989 Iroc Z
Axle/Gears: moser 28spline/Auburn posi w/ 3.73
I'm wondering what makes more power the HSR or the miniram? If anyone has dyno charts that would be great, it would also be nice to see any picks of these setups.
well honestly neither are going to CREATE power for you. Your stock TPI unit is awesome. I have run 12's with the TPI. Now if you go larger cubes or a mean cam set up then a mini ram is greate due to the short runner length. The HSR is awesome too for a decent build that is leaves room for alot of improvement. IMO the mini ram is better pick b/c they are so close in price
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Some food for thought.
Be sure to read the specifics on each combo "as tested" they are slightly different.
https://www.thirdgen.org/forums/tpi/...feb-super.html
Well how wild is the 383 and what are your future goals? I say mini ram for a low 11 high 10 second car and HSR for everything else. Both need special prom burnt chips and tuning so there ya have it. TPiS and look for mini ram.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
BTW the HSR is FAR cheaper than the Miniram...Much better overall value. Both will support serious HP with an edge towards the Miniram.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
with a camaro it should be fine as far as hood clearance goes.. maybe some mild mods to the support braces on the hood.
i think HSR will support 500hp on a 383. how much higher do you wanna go n/a? theres been a test on all those intakes and the HSR did make 500hp on one 383. i know its possible. seen a few other motors with HSR's that were making well over 450hp judgin by trap speeds/ET's. HSR is cheaper by a good margin.. i wouldnt go miniram unless u get it cheap. i think its overpriced. the LT1 conversion is also a good bet.. very similar to the miniram intake.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
But with the same long block, the miniram will make more power than both. Even if its a 400hp motor. Regardless fo the manifolds potential in terms of max power, theres a max potential with a perticular combination. My old 355 with a fully ported, siamesed, aftermarket TPI setup was about 400hp. With a signleplane manifold, it was about 460 or so HP. Does that mean the intake's max potential was 400hp? No way, I bet on a more radical, better engine it woulda pulled off 450hp no problem.
You can't look at the max potential for a manifold, you need to look at how they will all perform on YOUR engine. Miniram hands down always wins.
-- Joe
Car: 1989 Trans Am GTA
Transmission: M28 T56
Oddly enough I fit a HSR under a stock TransAm hood on my 89 GTA. I had to turn the screw clamp upside down so the screw was on te bottom of the throttle body. I eventually would have trimmed the hood brace abit, but the motor started knocking about 1 month later.
This was with stock motor mounts only about 1 year old.
Car: 1989 Iroc Z
I want to get the Golen Engine Service 383 long block designed for the miniram. But I was thinking of putting the HSR on it to cut down on cost. I also don't feel like modifiying my hood though.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 1991 Z28
Engine: 383
If you are going to the trouble of dropping in a 383 whats modifying a hood brace? If you don't mind paying twice as much then go for the Miniram...I'd just modify the brace and put the money to something else go-fast.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was talking about the original poster, he has a IROC IIRC.
You finally get the Corvette you were looking for?
-- Joe
Car: 89 Iroc-z
Transmission: TH400
The HSR will fit under a camaro hood no problem if you don't have poly motor mounts.
It'll fit much better than it does on a bird anyways.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I think for the price I would really consider an lt1 intake over the stealth ram. You will get the same characteristics as a mini ram at half the price seeing that the mini ram is a rip off of the lt1 intake. I think there is a .5 difference in runner length.
Car: a car being parted out
Engine: blown up
Transmission: in peices
Originally Posted by anesthes
I'd go with a ported HSR purely for cost reasons if it fit under my hood. Personally, I think an HSR can be ported and modified to flow just peachy. Its about 1/2 the cost of a miniram. However, it just wont fit.
-- Joe
-- Joe
The past few times you were talking about the C4 hood. Fine we all know it won't fit but grumpy DID get an airbox made that would work, and work very well for the C4 crowd.
As far as under the 'Birds hoods, it is really simple...
you have 2 choices...
A. Cut the hood.
B. Cut the intake.
I choose B and had 1/4" milled off of it. It fits just fine.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Originally Posted by V6sucker
why do you keep saying it will not fit...
A. Cut the hood.
B. Cut the intake.
A. Cut the hood.
B. Cut the intake.
Engine: blown up
Originally Posted by Tony89GTA
Got a pic? Also did you have to cut the hood brace?
I will post a link to a thread I posted the pics in.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
A. Cut the hood.
B. Cut the intake.
A. Cut the hood.
B. Cut the intake.
HSR = looks neat, efi on the cheap, requires somewhat tall hood.
miniram = performance better than HSR, not very cheap.
singleplane = performance better than all, still not cheap, but requires tall hood.
I had a singleplane on a bird. I cut the hood worked great. Car was soo fast its not funny. . On the vette it wouldn't fit, so I went miniram. If I wanted to modify the HSR lid, and go slower, I woulda went HSR.. If HSR bolted right in for $500 i might of considered it. but to go slower AND have to modify the thing. no way.
-- Joe
Engine: blown up
Grumpy_vette made a 1 off airbox to fit his. I can't find any pictures about it, and he hasnt responded to any PM's.
-- Joe
-- Joe
Just cause you think the HSR sucks does not mean it does.
With no tune on it it is better than the stock TPI was hands down.
Had I not already had the set up that I was gonna put into a truck I might have looked at other intakes.
But also considering I got this whole set up minus the commander system for under $400 I highly doubt anything that cheap could come anywhere near this for the money and still be MPI.
I got out of carbs because they are way to finiky when you travel (change altitudes and humidity). MPI does not have that isue.
And no I did not touch the hood brace.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
he has not responded because the company he got to make them went out of business a year and a half ago. Last I heard (3 months ago) he was still looking for another company to make them but has had no luck.
My opinion on the HSR sucking is my own, I recommend everyone do their own research.
And the whole setup isn't $400, unfortunately. Even on a camaro with no modifications required to the hood, it's $654 according to www.stealthram.com. Still cheaper than a miniram, and for most people it will work just peachy and is a good upgrade over TPI.
However, this thread is "which makes more power".. Miniram.
-- Joe
9192camaro
16
Feb 3, 2019 12:21 AM
Dialed_In
Aug 20, 2015 01:45 PM
