Tuning with the EBL
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Re: Tuning with the EBL
Part of the issue is that the intake manifold is too cold
I guess I thought we could make up for the colder manifold, as previous folks seem to just use more AE and everything works out alright. But I guess they don't snap their throttle open and expect everything to run smoothly.
Car: check
Engine: check
Transmission: check
You can do this as long as the injector DC% is OK (<= 85%). Otherwise will need to increase the fuel pressure some.
RBob.
Car: '92 GMC C1500 RCSB
Engine: TBI + Vortec + EBL 383
Transmission: 4L60
Axle/Gears: 3.08
I have a 195 thermostat in my truck, and have no problems with the throttle... the only coolant passage is across the front of the intake (Vortec heads).
What do your AE and PE parameters look like? See if they've been heavily modified from stock by accident. VE table?
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
This isn't unusual, likely due to a resonate frequency that improves the VE. Just increase the BPC vs VAC table and lower the VE tables by the same percentage. That will provide more head room in the VE table.
RBob.
RBob.
Max DC is about 85% a little before 5000rpm @ 12.0:1 (about where the HP seems to peak), so we have just enough fuel with the 61pph injectors @ 14psi, by some lucky coincidence.
I can post more tables but if you have EBL they are just the 2002 starter bin.
PE stuff:
VE low and high table:
I need more learn time but I did specifically try to learn in the WOT stuff from 1000rpm to about 4800, then feathered in at 90kpa. I did hand fudge the 1000rpm results because it was overflowing the VE, but next time I'll let it do what it wants, and give the table some headroom with the BPC.
Thanks for taking a look.
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
I will be changing my Patriot Freedom heads out in the next couple of weeks to either the AFR 195's or 210's. Haven't decide which just yet.
If I go 195's would it be a safe bet to start with a 2% increase across the board in VE? and 5% increase if I go with 210's.
Car: check
Engine: check
Transmission: check
RBob.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Good Q. Depending on how much your top VE is, I'd just add like 5 across the board and try to do some BLM VE Learns maybe? That way you wouldn't get too far off from stoich, or let's just say a safe AFR. Take this with some grains of salt though, it's just what I would do without any other advice
My other approach would be to do a quick run on the desktop dyno with your current combo with the patriot heads, and then the AFR and see how the the torque curve shifts. I believe you can even get the VE out of it somehow.
They are a fast opening injector, seems to be too fast. At a nominal 14 volts the offset is 213 uSec. Maybe measure the resistance to make sure that they aren't a low impedance injector.
Be sure to multiply the values in the charts by 1000, as they are in mSec while the XDF entries are in uSec.
RBob.
RBob.
Looks like they were 24lbs blue top bosch 3, then modified by FIC to flow matched 48lbs and the data supplied by FIC.
I've heard good and bad about "modified" injectors, however FIC appears reputable so I'll try their offsets as supplied.
Also I noticed the inj offset tables are different in the the ebl bins from aujp. What injector are those tables for?
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I have an idling and low throttle stumble issue, just looking for some guidance in resolving it.
At idle.... my ecm is constantly cycling in and out of s/f mode (single fire), in doing so, my engine hunts as the s/f turns on and off, it also cycles in and out at a low throttle, low load cruise, also causing a very slight stumble situation. What conditions or settings might be causing this constant cycling of s/f mode? I know it enters s/f during DE< and that's fine, but I don't like it coming on during an idle, my idle would be perfect without it, same with low load cruising.
Im curious if there is anything causing this condition, or am I just better off trying to tune the s/f mode out?
The only table I see regarding s/f is for pw only, Im not sure if adjusting this table would have an adverse effect on fueling anywhere else, so im hesitant to try. Is there a scalar with an rpm adjustment?
I am running a 383 with a tf6, and the EBL p4.
thanks
thanks
Car: check
Engine: check
Transmission: check
There are a couple of things you can do. If the desired idle speed is higher then stock, increase the RPM threshold for the idle BLM cell:
BLM - Idle Cell RPM Threshold
Raise it high enough that the ECM doesn't switch out of the idle BLM cell.
The set points for S/F mode can also be changed. They should reflect the minimum allowed PW for the injectors being used:
INJ - Single Fire Mode PW - PORT Only
You can also zero them to prevent S/F mode, or increase them to always be in S/F mode. Having the injector offset and small PW compensation tables correct goes a long way to having the proper fueling on a transition between S/F & D/F modes.
RBob.
RBob.
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
RBob.
RBob.
I will look into my blm idle cell first and go from there. With the issue happening at cruise im not sure the BLM idle cell will cover the range Im in, I will have to verify the rpm at which it happens out of idle.
So the set points being in:
INJ- Single Fire Mode PW- Port Only
This is the only parameter to adjust the s/f?
I will get back onto it after this weekend.
Thx
Engine: LS1 / L03
hey folks,
i was wondering how much time you guys allow to warm up before doing VE learns, or let's say, what's your temperature thresholds in the WUD preferences. I'm getting quite mixed results from transient warm-up to warmed up operation.. my WUD is set to learn from 65°C (150°F) onwards.. learning from WB, t-stat is a 195. Was trying to get some learns done on the daily commute which is about a 20 minutes drive.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I think you're really better off fully warmed up AND heat soaked (intake air temps) for a proper learn. I tend to see higher BLMs during cooler engine operation.
Engine: LS1 / L03
That's a good point you have there on the IATs being influenced by heat soak.. Was mainly thinking about the dynamics of fuel on/in the cold(er) runners and internal engine friction and stuff like that. So, best thing would be do OL VE learns on long drives and have CL compensate for everything else?
Car: 94 C1500
Engine: SBC 355
Transmission: 4L60E 2800 Vigilante Convertor
Axle/Gears: 14 Bolt SF 3:73 Posi
What do I need to change in the $0D mask PCM 7427 to get the TCC to lock up when combined with the Flash EBL? I have wired the EBL ECM and 7427 PCM to Bob's recommendations with the engine coolant temp grounded to a resistor and inputting 50 C. I have altered the upper and lower engine temps to "Engine temperature for TCC off" = 4 "Engine Temperature for TCC on" = 10. Thanks in advance.
Car: check
Engine: check
Transmission: check
Code:
L6729 FCB 133 ; 60c COLD ENG THRESH FOR TCC OFF L672A FCB 128 ; 56c COLD ENG THRESH FOR TCC ON
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
hey folks,
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
How come I can't find the current N/V ratio in the log? It shows different gears in the WUD while driving (the wrong ones) but I cannot find the current ratio in the log to save my life...
Car: check
Engine: check
Transmission: check
You mean the actual N/V ratio? Divide the RPM by the MPH and that is it. Can reduce it by 10% and fill in the table.
RBob.
RBob.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Oh. I didn't realize it was that simple. The docs do say the current ratio is in the logs but I can certainly divide two numbers. Of course I'll use Excel...
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Actually I did use Excel. First I made an N/V column (RPM/MPH). Then I selected the N/V column and made a histogram. Then I plotted the histogram value vs frequency and the peaks should be the correct values for each gear.
Why subtract 10%? Does it always round up? What is the 1stHi row for in the N/V table? Is it that 1st gear is an N/V value between 1stHi and 1stLo and 2nd is a value between 1stLo and 2ndLo and so on?
Also, is there no way to reliably use N/V with an auto? I guess with a stock torque converter it could work, no?
EDIT: Nevermind on the N/V questions. I'll figure it out from earlier in the thread: https://www.thirdgen.org/forums/diy-...ing-ebl-8.html
Car: check
Engine: check
Transmission: check
RBob.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Now I've got a DE issue. This is another one that it's had the entire time, on either ECM. I go from 100% TPS down to 35%. Because it's only 1600rpm, MAP doesn't change much, going from 102kPa down to 90kPa or so. Still in PE. It goes pig rich, and actually causes a nasty buck. Basically a sudden lift to part throttle. I assume I need DE to trigger in this condition and that should help a lot. How do I manipulate the settings to get it to trigger here? The scenario:
My DE tables:
At a high level I know I need to make sure this event triggers both the TPS and MAP thresholds but I don't know what the dTPS and dMAP were in DE land. I suppose I need to lower one or both of these thresholds, and maybe lower the TPS filter...ideas?
My DE tables:
Car: check
Engine: check
Transmission: check
There is no DE while in PE mode. At 35% TPS and 1600 RPM there really isn't any reason to be in PE (that I know of).
Even if DE is active, it is based on the delta MAP value. Which is going to be low as it barely changes. For DE to be active there is the dTPS% and dMAP thresholds, both need to be met.
The dTPS% threshold is likely met in this case, but the dMAP may not be. The dMAP value is the same one that is generated and used for AE. Which makes sense as DE is the opposite of AE.
There is also a DE - Coolant Factor table involved. That and the enleanment factor both work with the dMAP value. Basically, multiply the three together, negate, and apply it as a multiplier against the current injector PW.
RBob.
RBob.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Well for one thing it's already at 90kPa @ 35%. But maybe raising the PE thresholds will help if there is no DE in PE.
That is about as good as you can get.
If IAT is seeing underhood heat from manifold and in part environmental temps it will change BLM accordindly as well.
Seems it is just doing what it is supposed to do?
you will go crazy if you chase BLM changes day to day.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
In a perfect world if the point of intake is in a good cool area seeing ambient temps the IAT table should manipiulate pw for those days it is warmer of colder. And change BLM accordingly
Too late for us. We're already over the brink.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Sometimes you do have to step back...I mean I sometimes find myself trying to convince EFI hold-outs how great it is to have turn key performance in every season. Then I find myself tempted to tune the car for the different seasons. Of course I don't HAVE to....I can stop any time.
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
As such, whatever influences or affects that intake air temperature *should* be reflected in the IAT data.
The objective being a consistently predictable AFR by weight, my IAT is located about an inch above the TBI injector nozzles so that the AFR can be calculated for the point the AFR is created.
To my one still functioning brain cell, the intake air temperature is the temperature of the air at the point it is mixed with the fuel, so that's where I want to measure it as closely as possible.
It matters not whether it's affected by heat soak, winter, summer, whatever, since it's purpose is to represent to the ECM the current intake air temp, whatever it is, and regardless of how it got that way.
Were I running TPI, I'd probably drill a hole in the manifold about an inch before an injector, and use that. ( until I found good reason not to )
Now, if it's mounted in a place or in a way that something like heat soak were to affect the sensor in a way that it's not reporting the temperature of the air, that would be a problem.
As a point of interest once the grams/sec start to rise the incoming air is not heated that much by the engine/ext manifold as it has little time to conduct that heat. If the air cleaner is in a good spot(cool) it absorbs little heat. If at idle another story.
My IAT temps vary widely with rising grams/sec reads in log.
Everything else says it needs it.
Not easy for me to look it up, but if memory serves something like 45% at 2400 RPM, and increasing to 60% at 3200 RPM.
Like Bob, 35% at 1600 seems awfully low to me. Is your engine pulling that hard, is that far into its curve at that low an RPM and TPS ?
It only departs from the oven thermometer stuck in my vent window by any significant amount when stopped in traffic on a hot day, so I'm inclined to believe it's accurate.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I've got PE set to come in fairly early, largely because at relatively low RPM and TPS, the wildcat is already well into its torque curve. ( peak is something like 570 ft/lb at 2700 )
This engine does require 91% VE all the way down at 1000-1400rpm @ 100kPa, though. Then down into the mid 80s by 2000rpm and back up to upper 80s around 3000-3600rpm. It only goes below 80 between 4400 and 4800rpm. Interesting torque curve. Seems very flat.
Car: 1983 G20 Chevy
Transmission: 4L60
Actually the threshold at 1600rpm is 40%, but the hysteresis is 11% so it'll stay in PE all the way down to 29% TPS. I can try raising it, but I just find it odd that a mere 10kPa reduction in manifold pressure causes such a shudder (and big rich dive). I think during the earlier tuning weeks I had the threshold set much higher but I think it was still a problem then. But I also hadn't dinked around with the DE settings, either.
Car: z28, g92, 5psi paxton,42lbs,eblp4
Engine: 5.7 .040bore,195cc trickflow,tpis
Transmission: 5spd
when tuning at idle, should I be looking to get the highest vac reading or for the 14.7 afr. im getting higher vac numbers but a richer afrs?
Fuel consumption, cylinder pressure, heat, etc. is so minimal at idle as to be nearly irrelevant.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I have been playing w this on my car. It appeared that I got higher vacuum w
idle at 20d, but idle feels less "nervous" at 18. I'd rather the smoother idle so agree w Cflick here.
Transmission: 5spd
im comfused because with a carburetor I used to set the mixture screws to the highest rpm achievable and then turn the rpm down with the throttle screw and that's it. but with this thing, if I give it more ve it will smooth out the idle but the afr goes way rich. like 12.2. I though that I could bring it to 14.7.. or is it that with 195cc heads 2032 cam and 43 lbs injectors is to much to ask for at idle?
With an ECM such is not the case.
Likewise, with a carburetor, you had a few limited options. Main jet, metering rods, power valve, and idle mix, and not much more. Anything that came in at low end had some affect at high end, with exception of the metering rods, and nearly everything for high end had minimal if any affect at low end.
With an ECM, and the EBL is very fine grained in this regard, you set everything at every RPM and combination of load separately.
This is both good and bad. It means you have separate control of almost every parameter.
You no longer have to just accept that a good idle mix meant a so-so mid range mix. You can tweek them separately without interfering with the rest of the range.
It also means you have to set almost every parameter ! Fortunately, Rbob provides a number of "stock" bin files so much of that has already been ball-parked for you.
Checked them all are 15+ ohms.
Tried adjusting the offsets and couldn't get it to idle, Had to change the constant to 27.5 lbs to get the A/F half decent enough to idle, at 48lb it was lean off the scale on the wideband.
Sending them back, now going to try the old style Lucas injectors. 52lb part# 01D066B. Anyone familiar with these?
I'll try the original offset tables to start.
Anyone one have any info/ideas in starting offsets for these?
Also for Rbob- the offset tables in the ebl bin are different form aujp-what injector is that based off of?
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Well those sure didn't work!!!!!!!!!!
Engine: LS1 / L03
Dominic,
only if one of the injectors was already nearly double the flow rate to start with
no, jokes aside, is there maybe a problem with the injector offset tables compensating for opening/closing times?
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
My comment was made somewhat tongue in cheek. If the injectors were "flow matched" they should still be 24# injectors. What FP are they rated at? Are they the same injectors used in an LT-5? I have 23# injectors rated at 43psi. If its those injectors, I can give you the offsets in the stock LT-5 bin for comparison and to try out.
These were from FIC-supposed to be their "modified" bosch 3 injectors that would flow 48lbs after they "modified" them.
Thought I'd try them since I'd heard that FIC was reputable and would supply the offsets needed. And yes I've read that "modifying " an injector just doesn't work......
Gonna stick with stock injectors from now on!
Still curious about the offsets in the ebl-p4-3006.
Gonna be awhile before I can tear that superam off again and swap the injectors but I'll try Rbob's offsets in the ebl-p4-3006 first with these Lucas 52lb injectors first, unless someone has better info on them.
Car: check
Engine: check
Transmission: check
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Owner said "That's a good point you have there on the IATs being influenced by heat soak...."
Many of us have also moved the Intake Air Temp sensor (IAT) because it gets heat soaked. Mine now resides in the rubber shroud of a K&N RC-5000 air filter. Leave the old sensor in place to pus the hole. Get a new one, extend the wiring, and make a hole up front (Shroud of Tourin') and you eleiminate a heat soaked sensor.
A few years ago, after header mods, I was plagued with hot restart issues. I solved it by also moving the ignition module out of the TPI distributor (remote coil) I'd go to the store, and wouldn't get a restart due to heat soak in the module. I moved it out onto the fender well, and strapped a big computer heat sink onto it. More more problem. These aren't EBL issues, just heat soak gremlins.
Dave
Dave
Engine: LS1 / L03
Hmm, yeah relocation is also a point i guess, at least for those hot restart issues. But i also learned there are two different (or 3?) types of sensors. One type is more like a CTS (with a lot of sensor tip material to 'filter' IAT changes) and the other one is referred to as "birdcage" IAT and is imho a lot more dynamic... I forgot which is the TPI/MPFI type and which one is used on our cars tho.. A search should bring that up too
